Old 04-01-2013, 10:48 AM   #7831
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,547
Thumbs down ABOUT THose WELDS
If those welds in the previous picture were done at the BMW factory, and they continue to produce bikes with weld-ments like that.......... we are definitely in big trouble. Some of those joints were actually almost cold weld joints.. or at least looked that way in the ( not so good pics as opposed to up close and in person). And don't forget, once paint is applied a weld almost always looks better. COLD WELD = a failure at some point !
After attending college and taking Industrial arts ( welding classes were part of the curriculum) I welded for a while. Yeppers those weld-ments would have earned me a NON PASSING grade ....jus saying
OH MY ...what art thou doing BMW? Surely it can not be only about pure profit and damn everything else?
Racegun screwed with this post 04-01-2013 at 10:49 AM Reason: punctuation ....
Racegun is offline   Reply With Quote
Old 04-01-2013, 10:48 AM   #7832
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,115
Originally Posted by Serp View Post
I've ordered the headlight guard for a mere $156.72.
Also ordered the luggage plate - 77448523742 and small tankbag - 77458534698. Waiting on the guard and plate but my tankbag is ready for pickup.
Luggage plate cost?
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 04-01-2013, 11:16 AM   #7833
MaxReving
MaxReving's Avatar
Oddometer: 251
Yes a low suspension model can be ordered but it is not available with ESA.
This is wrong. The low suspension version can ONLY be ordered with "Dynamic ESA" and "ASC and Modes". Furthermore, you cannot order the low seat together with the lowered suspension because the low seat is a part of the low suspension option.
Below is a screen dump from the German bike configurator. I can not give 100% guarantee that all options are available worldwide.
Max :-)
MaxReving screwed with this post 04-01-2013 at 01:03 PM
MaxReving is offline   Reply With Quote
Old 04-01-2013, 11:42 AM   #7834
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by tau View Post
I can see that still nobody has answered my questions; therefore I'm asking you another one: would you buy it / order it without ESA?
Please explain your reply. Just to be frank with you guys, I'm willing to order it without ESA, as:
- I consider the manual adjustment being more suitable / accurate.
- lower replacement cost
My main problem / concern the case I order it without ESA, is the front suspension which ... can not be adjusted ...!
No because the demo bike I rode didn't have the ride modes and I consider the throttle sensitivity to be completely ill-suited for any offroad use at all and not to my liking for on-road use.
EJ_92606 is offline   Reply With Quote
Old 04-01-2013, 11:44 AM   #7835
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by MaxReving View Post
Hurra for handmade stuff
Ohh my God those weldings don't look nice. They might hold the subframe together but they sure look like someone had a very bad day at the welding factory. Maybe BMW Motorrad has subcontracted the welding but they still have to have some kind of quality control of all the subframes no matter if they made them themselves or if it was made by subcontractors. This for sure does not look like German engineering.
Max :-)
I've seen better welds on a chinese made bicycle frame. Sad.
Old 04-01-2013, 11:51 AM   #7836
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Sorry but this is incorrect.
Old 04-01-2013, 12:51 PM   #7837
Cycling101
Oddometer: 65
I was also told by my dealer and by a BMW rep at the regional motorcycle show that ESA was not available with the low suspension option.
Cycling101 is offline   Reply With Quote
Old 04-01-2013, 12:56 PM   #7838
nwpa
Generally amused
Oddometer: 499
Reading from the US launch guide:
499 Low Suspension, 31.1/31.9 inches (only w/191 Dynamic ESA, Incl 776) - $250
776 is Low seat, 32.3/33.1 inches, $0
191 is Dynamic ESA (only w/190) - $950
190 is Enduro ASC and Riding modes (only w/191, or packages 234, 237, or 238) - $450
nwpa is offline   Reply With Quote
Old 04-01-2013, 12:57 PM   #7839
GSMarc
GSMarc's Avatar
Oddometer: 1,006
"I was also told by my dealer and by a BMW rep at the regional motorcycle show that ESA was not available with the low suspension option"
It is the opposite
Select a basic R1200GS with NO Pack.
When you select Low Suspension in 'Equipment in Options'
ESA & ASC come automatically in the Bike Configurator
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 04-01-2013, 12:57 PM   #7840
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
You were told wrong
Old 04-01-2013, 01:03 PM   #7841
IB1
IB1's Avatar
Oddometer: 994
This was true for the old versions, for the 2013 low suspension is only available with ESA.
IB1 is offline   Reply With Quote
Old 04-01-2013, 01:04 PM   #7842
Cycling101
Oddometer: 65
You were told wrong
Yep. Thanks for quickly pointing that out
Old 04-01-2013, 01:12 PM   #7843
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Read the forum more often...was discussed long ago
Old 04-01-2013, 01:16 PM   #7844
Cycling101
Oddometer: 65
It was discussed. But if I remember correctly it was speculative. And its also a lesson that your dealer and even a company rep get it wrong once in a while. My dealer told me this only several weeks ago.
Ronald Regan once said "Trust. But verify."
Old 04-01-2013, 02:19 PM   #7845
RichBMW
RichBMW's Avatar
Oddometer: 1,991
I've not noticed particularly bad welds on my bike. Even if they are big, at least the bike won't fall apart
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Times are GMT -7.   It's 05:38 AM.
