Old 05-21-2013, 05:02 AM   #9016
IB1
IB1's Avatar
Oddometer: 1,024
Originally Posted by twinrider View Post
I've got a 30" inseam (just in case you have a different measuring system there, that'd be the length of the Levis that would fit).
When I took the LC GS for a test ride I had the seat in the low position, normal suspension. I'm so used to only being able to put just one foot on the ground while stopped after owning an 11GS, a Dakar and a Super Tenere that it comes as second nature now. But offroad it definitely helps to even be able to get both balls of your feet down. Don't ask me how I know.
I have no idea of my inseam. total leg length is 99cm, but that is a different measure.
Originally Posted by nwpa View Post
What's your method for getting on the bike? Do you leave it on the centerstand. Btw I have a 30 inch inseam and can only plant my toes on the high seat setting I prefer.
I put it upright, hold it stable with my left hand and pop my right leg over it. Side stand is usually retracted.
IB1 is offline   Reply With Quote
Old 05-21-2013, 05:09 AM   #9017
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,370
That's a good way to drop a bike. Leave the side stand down, that's what it's for.
twinrider is offline   Reply With Quote
Old 05-21-2013, 05:49 AM   #9018
Voz
Voz's Avatar
Oddometer: 484
Man award right there.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 05-21-2013, 06:16 AM   #9019
IB1
IB1's Avatar
Oddometer: 1,024
Originally Posted by Drew View Post
Photos, or it didn't happen.
I'll try and make a little vid on friday.
Main reason I do it like this is cause the side stand is a little to far forward making it harder for me to reach.
Old 05-21-2013, 06:25 AM   #9020
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,145
Make sure you do it while YOURSELF is taking the video.
Now that would be cool.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 05-21-2013, 06:52 AM   #9021
IB1
IB1's Avatar
Oddometer: 1,024
That's easy. I just mut my gopro or camera on the ground and hit record, then I get on my bike. I'd better use the gopro with this weather (need something waterproof).
Old 05-21-2013, 07:01 AM   #9022
Bazgab
Bazgab's Avatar
Oddometer: 192
Originally Posted by Voz View Post
I am looking to attach my wiring loom from my Admore LED lights installed in my Givi V46 top box. I had this loom wired into my Versys 650. I had a look under the GS seat and there is very little wiring in there, haha.
Anyone have any advice? I need to tap GND, 12V, Left, Right, Brake & Lights. I can see the wires running to the rear LED lights, can these be tapped?
The picture I linked earlier is a good place to get a switched 12V power source. You would probably also need to feed the tail light wire from that same 12V source, as I mentioned if you tap into the tail light wire with any anything that draws even a little current you will throw an error code.
I exposed the tail light/brake light wires, that run together along the right side of the tail, a couple inches from the back of the bike as it was impossible to get to the exposed wires right by the tail light connector. The turn signals are easy to find, there are (2) two-wire connectors about halfway up the tail on either side. Tap into the blue wire for Left/Right turnsignals. GND is any brown wire you can find.
I can take some pictures of what I did if you need them, though the bike is a little messy at this point.
Bazgab is offline   Reply With Quote
Old 05-21-2013, 08:32 AM   #9023
Voz
Voz's Avatar
Oddometer: 484
Thanks, so you are wiring up something similar to me.
Any more detail pics would be great if you have them, cheers.
Sydney, Australia
Old 05-21-2013, 09:55 AM   #9024
Bazgab
Bazgab's Avatar
Oddometer: 192
I was wiring up some P3 LEDs (you can see them under my license plate) which have similar wiring compared to your topbox lighting. The bike is taken apart like that for the wiring of my auxiliary LED driving lights and the associated components (control unit, handlebar switch).
I will take some more pictures this evening when I get home.
Old 05-21-2013, 05:40 PM   #9025
hdog
hdog's Avatar
Oddometer: 557
Besides the slick handlebar function, tying into the bike's electronics also lets the Zumo display a lot of info about the bike as well. Have a look at this if you haven't seen it.
http://www.ascycles.com/detail.aspx?ID=121329
Thanks for the info.. It's an option.
I only need 14 hp to ride around oz ...the rest is wheelspin
KTM 1190 R
KTM 690 R
hdog is offline   Reply With Quote
Old 05-22-2013, 02:22 AM   #9026
At adventure
AB
Oddometer: 134
What is the dealer wanting to charge you for the BMW Nav IV? I was quoted $1600 which seems outrageous. I got some story that it needed to be installed even though I have the GPS bracket. I plugged a mates Garmin 650 into the bracket on the weekend and it worked fine. The touch screen with gloves was pretty good and at $530 I think I will go with that but I know not being able to use the controller will annoy me! I don't think the extra features from the integrated unit are a big deal but I do like the idea being able to control it with two hands on the handlebars.
At adventure is offline   Reply With Quote
Old 05-22-2013, 02:58 AM   #9027
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,370
That really sucks. BMW also fleeces customers in Japan with bike and parts prices being much higher than in the US, but the Nav IV is sells for a pretty reasonable $700. Could be wrong but I think it just has to be enabled by the dealer if the bracket and handlebar control are already on the bike. Have you asked BMW OZ about the cost?
Old 05-22-2013, 03:31 AM   #9028
At adventure
AB
Oddometer: 134
New Panniers
https://www.dropbox.com/s/ref7d73u14...2015.58.12.jpg
https://www.dropbox.com/s/23rklsyxdq...2015.55.51.jpg
Holan frames and locally made boxes.
Old 05-22-2013, 03:36 AM   #9029
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,370
Nice and narrow, was thinking about getting the same boxes but the cost of shipping put paid to that idea.
Old 05-22-2013, 03:49 AM   #9030
At adventure
AB
Oddometer: 134
Too bad. Why don't you see if you can become the Japanese distributor if you can't find one there. Or just buy the frames and have the panniers made locally. I liked the narrow profile as well. The width is less than the handlebars and almost identical to the lower crash bars.
Times are GMT -7.   It's 09:47 PM.
