Old 07-07-2013, 03:05 AM   #9811
802mike
802mike's Avatar
Oddometer: 442
Maybe it's been discussed before in this thread. If it has, I can't find it with
the "sucky search". And, I'm not bored enough to read every post in it.
I noticed that the new GS only puts out 5?? watts compared to the old one's
7?? watts.
I figured that's because of the LED lights so it doesn't need all that extra power.
One thing that always drew me back to BMW was the gadget power. I like lots of
gadget power!!!
802mike is offline   Reply With Quote
Old 07-07-2013, 04:42 AM   #9812
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,176
7?? watts.
gadget power!!!
Yes new GS produces less but also consumes less.
I am not sure of the difference in what "remains" for the extra gear (might be almost same).
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 07-07-2013, 05:11 AM   #9813
jerryj
Lets Ride
Oddometer: 63
Originally Posted by Dahveed View Post
He is either confused or lying. My plug came with the bike stored under the rider's seat. Its red and hard to miss.
I'm pretty sure I know what I am looking for,but it isnt there.
'13 R1200 GS LC
'07 DL650 ABS
89 Transalp For Sale
jerryj is offline   Reply With Quote
Old 07-07-2013, 05:17 AM   #9814
Marki_GSA
Oddometer: 599
7?? watts.
gadget power!!!
It's a fair point especially If you don't have the LED lights. Even with the LED lights your probably only saving 40w compared to halogen. I have no idea how much if any they have saved on the electronics front but I would seriously doubt they have save another 100 odd watts to make the systems equal.
To make a proper comparison BMW would need to publish power consumption figures and I can't recall seeing this although I have seen it for the hexheads.
Maybe someone can put a meter on theirs and let us know?
Marki_GSA is offline   Reply With Quote
Old 07-07-2013, 05:42 AM   #9815
cjack
cjack's Avatar
Oddometer: 859
580 watts compared to 720 watts. So that's 140 watts less. Or 10 amps less at 14v.
There are only 2 spark plugs instead of 4. So that'll save some. I used to think a normal 2 plug system took about 4 amps, but I kind of doubt that these stick coil systems take that much. Anyway it's a saving there.
Let's say 2 amps.
Halogen headlight bulbs take 4 amps each, but LED headlights (or driving lights) only take 1 amp each.
So that 3 amps each saved for the two headlight bulbs or 6 amps total.
Now we're up to 8 amps saved.
And of course if you use LED driving lights instead of halogen, then you save another 6 amps.
That would be a total of 14 amps saved over what was provided for previously when the high beam was on and the driving lights were being used.
In total, the new bike as a system, has a 4 amp surplus over the old bike when just considering lighting and the ignition system. :)
My other bike is a BMW
Jack
RA & MOA #224
cjack screwed with this post 07-07-2013 at 05:50 AM
cjack is offline   Reply With Quote
Old 07-07-2013, 05:49 AM   #9816
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 822
Originally Posted by jerryj View Post
mjne didnt come with the bike,ask my dealer today and he said there wasnt any in the US and didnt know when they would arrive.
My plug was on the bike when I got it in April right after the "unveiling" event at our dealership.
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 07-07-2013, 06:11 AM   #9817
nwpa
Generally amused
Oddometer: 499
I'd have The dealer take one from another in stock Bike.
nwpa is offline   Reply With Quote
Old 07-07-2013, 06:21 AM   #9818
jerryj
Lets Ride
Oddometer: 63
I think that is my next step Thanks All.....................Jerry
'13 R1200 GS LC
'07 DL650 ABS
Old 07-07-2013, 06:26 AM   #9819
Marki_GSA
Oddometer: 599
Let's say 2 amps.
Can you link to figures for the 1A per headlight? Current figures would have the actual light out put in lumens a fair bit under a normal halogen. Personally I think the LED lights will be neared 3A, more than happy to be proven wrong though.
As I said earlier what if you don't have LED as many don't? They don't come with a bigger alternator to make up for it.
Valid point about the 2 spark plugs that will save a bit but then you have the added synchro throttle bodies and all the other electronic stuff the older bikes don't have.
Old 07-07-2013, 10:27 AM   #9820
atg
Oddometer: 225
Adding to the subject:
The GSLC not only has a new smaller alternator but also a new smaller battery (12 Ah).
In spite of very likely differences in watt consumption of the new versus previous model, the major reason for a change in battery capacity and, therefore, alternator capacity is the new starter system that uses much less energy to start the engine due to the new decompression system.
Although I find cjack's calculations perhaps too optimistic regarding LED consumption and Marki GSA more likely closer to the actual real value, the fact is that to know the real values one has to either measure them or get BMW's specs. The first are most likely easier to acquire...
What I think we can safely assume is that there are at least 5 amps available to the user as this is the limit of the accessory socket and another 1 amp if one doesn't use the GPS and an additional (estimated ) 3 amps if one doesn't use the original auxiliary lights. Most likely there is more watt reserve available, however, how many extra watts are available is, without measuring or BMW's specs, a wild guess.
Andre
atg is offline   Reply With Quote
Old 07-07-2013, 12:59 PM   #9821
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,581
The GSW alternator at 580 watts (is that correct?) supplies a whopping 20 watts less than my '05 which was rated at 600 watts. My '05 had power assist "whizzy" brakes that sucked up the juice. There was still plenty of power left over for halogen fog lights, heated gear, etc.
I did not order LED lighting. It's not that important to me. I'll be moving the same halogen fog lights to the new bike. I expect to still have plenty of power left over for heated gear. More than I had with my '05.
marchyman is offline   Reply With Quote
Old 07-07-2013, 02:42 PM   #9822
Bails
Bails's Avatar
Oddometer: 402
You will this noise about 580 is just that noise ! I can remember my first car having 30 amp Generator, and those were the days when a valve radio was fitted ! Here we have a 48 amp Alternator @ 12 Volts , or 42 amp @ 14 volts . Have a look at some car specs and you'll find this alternator is as powerful.
If it has to Be then it's up to Me!
Bikes Multi Strada 1200 BMW GSA
Bails is offline   Reply With Quote
Old 07-08-2013, 05:38 AM   #9823
Cara Pálida
Cara Pálida's Avatar
Oddometer: 254
Mensch!
Are they doing SUVs now????
Abr.,
CP!
Don't follow me, I'm lost too!
Please, be gentle with my english! I'm native in portuguese.
Cara Pálida is offline   Reply With Quote
Old 07-08-2013, 07:08 AM   #9824
atwoodtja
Oddometer: 408
It looks like BMW is thinking if they make the front of the new GSA "round" enough, it will roll right over and back upright again when you drop it. Would solve the problem of having to pick this beast up. Just spring load the windshield so it folds down out of the way...
atwoodtja is offline   Reply With Quote
Old 07-08-2013, 09:19 AM   #9825
Marki_GSA
Oddometer: 599
Hmm yes your spot on, BMW were just playing with themselves when they increased the alternator output on the newer oil heads. It was obviously all just for show and or to rob their customers of a bit more hard earned.
It's not a valid comparison in any way but my last couple of cars have all had 100A + alternators. I will bet your car didn't have 20A plus of computers and fuel system taking power. In fact I would say it was probably from the 70s at the latest so had very little of anything electrical.
Everyone will come to their own conclusion and to most it won't matter at all. It might to those who have their bike lit up like a Christmas tree and use heated clothing though.
Times are GMT -7.   It's 08:34 AM.
