Old 07-11-2013, 02:06 PM   #9886
atg
atg's Avatar
Oddometer: 243
Originally Posted by kindofblue View Post
Hi all,
To follow up on the discussion of tires for the LC, I thought you might be interested in this email tread between Metzler and yours truly. I've also posted it over in the thread about LC tires at
http://www.advrider.com/forums/showthread.php?t=896111
Note the comment about the EXP oem tires.
Thanks for the reply. That's very interesting about the oem tires. I was not aware of that. I would think that the lower tire life on the oem tires could be adversely affecting your subsequent sales of EXPs. I certainly didn't get another set based on the durability of the oem tires.
Warmest regards,
Reid
On Thu, Jul 11, 2013 at 9:24 AM, Metzeler Web Assistance, US <webassistance.us@metzeler.com> wrote:
Hello
You really cannot compared a Tourance EXP to the old Tourance unless you consider this fact. The OEM Tourance EXP tire fitted at the factory (a different part #) has a tread depth that is 1 mm less than the replacement EXP tire in the same size that we import for replacement sales. So what we have seen with the replacement EXP tires over the last few years is a mileage range of about a low of 3,500 miles to a high of about 10,000 miles. But remember tire mileage is always lower when the air pressures are under 40 front & rear, if the roads are rough (I.E. dual sporting, traveling to Alaska) or unpaved. We hope this helps.
NA Metzeler M/C Tires Consumer Affairs
877 202-4993
www.metzeler.com
Thanks for the reply. Do you have any data to suggest that your Next tires will last longer than your standard Tourance? The reason I ask is that I had a set of Tourance EXP tires as OEM equipment on my 2010 GS and they lasted ~4500 mi. While they had good grip, they didn't last worth a darn. The standard Tourance tires I had on my 08 GS, on the other hand, lasted 7,500 mi. And I rode these two bikes comparably.
Warmest regards,
Reid K. Hester, Ph.D.
Director, Research Division
Behavior Therapy Associates LLC
Behaviortherapy.com
Drinker's Check-up
ModerateDrinking.com
Overcoming Addictions
On Tue, Jul 9, 2013 at 7:23 AM, Metzeler Web Assistance, US <webassistance.us@metzeler.com> wrote:
Hello
We are offering the Tourance Next and the Karoo 3 in these sizes and we currently have no current plans to offer these sizes in the old technology Tourance tread pattern. The Tourance Next are leaps and bounds ahead of a Tourance and feature the Interact technology and a dual compound construction in the rear. So please air up the tires (38-42 front and 40-42 rear) and enjoy them. Thanks for the e-mail.
877 202-4993
www.metzeler.com
Kindofblue;
I am indeed surprised to learn that the OEM tires have 1 mm less thread than the replacements ! I wonder why as cost wise the difference must be ridiculous and also if this is true of other tire manufacturers.
Thanks for this info.
Andre
atg is offline   Reply With Quote
Old 07-11-2013, 02:13 PM   #9887
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,192
Originally Posted by atg View Post
NLS;
Cerainly the expression: "harmonised ASC and ABS " was coined by BMW's marketing department...
Already available in present LCs it is asystem that integrates ABS and ASC with differently with each riding mode.
For instance, in ENDURO PRO the rear wheel ABS is not active when the rear brake pedal is pressed; the ASC is less active compared to other modes.
In RAIN mode, both ABS and ASC ae quite sensitive and it actuates at the least provoking.
Each of the modes has a different setting for each ABS and ASC.
Again nothing new is offered on the 2014 model (in this topic ) as compared to the present model
Andre
Maybe you are right, but I am not convinced yet Andre.
You see someone would expect a similar term for this years GS too then.
I have some hope for an additional sensor or something, that is extra.
(for example I think GS never had the lean sensor installed to assist ASC and ABS - a vital sensor for these things I believe)
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 07-11-2013, 02:55 PM   #9888
Voz
Voz's Avatar
Oddometer: 502
2014 gs
I will bet that there is new switchgear, just does not get mentioned in the press release.
Faulty switchgear has affected a lot of us, it can not continue.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 07-11-2013, 03:00 PM   #9889
NLS
NLS's Avatar
Oddometer: 3,192
Wonder about the brand, type and install location...
Wonder if they make it optional extra for the 2013.
NLS
My Blog
Old 07-11-2013, 04:09 PM   #9890
kaiserlover
Oddometer: 25
my ride
Do you your unit has multiple issues or the model has multiple issues ?
If yours has multiple issues I agreeits worrysome. If you mean the model has multiple issues, perhaps you are worrying too much for problems that you may not have in the future.
Relax and enjoy ! Its still a really great bike and certaily all the troubles will be sorted out.
My 2011 GS was great and had no problems whatsoever. Nevertheless, I much prefer my LC with whatever problems it may have had/has or will have. Do you feel different ?
Andre[/QUOTE]
21842478]kaiserlover; hi andre. thanks for the feedback. I have a c650gt with 4000 km. it stalls while riding making it very dangerous to the point that I won't ride it. also the clutch rattles so much in low rpms that it is disappointing to say the least. bmw hasn't responded with a recall or a solution and can't or won't fix it. how would any one feel that pays more than double what everyone else pays for a bike without a test ride or even a look at the bike? I know you pay mega bucks in your country for bmw as well.
so why buy it? cause folks here rave about it that's why. and I like to have quality products.
it's not about the money but it is. it's about disappointment when you pay double for something and you get a product that is less than you expect.
