Old 04-02-2013, 04:21 AM   #7891
IB1
IB1's Avatar
Oddometer: 1,026
Originally Posted by SYDADVGS View Post
Few pics from the weekend:
You've got a beautiful riding region. Way less boring than here. Nice unpaved roads here are rare.
IB1 is offline   Reply With Quote
Old 04-02-2013, 04:24 AM   #7892
IB1
IB1's Avatar
Oddometer: 1,026
Originally Posted by MaxReving View Post
Exactely. I would never red line my GS but that is often the argument you hear from people that don't like then fact that it can be hard to see the rev range. I never look at the rev range, I use the feel for revs. What makes the new GS fast is not the revs but the torque (my view).
Max :-)
I look at my revcounter all of the time. Still running it in and getting the feel for it. Besides, I am still running it in and try and keep it under 5K . But my feeling ATM is that the sweet zone is from 3K to ??? But I don't see why you need to take it over 6K cause there is plenty of torque on tap.
Old 04-02-2013, 04:31 AM   #7893
paulW
Oddometer: 143
Max :-)
Torque all the way for me, never redlined any of my GSs - just no point and shows no sympathy for the engine
paulW is offline   Reply With Quote
Old 04-02-2013, 04:50 AM   #7894
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,178
I only red-line sixth gear.
Although I shouldn't probably be as harsh as Max (someone managed to be harsher than me? This is new...), as I understand some "easy fixes" for any new vehicle to fit your tastes a bit more (and make it "unique" for you), yet indeed with GS (and HD... a comparison that BY ITSELF sucks that I even have to mention) some people go tooooo far ("loosing the point" far I mean).
That said, it's their wallet and their ride.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 04-02-2013, 05:21 AM   #7895
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 829
Thumb Trek
Nice looking Trek. And a hard tail at that. How much does it weigh?
Originally Posted by IB1 View Post
I've been riding for most of the weekend. But not on my GS
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 04-02-2013, 05:31 AM   #7896
Deans BMW
Granpa Hoon
Oddometer: 3,527
Why would you red line this bike, let alone bounce it off the limiter.... .
Well you don't if you ride like a little old lady and never get the rings seated properly and miss all the fun the bike has to offer.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 04-02-2013, 06:42 AM   #7897
UK_Engineer
Oddometer: 67
Not sure if this chart has been posted yet, explains the different riding modes.
After reading that chart, I am glad that I went for the simplest option, just bog standard front and rear shocks
UK_Engineer is offline   Reply With Quote
Old 04-02-2013, 06:59 AM   #7898
NLS
NLS's Avatar
Oddometer: 3,178
Not really curious personally, but maybe you want to explain that?
NLS
My Blog
Old 04-02-2013, 07:00 AM   #7899
MaxReving
MaxReving's Avatar
Oddometer: 257
You are either joking or ignoring the facts. Take a look at the two pictures below. Red line starts at 9.000 rpm and then compare it with the power and torque figures in the other picture (R1200GS LC is the light blue lines).
125 hp @ 7.700 rpm
125 Nm @ 6.500 rpm
What makes it more fun to take the engine over 9.000 rpm ? (in that range it has lost power and torque !! )
Max :-)
Source: BMW Motorrad Press Kit
Source: Motorrad (German magazine)
MaxReving screwed with this post 04-02-2013 at 03:07 PM
MaxReving is offline   Reply With Quote
Old 04-02-2013, 07:25 AM   #7900
sbrownn
SlowMo
Oddometer: 457
Originally Posted by NLS View Post
I think 99.999% of manufactured consumer products out there are like that.
Hint: Even some that don't make ANY mention about that (even in stickers or hidden labels).
I understand what you want to say. Yet it is not entirely true.
Many (most?) people using stock suspension, don't even touch preload.
Many (most if not all) people going to custom suspension, do that EXACTLY to be able to touch anything they want.
They do it at least once when they install it after all (and possibly for the next few km).
So it is first a difference in the mentality and priorities between riders.
For me, not being a competition rider, it is enough if my suspension is OK for about my weight, is OK for my "mean" riding habbits and indeed tries to keep the wheels on the ground.
Rebound for me (again as a "casual" - but every-day - rider) is something I shouldn't bother because I EXPECT the suspension to have the rebound set already as needed for the mean of the parameters above. Preload that needs to vary more because of weight differences IS configurable. Rebound does follow a bit (and should - read the Physics behind it) as it varies depending on the (also variable with modern shocks) compression. Anyway this is a big discussion, that reminds me (ok a bit extreme example) the difference audiophiles find in DIGITAL sound between different cables. Or the nitrogen in tires discussion maybe... ahem.
I personally (again: PERSONALLY, based on my needs and priorities, so keep your fireball spells) find it stupid to have a manually micro tuned suspension when ALL riding parameters change constantly. I start my day on tarmac, I am a bit heavier today (and 10Kg heavier from when I bought the bike years ago) because I ate good breakfast and was in a rush so didn't get a chance to go (erm... you know), then two blocks away I find a friend that needs a lift towards where I am going and then back from work I decide to take a fire-road instead. No I cannot see myself tuning constantly for those parameters. D-ESA is the closest I will ever come to doing this, because partially it does it for me and partially I do it but by just pressing a button.
The only thing I need from my (whatever) suspension, except what was mentioned in the paragraphs above, is to keep doing its job the longest possible, without BOTHERING me with details or breaking up.
