Old 08-30-2013, 02:32 AM   #10621
At adventure
AB
Oddometer: 142
Originally Posted by JimVonBaden View Post
Ahhhh, good point!
Jim
The point is shit happens so don't assume all is in order. Better to check the bolts securing the handlebars are tight especially if doing lots of off road riding.
At adventure is offline   Reply With Quote
Old 08-30-2013, 04:22 AM   #10622
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,507
AND, make sure that you used the correct bolts and torques in the first place.
Jim
Old 08-30-2013, 07:31 PM   #10623
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Jim
Are you sure Jim no Loctite is being used on those screws? What is the reason some screws use Loctite but not others?
Only really safety relevant?
tallguy-09 is offline   Reply With Quote
Old 09-01-2013, 03:07 PM   #10624
JimVonBaden
"Cool" Aid!
Oddometer: 54,507
I can only tell you what the manual says. I have not taken one apart yet.
Jim
Old 09-02-2013, 11:38 AM   #10625
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,253
Question for you GS-W owners with the non-LED halogen headlights:
Have you tried any higher wattage bulbs in there yet? I see that 65, 70, and 100 watt bulbs are readily available. Might be nice in the high-beam lamp, but it would suck if the canbus shuts off your headlight circuit.
Old 09-02-2013, 01:37 PM   #10626
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,613
More wattage translates to more heat. My preference is to go for more lumens at the same wattage. Except you don't get all that many more lumens at the same wattage and you usually get reduced bulb life.
55W H7 about 1500 lumens
55W H7 "plus-50" about 1580 lumens (but half the life)
If you want to experiment try the Osram 65 watt H7 rallye+65. I don't think (haven't tried one, yet) the extra 10 watts will hurt anything. That bulb gives you 2100 lumens at about the same life of a stock H7.
http://store.candlepower.com/osraulhiouh7.html
It's what I'll try when I finally use up my supply of "plus-50" bulbs.
marchyman is offline   Reply With Quote
Old 09-02-2013, 01:41 PM   #10627
cug
Oddometer: 5,030
I had these in my 2010 GS and I really, really liked them. They are about 60% of overall light output of a HID installation, with much better light distribution.
One night we were out with two GSs - one with HID install and mine. The HID light was all over the place, blinding oncoming traffic, scattering everywhere. The light in places where you needed it was actually very similar, but for my eyes it was better usable with the Osram bulbs. Less scatter and distraction, better use of the reflector. Better light temperature.
I would definitely recommend them.
cug is offline   Reply With Quote
Old 09-02-2013, 02:01 PM   #10628
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,253
Thanks for that link, and the recommendations, guys!
Yes, I realize more wattage = more heat. Am wondering how much our GS-Ws can take.
It also remains to be seen how tolerant of a larger draw the canbus will be. It may be that anything more than 55w and it shuts off the circuit. We won't know until someone tests with a bulb. Same thing for the high beam. A 10w high beam would be very nice indeed, but will the bike tolerate it?
I should check my box of electrical odds and ends, but I don't think I have any H7s rated at more than 55w to try. I kind of hate to buy bulbs that might not work...
Old 09-02-2013, 04:23 PM   #10629
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
The All New 2013 LIQUID COOLED R1200GS threadfest
Had them as well, didn't like them to be honest. I could not see a big output change. 35W 4300K HID is way better, at least during the day for passive safety.
Old 09-02-2013, 05:57 PM   #10630
cug
Oddometer: 5,030
We didn't compare much during the day - certainly more conspicuity, but that's mainly because the light is all over the place. I would not hesitate doing that with a Tiger 1050 with projector lenses, but I wouldn't do it on a reflector lamp. I hate the people coming my way with that stuff (mostly older Civics or Corollas) just too much.
Old 09-02-2013, 07:41 PM   #10631
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,559
Important to shim the bulb of the HID to make sure it sits in the proper orientation to the reflector (front to back). If it's off, you get the light spread that you're talking about.
"Everybody loves cunnilingus!" Chacifer
"The road to paradise is paradise" Jacques Yves Cousteau
Jabba is online now   Reply With Quote
Old 09-02-2013, 10:11 PM   #10632
mefly2
mefly2's Avatar
Oddometer: 1,228
Suggest go with aux LEDs; there heat is not a problem ...
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 09-03-2013, 03:46 AM   #10633
iride4u
iride4u's Avatar
Oddometer: 321
Sylvania makes Silverstar bulbs in different brightness's, they are readily available and seem to work well when I have used them before.
They just released a new model.
2013 R1200GS LC red
2012 K1600GTL blue
iride4u is offline   Reply With Quote
Old 09-03-2013, 07:59 AM   #10634
sbrownn
SlowMo
Oddometer: 457
No loctite
Jim
I've had mine off and I don't recall any Loctite.
sbrownn is offline   Reply With Quote
Old 09-03-2013, 10:59 AM   #10635
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 817
Will these Rox Risers fit the 2013 LC and do I have to re route the lines?
http://roxspeedfx.com/product/gunmet...ing-risers.htm
Got places to do and things to be.
'14 1200 GSA
seatec is offline   Reply With Quote
Times are GMT -7.   It's 10:29 AM.
