Old 10-05-2013, 09:33 AM   #10906
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Originally Posted by alouisell View Post
Has there been any thought or conversation given to modifying the US versions to allow full use of the LED running lights as in the EU? From what I have read the US version is restricted to 40% intensity, while the EU version has automatic switching from high to low as well as a manual override. Would be nice to get 100% of the light from that sucker...
Have a look at these posts I did to explain on another thread:
http://advrider.com/forums/showpost....&postcount=781
http://advrider.com/forums/showpost....&postcount=783
Oh and the second pic in this one: http://advrider.com/forums/showpost....&postcount=776
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 10-05-2013, 09:36 AM   #10907
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Originally Posted by deacon51 View Post
If you come up with anything be sure to share. I would love to have the full use of the headlight but my bet is that it would be easer to import a bike from the EU than changing over a US market bike. I'm not even sure we have an ambient light sensor.
Sent from my Nexus 7 using Tapatalk 2
You do have the light sensor as this also switches on the backlighting for the instruments.
Old 10-05-2013, 07:35 PM   #10908
MIBavarian
Dude idonno...
MIBavarian's Avatar
Oddometer: 19
Originally Posted by duffs View Post
Thanks to all for your input on the DRL... and Duff, great breakdown of the setup. I look forward to having a closer look at it when my bike arrives. Maybe rewire it with a H/L switch, seems like a plausible solution...
In the meantime I guess I will continue to read about how great it is to own a 13/14 GSW and stack my accessories in the corner of the garage as they arrive. Mine was off the boat in NYC on Sept 16, but the terrain between NY and MI has so far proved impassable. Waddya do? (well... what I do is call my dealer and ask if they have any new information on my bike, then I hang up the phone and )
MIBavarian is offline   Reply With Quote
Old 10-05-2013, 07:42 PM   #10909
MIBavarian
Dude idonno...
MIBavarian's Avatar
Oddometer: 19
Originally Posted by iride4u View Post
Info for everyone who is waiting for 2014s. There is a hold up on the East coast. I do not know if it is customs or BMW as I have heard both ways.
I have a X1M coming into the West coast in 2 weeks and so far that seams to be OK.
What did you hear? Aside from the fact that there is a lot of us waiting (thus indicating a hold up...) Do you know anything specific?
Should we call our Congressmen and Senators, the national guard, the President if we must and say "Let our Beemer's go!" To hell with the shut down or whatever else they are dealing with, there are citizens waiting on GSW's! ...OK that might be too much. I'll just sit here and wait... (crickets chirp)
Old 10-05-2013, 08:54 PM   #10910
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,614
2014s now arriving, being uncreated, and finding their way onto so cal showroom floors.
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 10-05-2013, 09:19 PM   #10911
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
When do you pick yours up?
'13 R1200 GSW
EJ_92606 is offline   Reply With Quote
Old 10-05-2013, 09:29 PM   #10912
oalvarez
oalvarez's Avatar
Oddometer: 2,614
EJ! I still need to ride one of these darned things! And to think I had a deposit on one of the first '13s!
oalvarez screwed with this post 10-05-2013 at 09:35 PM
Old 10-06-2013, 12:25 AM   #10913
Random-Water
Oddometer: 149
You won't be able to hook the LED's to a switch. The wiring going into the LED controler is...odd.
Wire #1. Variable resistance anytime the key is turned on. No continuity to ground. Voltage (negative side) from .5 to .1v that changes. Appears to be a communication wire.
Wire #2. Constant Ground
Wire #3. 10.9V when key turned on but engine off. 12.9V (battery voltage roughly) when engine running.
Wire #4 14.5V anytime key is turned on
Wire #5 14.5V anytime key is turned on
So the "welcome light" feature is somehow programed into the LED controler. As it doesn't show in the voltage going to the lights.
Random-Water is offline   Reply With Quote
Old 10-06-2013, 04:27 AM   #10914
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
LEDs require a constant voltage within a narrow range - the dimming effect is achieved through pulse width modulation (PWM) which is performed by a micro controller - this is why the LEDs at lower intensity flicker when filmed (tail lamp vs brake lamp on all models, parking lighting vs DRL on ECE models).
The function of PWM is to switch the LED on and off many times per second (not sure of the exact hertz used by BMW, likely in the range of 100-240x/second). The ratio of on-time vs off-time determines how bright the LED looks to your eye. Old CRT monitors and televisions showed onscreen images the same way which is why they appeared to flicker at refresh rates of 60hz or less.
So, in a nutshell, there is no way to 'rewire' the LED to run the DRL at full intensity as this is a function of the regional (US/ECE) programme in your bike's ECU. In theory you could reprogramme it with the ECE software but you would also need to order in the left ECE handlebar control unit with the DRL switch and also the instrument panel controller would need a software update to connect the ambient light sensor to the headlamp controller and enable the DRL indicator light to work.
One thing I'm not clear about is the welcome light function on US/DOT bikes - when you first switch on the key, is the DRL at full intensity, or is it at reduced intensity like when the engine is running?
Old 10-06-2013, 01:01 PM   #10915
Aviatordoc
BMW K12S rider
Aviatordoc's Avatar
Oddometer: 405
So do these new '14s come with the steering dampner?
Aviatordoc is online now   Reply With Quote
Old 10-06-2013, 01:20 PM   #10916
nwpa
Generally amused
Oddometer: 499
Yes
nwpa is offline   Reply With Quote
Old 10-06-2013, 06:23 PM   #10917
kjazz
Oddometer: 204
Recent WC R1200GS rental experience...
I rented a new GS from MotoQuest in Long Beach for about 5 days. Took it all over CA. Up the coast, caught all the good canyons etc. Then over to Yosemite and then down Kings Canyon, Sequoia National and finally the Mojave before catching Angeles Forest into LA.
The bike is SO stinkin' zippy!!! Very fun to ride. After reviewing the video we shot, I can see how much quicker my WC was pulling away after turns from an older (2005) GS. My usual ride at home in Dallas is an '11 Triple Black GS.
https://www.youtube.com/watch?featur...&v=WegY-QfdoAA
The only complaint(s) (very small) was the clutch seemed to have very little actual range of engage/disengage. I got used to it. And the biggest prob was my left boot/lower leg got cooked. Not all the time. Really puzzling. I figured, on the new design there is a lot of exhaust pipe near the feet, looks like more than on the previous engine design. And of course the radiators, but they are higher up. Dont know why this was happening, but another rider confirmed it when we switched bikes.
Otherwise very fun ride. Felt like a GS, just more zip, but still liked to play in 3rd gear on Angeles Crest Highway. Very little shifting required!!
kjazz is offline   Reply With Quote
Old 10-07-2013, 12:37 AM   #10918
Random-Water
Oddometer: 149
When key is first on, but engine is not running, it goes to 100% for about 10 seconds then dims over about 3-4 seconds to about 30% brightness. Once the engine is running and the low beam kicks on, it goes to about 50% brightness. The Percentages are 100% guesses...I don't have a light/lumen meter.
Old 10-07-2013, 09:43 AM   #10919
RichBMW
RichBMW's Avatar
Oddometer: 2,111
I took the luggage rack off today....
What's the verdict then folks?
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 10-07-2013, 10:02 AM   #10920
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Thanks for coming back about this. Seems the welcome lights are the only condition where the DRL runs at full intensity on the US/DOT models.
Times are GMT -7.   It's 05:43 PM.
