Old 05-20-2013, 11:31 PM   #9001
hdog
hdog's Avatar
Oddometer: 558
Zumo 550 on 13 gs
Any one wired a zumo 550 or montana to the new GS.. I have an older 550 and wanted to fit it where the BMW cradle is...Other option is to buy the BMW Nav4. but I like my garmin..I like my topo maps too. I always wanted to upgrade to a montana...the only reason I would think of the BMW nav would be for the handlebar function... Any thoughts
I only need 14 hp to ride around oz ...the rest is wheelspin
KTM 1190 R
KTM 690 R
hdog is offline   Reply With Quote
Old 05-20-2013, 11:54 PM   #9002
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Besides the slick handlebar function, tying into the bike's electronics also lets the Zumo display a lot of info about the bike as well. Have a look at this if you haven't seen it.
http://www.ascycles.com/detail.aspx?ID=121329
twinrider is offline   Reply With Quote
Old 05-21-2013, 12:11 AM   #9003
oz97tj
oz97tj's Avatar
Oddometer: 829
I have a Montana that will be replacing the factory cradle with a Touratech mount. I just need to go pick uo the mount.
'15 KTM 500 EXC / '13 BMW 1200 GSW / '05 Honda ST1300 / '04 Husqvarna TE510
oz97tj is offline   Reply With Quote
Old 05-21-2013, 12:30 AM   #9004
IB1
IB1's Avatar
Oddometer: 1,026
Originally Posted by NLS View Post
Go for the LED.
1) People verified it is way better.
2) It's not just the light. One has an extras package that the other doesn't.
3) LED is becoming something like the trademark of the new LC GS. I see people in a few months (non GS people) to say "ah this is not the new one, the new one has the LED".
4) No LED WILL (I will sign for this) affect resale value. If you care.
On the other hand. LED is an "unknown" right now. We don't know the real longevity of it (supposedly it's huge).
90% of the bikes sold here have the LED. All the demo's and showroom models from the dealers are equiped with it.
They are trying to make it a trademark thing.
And the light is way better compared to old 800.
IB1 is offline   Reply With Quote
Old 05-21-2013, 12:54 AM   #9005
IB1
IB1's Avatar
Oddometer: 1,026
I loaded my bike up with some luggage in the 3 cases and noticed the bike was a little lower. I could almost flatfoot the ground. So I pressed the button for ESA 1+ luggage and it rose about 2 cm I think.
Now the question. I weigh about 65 kg (144 lbs) and give or take about 25 kg of luggage (paniers included). Should I really use the 1+luggage or just stick to solo rider? While riding I don't really notice a difference. (I put it in rain since it is pouring with rain here).
Old 05-21-2013, 01:01 AM   #9006
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,176
Really light for a GS. :)
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 05-21-2013, 01:06 AM   #9007
RichBMW
RichBMW's Avatar
Oddometer: 2,111
I weigh the same as you and will leave it in rider, no luggage, when the panniers are fitted. I read somewhere that the rider without luggage is set up at the factory for a rider weighing around 175lbs.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 05-21-2013, 01:13 AM   #9008
IB1
IB1's Avatar
Oddometer: 1,026
And with 5'7" also really short for a GS.
Old 05-21-2013, 01:16 AM   #9009
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Same size as me.
I have bad knees so I'd probably prefer the taller setting for the additional legroom and cornering clearance. But if I took it off road I'd switch to the lower setting so I could get my feet down flat when necessary.
Old 05-21-2013, 01:31 AM   #9010
IB1
IB1's Avatar
Oddometer: 1,026
Originally Posted by twinrider View Post
Same size as me.
Ok, 5'7" with short legs here. Low seat in low position with the lower suspension. (and I still can't flatfoot the ground).
Old 05-21-2013, 01:41 AM   #9011
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
I've got a 30" inseam (just in case you have a different measuring system there, that'd be the length of the Levis that would fit).
When I took the LC GS for a test ride I had the seat in the low position, normal suspension. I'm so used to only being able to put just one foot on the ground while stopped after owning an 11GS, a Dakar and a Super Tenere that it comes as second nature now. But offroad it definitely helps to even be able to get both balls of your feet down. Don't ask me how I know.
Old 05-21-2013, 03:14 AM   #9012
nwpa
Generally amused
Oddometer: 499
What's your method for getting on the bike? Do you leave it on the centerstand. Btw I have a 30 inch inseam and can only plant my toes on the high seat setting I prefer.
nwpa is offline   Reply With Quote
Old 05-21-2013, 03:28 AM   #9013
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Leave it on the side stand, stand on the left footpeg and swing your leg over the seat dirt bike style.
Watch this vid from 2:29
Old 05-21-2013, 03:45 AM   #9014
At adventure
AB
Oddometer: 142
Originally Posted by mercieca View Post
Should have asked, are they spoked wheels? Read below if they are.
Just going to put this out there. Ask to check if the hub is not off centre to the outside rim. When I bought my GS years ago, it was the first time they had seen this problem on my bike. I had the dealer at the time say the same thing, and actually say your just getting used to the bike, so don't take no for an answer. Ride it at low speeds and see if there is a bobbing effect.
Yes spoke wheels but no problem at low speeds. I only feel a slight shake from 80km when riding in a straight line. Thanks for the tip though I will check that. Cheers AB
At adventure is offline   Reply With Quote
Old 05-21-2013, 04:01 AM   #9015
Voz
Voz's Avatar
Oddometer: 491
I am 6 ft 120 kg, short legs long body. I run my GS LC in single helmet setting and can flatfoot both feet, love this. The bike seems to ride perfectly in Soft setting. I also carry about 20Kg of luggage on my daily commute.
I don't think u have anything to worry about!
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Times are GMT -7.   It's 08:12 AM.