BTW my then-willingly-non-ESA 2007 GS did loose front shock oil when just one year old in an Enduro session... Replaced under warranty. What was fantastic though is that because of telelever the bike was actually ride-able for the 10 days I waited for the part - not even close to the bike limits but ride-able (a bike with DEAD front suspension) and I DID ride it daily (carefully) until the shock got replaced. Now that is BMW for me. For you BMW is something else, no problem.
Others love doing this manually or believing that some periodic tuning covers all their needs (or they indeed tune their suspension like 3-4 times a day before they change mode and mood). Well to its his own.
Another more general comment (not even GS or BMW specific): Technology is here to stay, whether you guys like it or not. Things that are innovation today, will be common place and even default (read: ABS and remember discussions 10 years ago - or 5) and even NOT available without in a few years. Sorry.
You don't have to micro tune to be able to take advantage of adjustable suspension and my guess would be that most people do make use of the preload either to set their initial sag and to compensate for either luggage or a passenger. Neither do you have to adjust your suspension all of the time but there is a benefit in being able to initially adjust for your weight, riding style and average road conditions.
Probably the biggest disadvantage with stock suspension is the inability to adjust the spring rate. When people purchase aftermarket suspension systems they can get a spring rate that is specifically suited to their weight instead of the one size fits all stock spring. Part of the reason riders are so pleased when they fit a aftermarket suspension system is that they finally have a set up in which the spring rate is customized to fit them. I am looking forward to getting my new bike with ESA but I also know that for my weight (150 lbs) the spring rate will probably be totally wrong and all the ESA in the world won't change that... but it will help.
sbrownn is offline   Reply With Quote
Old 04-02-2013, 07:44 AM   #7901
NLS
NLS's Avatar
Oddometer: 3,178
Still fail to see this.
Why:
The stock suspension is indeed set for a "mean" weight (which btw I think you are very close to), but also needs to compensate for possible luggage and/or passenger.
Same with a custom suspension... oups!
D-ESA does this with specific presets, plus some "auto" tuning (which I suspect is more mechanic than electronic though).
Non-ESA does this only for preload (still WAY better than nothing).
Again, to me a super expensive suspension, custom made to weight (and preference), is only valid for people mostly riding in a single "mode" and "mood". Whatever changes, they either need to modify settings OR... they are out of the custom suspension manufacturing specs.
Changes include riding style, rider weight (*), luggage, passenger, surface type etc. Even suspension itself "getting old", is a change to be compensated (except if you guys ride for a living so it makes sense to rebuild your suspension every few rounds... erm... months).
* I mention rider weight by itself as something changing, because according to you, a generic suspension made for a mean of 80Kg is... different from a custom suspension made for a guy like you 70Kg... OK. Let's accept this (and this indeed DOES make sense for Valentino Rossi). So if you actually gain weight, the suspension you paid 2K is no longer for you? This is what you say? What happens if your luggage is 10Kg? (EASY) Do you include that in your custom order calculation? What happens if you don't ride with the luggage then?
You see where I am going?
Anyway as I said from the start, to its his own.
We don't have to like the same things. Also I don't see a universal truth in this discussion.
NLS
My Blog
Old 04-02-2013, 08:08 AM   #7902
cug
Oddometer: 4,980
You would be completely correct if a manufacturer for about the second or third time in history put in a suspension with proper spring rates for the "mean" rider and gets the damping right.
You might not notice or not care or not have a really good suspension to compare to, but that doesn't make it any better or worse. It's just that you "don't see it" while others do. What you seem to do though is saying that others are wrong in not being happy with the suspension quality delivered by BMW. I think that's where the disconnect is.
But never mind. It's different for different people and some will say the suspension is great and others will say the suspension is crap and both will be correct from their point of view.
R1200R/RS LC Forum
cug is offline   Reply With Quote
Old 04-02-2013, 08:17 AM   #7903
Gompie
Oddometer: 174
I'm not sure what we're discussing here. Sure, on straight line acceleration there is an optimal point to shift. That point is when the next gear delivers more torque at that rpm than the gear you're in. And no that is not simply peak power, or peak torque points on the published maps. It's in between, and you'll need to do some extensive excel homework to find out. The shift point changes only by a few 100 rpm across gears, but the good news is feel tells you even better.
The other side is driving style related twisties. This is where you ideally want to drive in one gear, thus not having to downshift for the next turn and keep the bike more balanced. I go 8000+rpm here on my 2010 GS. This is where you offset high rpm, vs one upshift, and one down downshift, on a short distance
Gompie is offline   Reply With Quote
Old 04-02-2013, 08:22 AM   #7904
NLS
NLS's Avatar
Oddometer: 3,178
Originally Posted by cug View Post
What I say is not a BMW thing.
My post was mostly generic.
Now if BMW and GS specifically has "wrong" suspension, is another discussion (I refuse the term "bad" when they always used pretty good OEM as suppliers - it's not that they make the thing themselves).
NLS
My Blog
Old 04-02-2013, 09:09 AM   #7905
Deans BMW
Granpa Hoon
Oddometer: 3,527
You don't take it over 9K as the revlimiter kicks in at around 8,900 R's . some engines pull strongly to the rev limiter. When playing Ricky racer in the mountains I often hit the rev limiter with my R1200ST, my R1200S, my R1200GS Cam head and my K1600GT, some bikes, you never do as the power falls decidedly quickly before the rev limiter.
Dean O
Copperhill, Tn.
Times are GMT -7.   It's 03:44 AM.
