Old 07-04-2013, 06:53 AM   #9781
nwpa
Generally amused
Oddometer: 499
Originally Posted by kindofblue View Post
Not sure I follow your comment so this may be tangential. I did figure out that the adjustment of the brake and clutch levers made a huge difference for me. My bike was set up with the indicators at 4 and the levers were way to far away from the grip. I changed them to 1 and immediately noticed a difference. The clutch and brake levers now are like my '10 GS were. Just right.
I actually prefer the levers on different settings (between clutch and brake), but that's just me of course...
nwpa is offline   Reply With Quote
Old 07-04-2013, 07:52 AM   #9782
RichBMW
RichBMW's Avatar
Oddometer: 2,029
Originally Posted by Bails View Post
Is this with the LED lights ? I have the LEDs did not feel range was an issue but more intensity ? I don't ride at night as a rule but on my recent trip spent an hour on the road in the dark, lots of Roos in the area. I felt the max speed for these lights would be around 100 kph , not that I wanted to go faster but for me the lights limited the speed in dark areas.
Yep, that's on the LED
Originally Posted by At adventure View Post
I agree with your light observation. This is not a hieght adjustment issue (which I have done). Around the city the LED is fine and it gives great daylight presence it just lacks a bit of grunt out in the sticks at night. Anyone got any auxiliary light recommendations including where to attach them?
You guys do know that you have main beam for when you're in the sticks?
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 07-04-2013, 02:54 PM   #9783
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Is that with the high-beams on as well or low-beams only?
tallguy-09 is offline   Reply With Quote
Old 07-04-2013, 03:22 PM   #9784
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
How does it compare to the previous GS' halogens?
EJ_92606 is offline   Reply With Quote
Old 07-04-2013, 03:36 PM   #9785
Bails
Bails's Avatar
Oddometer: 401
I have every thing on ! There are things out there in the Aussie bush that can jump on you!
I have oredered the very very expensive BMW driving lights , which I hope will give a little more light. I don't ride at night if I can avoid, but the last time was due to a friend setting a Lead Wing down in the wet and by the time we sorted Towing , Ambos and reorganisation the next stop was in the dark.
I aim to be a bit prepared for the unexpected if possible.
If it has to Be then it's up to Me!
Bikes Multi Strada 1200 BMW GSA
Bails screwed with this post 07-05-2013 at 01:27 AM
Bails is offline   Reply With Quote
Old 07-04-2013, 04:08 PM   #9786
At adventure
AB
Oddometer: 134
The LED is definitely better than the previous GS halogen. At day time it has great presence and at night around town it casts a wider beam and the high beam is as much as you need in a built up area. I don't feel the need for aux lights around town (as I did with the previous GS) Or to give greater road presence. The issue is the high beam out the back of BF! It is at least as good as the previous GS halogen but I feel I want more so I will be adding some flood lights. I don't want to pay for the BMW ones and I don't want cheap Chinese ones so I am looking for Goldilocks?
At adventure is offline   Reply With Quote
Old 07-04-2013, 07:22 PM   #9787
atwoodtja
Oddometer: 383
I'm talking about the axial placement of the levers on the handlebars relative to the grips (brake lever specifically), not the regular 1234 adjustment of the levers for hand size.
BTW, I've also taken a shot at further clutch adjustment. Even at position 1, smallest hand adjustment for the lever, it engages too far out IMHO (YMMV). The clutch lever assembly comes out easily, just remove the bolt/nut holding it on and gently slide it out away from the master cylinder plunger gasket. The outside portion of the plunger is a round-ended rod with grease on it that just sits in a recess in the plunger. This rod is threaded into the cross-collar-nut and has a 2mm allen at the end that makes it seem adjustable, but unfortunately it also seems to be permanently lock-tited, at least I couldn't get it to budge without too much force on such a small piece (want to ask my dealer mechanics about this next time I'm there). For now, I left it alone and resorted to filing off some of the surface at the end of the main adjuster (just push out the brass cylinder that holds the outer lever to the inner one to get to this).
atwoodtja is offline   Reply With Quote
Old 07-04-2013, 08:34 PM   #9788
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Have we seen some Xenon conversions yet on the wet-head halogens?
Old 07-05-2013, 12:24 AM   #9789
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
A friend mounted the Clearwater Darlas on the stock GS (2013 LC) mounting brackets and is quite happy with them.
Old 07-05-2013, 11:07 AM   #9790
atwoodtja
Oddometer: 383
Forget the locktite comment above, looked at it again in daylight and there is another 2 mm allen set screw going up; its marked with red paint on the bottom of the assembly. You don't even have to remove the clutch lever to adjust it, just loosen the set screw first from below and then turn the threaded plunger rod out to bring the clutch engagement closer to the bar, then tighten the set screw and you're done.
I'm thinking about starting a separate thread on GS tire prices; I'm still in sticker shock after initial shopping at swmoto. I'm used to paying about $250 or less per set on the Ducati, so $175 for just the front seems like highway robbery.
Old 07-05-2013, 12:27 PM   #9791
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,023
What model(s) tire are you looking at? What kind of mileage did you get out of the ones on your Ducati?
I am thinking that more manufacturers are going to offer tires in the range we need for our water heads. I would gladly get a set of regular Tourances (not Next or EXP) when my current Tourance Nexts wear out. I like the Nexts ok, but not sure how long they will last.
Tyres, front 120/70 R 19
Tyres, rear 170/60 R 17
Old 07-05-2013, 12:43 PM   #9792
nwpa
Generally amused
Oddometer: 499
Us:
Old 07-05-2013, 03:09 PM   #9793
nachtflug
infidel
nachtflug's Avatar
Oddometer: 46,588
Bad:
-the steering is too light at high speeds. Also, in high-speed sweepers I could not throw the bike from upright to full lean with the same confidence as my ducati because it takes such a precise and delicate touch to avoid any wobbles as you pitch it over.
Does that mean if you were to rate your Ducati in area's where the GS excels in you would deem it "bad" because it didn't do things as well as your GS?
nachtflug is offline   Reply With Quote
Old 07-05-2013, 05:33 PM   #9794
Bails
Bails's Avatar
Oddometer: 401
I have always found BMW levers are too far out for my liking. These are better than previous models, but for some reason BMW feel it essential to have long pulls to work clutch and brakes . I don't think my habds are small , long pull on the clutch makes it harder for faster changes , that is if you want to use the clutch.
Muxt admit though the bike improves greatly with miles, the gearbox seems to be getting better in the lower three gears and I just seem to feel more and more confident all round .
Old 07-05-2013, 07:36 PM   #9795
Voz
Voz's Avatar
Oddometer: 484
Originally Posted by nwpa View Post
Us:
He is thinking "come at me bro!".
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Times are GMT -7.   It's 11:35 AM.
