Old 07-15-2013, 07:19 PM   #9991
pauljm
R1200GS WC
pauljm's Avatar
Oddometer: 77
Originally Posted by deacon51 View Post
well, yeah.... pretty much.
Easy solution to the wife problem. Just a get a new one as well to complement the new bike. :)
or maybe threaten to if she doesn't come on board. Or work harder on her, I found being relentless usually wears them down.
Ok so it took me a few months to convince my wife as well that it was a great idea. Still not sure how I got that one past her. But it seemed easy now.
Working on new tyres & Akra exhaust at the moment. :)
R1200GS LC
pauljm is offline   Reply With Quote
Old 07-15-2013, 09:26 PM   #9992
Tonopah
Tonopah's Avatar
Oddometer: 460
Continental tkc-80
I have a rear tire in the correct size but can't find a 120/70 R19 front tire. Shop is telling me not to worry about it as the readily available 110 / 80 R 19 will work just dandy.
Opinions before I buy it? Perfectly ok or bad idea?
A gun is like a parachute. If you need one, and donít have one, youíll probably never need one again
Tonopah is offline   Reply With Quote
Old 07-16-2013, 03:54 AM   #9993
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,181
A 110/80 is a taller, narrower tire than a 120/70 and should make the bike steer more quickly, that is to say, be more responsive to steering input. Not by a lot, but some. Is that what you want?
Old 07-16-2013, 04:03 AM   #9994
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,964
I'd expect it would work in a pinch, otherwise I'd keep looking for the correct size tire.
bemiiten is offline   Reply With Quote
Old 07-16-2013, 05:47 AM   #9995
pauljm
R1200GS WC
pauljm's Avatar
Oddometer: 77
lol... for the record, if I let go of the bars on my FJR it'll pitch me on the ground.
I assume the staring dampener will improve performance and help the bike track straight on rough roads / off road. I also know from my test ride that the R1200GSW likes to wheelie.
For the record I regularly put the bike in cruise mode & let go of the bars to adjust gloves or whatever. Never had wobbles or anything the bike tracks perfectly at any speed unless your going ballistic & it lofts the front wheel then it's a good idea to hang on.
I like a steering damper for sand & some off road situations & will probably add one eventually when a viable option come out. Not n issue for me if its OEM or rally moto or Scott or... The ralle moto worked great on my F800gs.
R1200GS LC
Old 07-16-2013, 06:06 AM   #9996
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,181
It is my position (and the position of Honda, as detailed in a mechanics course) that operation of the motorcycle without holding the handlebars constitutes improper operation and that therefore anything that happens when operating the motorcycle improperly cannot be defined as a problem. I happen to agree.
Another point is that motorcycle chassis are relatively stable as they accelerate or maintain speed, and inherently unstable as they decelerate. This explains why you can run without hands when cruise control is keeping the speed steady.
Old 07-16-2013, 07:35 AM   #9997
Tonopah
Tonopah's Avatar
Oddometer: 460
>A 110/80 is a taller, narrower tire than a 120/70 and should make the bike steer more quickly, that is to say, be more responsive to steering input. Not by a lot, but some. Is that what you want?<
I'm on Anakee lll's now and have 5700 miles on the bike. I live in AZ and have done one long trip through Nevada/CA/Death Valley, etc. The ties do have flat spots because I cannot avoid a lot of slab in high heat. The tires have been great and actually have a lot of life left in them. My home here in AZ is up a dirt road about a mile long so I ride "dirt" every day (easy road but dirt none the less). The Anakees do just fine.
I am going to Sturgis this year and will take a detour though the Dinosaur Nat'l Monument on the way -- this will be maybe 50 miles or so of dirt and I suspect the roads will be iffy and more challenging than I am accustomed to. I am 65 years old and 5'8"/175lbs and don't want to drop my new $20K bike and I don't bounce like a 20 year old either. I'd like to cheat by using TKC-80s but the front tire is not available as yet seemingly anywhere.
Kinda hate to put the "wrong" front tire size on the bike so I have been thinking about it...maybe just stick with the very good Anakees and ride slower? Dunno. That's why I asked for opinions. Thanks.
Old 07-16-2013, 09:02 AM   #9998
iride4u
iride4u's Avatar
Oddometer: 321
If you are going up to Dinosaur National Park why don't you call BMW of Grand Junction, Colorado it should be on your way. They were very good to me this spring when I needed a new rear tire on my K1600.
iride4u is offline   Reply With Quote
Old 07-16-2013, 02:10 PM   #9999
pauljm
R1200GS WC
pauljm's Avatar
Oddometer: 77
Why not try the new karoo 3 or Anakee wild?
R1200GS LC
Old 07-16-2013, 03:34 PM   #10000
Tonopah
Tonopah's Avatar
Oddometer: 460
The Karoo 3 is on backorder where I live and the TKC-80 is expected to be seen first. Dunno about the Wild though. I could also just use Heidenaus but I am one of the Heidi doubters.
Old 07-16-2013, 03:46 PM   #10001
Bails
Bails's Avatar
Oddometer: 402
So... why I'm not jumping.
First... I would like to have a complete understanding of the bike before I commit to it for the next 5 to 7 years.
Second... the MSRP on this bike will be more than twice what I paid for my current bike.
Third... First production run products tend to have minor issues that are corrected in later production runs.
Forth... I have never owned a BMW, I know the brand has a very strong following of loyalest, but I also know that quality control issues have dogged many of the brands "Flag Ship" models.
So it's hard for me to convince myself to abounded a perfectly capable bike so that I may invest twice the money on a first run bike from a brand with known quality issues for a fantasy of getting out of the city and searching for Adventure. Plus - I think the addition of a steering dampener as standard equipment is a major modification to the GS Line... and very telling.
That and my wife isn't on-board with the idea... yet.
I find it interesting when I am at the service centre for my European car and am listerning to the first time owners having a whinge becase the indicator switch is on the wrong side and for the price of entry it should have been perfect for them? I buy Euro for the engineering and design, not with any expectation it wil be perfect. I buy German engineering becuase it seems to be better than Austrian or Italian.
If it has to Be then it's up to Me!
Bikes Multi Strada 1200 BMW GSA
Bails is offline   Reply With Quote
Old 07-16-2013, 04:06 PM   #10002
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 822
Originally Posted by Farang Paul View Post
I had the same problem for a long time on my Harley and thought it was the vibration from the bike.
Then an (even) older biker told me to tuck my elbows in toward my body, and straighten my wrists, then relax them. This should increase blood flow to your hands and fingers and stop the tingles.
Works for me.
Rox risers may help. They did for me.
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 07-16-2013, 04:30 PM   #10003
pauljm
R1200GS WC
pauljm's Avatar
Oddometer: 77
Why not order online then. I saw them both on Revzilla & I am sure there must be many other US sites that probably offer them. Just an idea.
Can't get them in OZ at all yet, none have reached our shores yet.
R1200GS LC
Old 07-16-2013, 04:48 PM   #10004
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,444
Originally Posted by steelerider View Post
The GS can do everything the RT can, but its not the other way around.
It can also be argued that the RT is far better at LD superslab and, depending on how big the rider's stones are, can still go offroad...
twinrider is offline   Reply With Quote
Old 07-16-2013, 06:26 PM   #10005
steelerider
Southafricanamerican
steelerider's Avatar
Oddometer: 930
Sure, I've taken the RT off road. It feels like the bike is taking a beating with all the plastic rattling around. Plus, if it goes down, it's going to costs hundreds of dollars to fix it. No thanks!
steelerider is offline   Reply With Quote
Times are GMT -7.   It's 08:33 AM.