I put a deposit on the r1200lc back in dec. last year and hav'nt gotten it yet. when I read about clutch issues and gearbox problems and switches breaking after only a few months some red flags come up.normal I think. I look here for support and practical thinking from guys that own the bike and what experiences they are having. I even listen to guy's that think my opinion is rubbish because maybe I am over thinking this. I read your statement and know that you fully understand about paying big and getting a machine that does not live up to expectations.
so thanks to the guys who responded about their experience with the topic I brought up. I hope you and everybody else has a great ride and when you don't your not stuck all by yourself trying to sort it out.
kaiserlover is offline   Reply With Quote
Old 07-11-2013, 06:00 PM   #9891
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 5,017
Originally Posted by tallguy-09 View Post
Overall I like the looks.
I'm not liking that rear rack. Looks like you would need to run the passenger seat to get a level loading platform. Have to wait and see whats there when they release it, Hope they get this detail right.
bemiiten is offline   Reply With Quote
Old 07-11-2013, 06:04 PM   #9892
gr8ridn
gr8ridn's Avatar
Oddometer: 419
Originally Posted by Hicks View Post
guys. Finally, I got an access to the REPROM for LC (cannot share further though).
For torque moments etc, just ask me. Will try to help.
Can you please give the part number of that REPROM. It should be on the lower section of the back case label.
Something like 01 59 7 xxx xxx
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 07-11-2013, 07:48 PM   #9893
atg
atg's Avatar
Oddometer: 243
Andre
so thanks to the guys who responded about their experience with the topic I brought up. I hope you and everybody else has a great ride and when you don't your not stuck all by yourself trying to sort it out.[/QUOTE]
Hi kaiserlover;
Your message manage to convey how you feel and I must say I fully sympathize with you !
I am not familiar with the 650 GT as BMW's scooters ( if one can call this bike a scooter...) have not yet been launched in Brazil.
Nevertheless the problems you so well describe have no reason to exist in any bike, much less on a BMW.
Brazil is an important BMW Motorrad market. In fact we are either fifth or fourth largest market in the world for BMW motorcycles. BMW from Germany is here, not an independent importer. I do not know how it is Thailand. Perhaps if you write BMW Motorrad in Germany to request a solution that your local BMW Motorrad is not providing may help. As in any world company, instructions from the headoffice tend to make a big splash !
As I mentioned above, I have no experience with the 650 GT but from what I know from other automatic transmissions it is quite common to have noisy transmissions while stopped or on low acceleration. Stalling, however, is definetelly not acceptable.
You mentined ypu placed a deposit on your LC in December, thats 7 months ago... I placed a deposit on mine in October as soon as it was launched in Germany and received it on April 25th, that was a 6 month wait. Consider that mine was the first GSLC delivered in Brazil.
Yes, as you can see, there are many common points in our "BMW roads"
The switch cluster that I had problems with was finally exchanged after a 2 month wait. The clutch still has not been sorted out but I am certain it will.
Over here the long wait is usually result of the very bureaucratic import procedures obviously helped by the sheer size of a company like BMW. Still, BMW's posture regarding its brazilian customers is very serious.
I sincerely hope you get the problems with your bike sorted out as soon as possible but if it was me I would write a long letter to BMW Motorrad head offices in Germany.
All the best,
Andre
atg screwed with this post 07-11-2013 at 10:16 PM
Old 07-12-2013, 12:58 AM   #9894
RichBMW
RichBMW's Avatar
Oddometer: 2,203
The switches will be the same, but the mechanism behind will be different. BMW won't be redesigning their switches for the new GS for a long time.
2016 BMW S1000XR Sport SE
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 07-12-2013, 01:30 AM   #9895
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
Originally Posted by Emoto View Post
Hmm. How many miles on it now? I am thinking mine is gradually improving, but am not really sure. 2500 miles on mine.
14000kms = 8700 miles
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 07-12-2013, 03:32 AM   #9896
NLS
NLS's Avatar
Oddometer: 3,192
On the contrary.
The rack indeed is flat with the passenger seat, yet there is still the under-platform (if you remove the top rack) that is flat with the rear seat removed.
Also what is the problem KEEPING the seat on if it helps? It's not that it weights that much nor that it raises luggage CoG that much.
To be honest, in my experience, when loading something on the rear, the limited "give" of the seat pudding both keeps what I carry more stable (as it is pushed in a bit) and safer (is like an extra shock absorber) and less vibrations to go to the luggage OR back to the rear frame FROM the luggage.
NLS
My Blog
Old 07-12-2013, 03:51 AM   #9897
atg
atg's Avatar
Oddometer: 243
I see no reason (technical) to redesign the switch cluster. After dismantling the cluster and repairing one of the internal switches on my bike I found that the necessary changes needed to fix the problems so many have experienced is a simple one, however it has to be made in its injection tooling.
For the switch manufacturer (OEM supplier ) I think its a simple solution of increasing the gap between the outer switch body and the internal working "piston" which is the actual moving part.
In fact, I believe the "fix" was already made. My switch cluster was exchanged less than a week ago and its working smoothly. I will report as time goes by.
Andre
Old 07-12-2013, 04:44 AM   #9898
bemiiten
bemiiten's Avatar
Oddometer: 5,017
Yup, more weight, higher center of gravity. Or in other words, a clear step back from the previous model. I'll add in less secure as well.
Old 07-12-2013, 05:09 AM   #9899
NLS
NLS's Avatar
Oddometer: 3,192
As I said, the rack looks removable.
I don't see any of the other things you say either.
I have previous model, I would prefer to agree with you, but I can't.
NLS
My Blog
Old 07-12-2013, 05:30 AM   #9900
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,496
I like to remove the passenger seat and just run with the rack because it makes me look like a rugged world traveler who has no time for trifling things like women when I pull into the local Starbucks.
twinrider is online now   Reply With Quote
Times are GMT -7.   It's 09:35 PM.
