Old 10-19-2013, 11:39 AM   #11011
Desert John
Desert John
Oddometer: 206
Thanks, NLS, for the Dynamic information. And, no, I do not have the Enduro Plug installed.
But don't I want to be in Dynamic/Road/Normal for standard street and most mountain riding?
The manual is not very clear on all this.
Oh, I really, truly, got 249 miles on one tank of gas two weeks ago in Colorado from Pagosa Springs to Moab, UT via Naturita. It was amazing especially since the next day my run from Moab to Cedar City via US 70 and US 15 garnered a mere 207 with 30 miles left on the remaining countdown.
'15 R1200GS LC , '14 Harley-Davidson FLHTK, '14 Aprilia Tuono V4
Desert John is offline   Reply With Quote
Old 10-19-2013, 12:50 PM   #11012
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,612
Dynamic and Road are two separate running modes. Normal is an ESA setting. My preference is for Road/Normal around town and on the freeways. I switch to Dynamic/Hard for the fun twisties on good pavement. I may use Dynamic/Normal if the pavement isn't so good. On some of the barely maintained county roads that are more patches than road I'll switch to Enduro/Soft. I'll also switch to Soft when in Road mode on some of the more pothole than road surface roads.
That's what I do. You may want to do something different. Play with the modes and find out what works for you. I will say that on a good road surface Dynamic/Hard is great! As others have said.... if you want the bike to remember your ESA setting for particular riding modes then install the Enduro Pro plug.
marchyman is offline   Reply With Quote
Old 10-19-2013, 01:41 PM   #11013
atwoodtja
Oddometer: 437
Originally Posted by steelerider View Post
Hmm. A small locating tab on my LED headlight was broken off when I crashed (deer strike) on my bike. The result? Can't be fixed, new headlight module for $1236.00 from Germany plus 2-3 weeks to get the part. I'm talking about a piece of plastic no bigger than 1cm high, and about the width of 3 toothpicks.
Is the broken tab the only damage, or is the lens also broken? If the tab is the only damage, make sure to keep the old one. If you don't think you can figure a way to fix it I'm sure someone will want to buy either the whole thing or just the lens. Usually you can jury-rig a fix with safety wire and thermoplastic.
FWIW, aside from the replacement cost, I'm pretty happy with the LED. Once you adjust it properly so the cutoff is just below horizontal, low beam is very good, and the high beam is stupendous.
2013 BMW R1200GS-LC
2008 Suzuki DRZ400
atwoodtja is offline   Reply With Quote
Old 10-19-2013, 04:06 PM   #11014
cvan810
cvan
Oddometer: 10
New R 1200 GS
Got it in July from Riverside BMW. The bike is amazing. I bought it to commute and adventure ride. It's amazing off-road and it performs as billed! The photo is above Lake Elisnore
cvan810 is offline   Reply With Quote
Old 10-19-2013, 05:21 PM   #11015
smithdt
Oddometer: 83
Without knowing what the tab looks like, this info could be totally useless to you...but I'll proceed anyway...
If you can make your own tab somehow, you could maybe use a product called "rapidfix" to attached back on the LED casing.
This link is to an Australian utube vid, but It's available from ebay sites as well. I've got some on order, so have not used it yet... but it looks like the go,
http://www.youtube.com/watch?v=bSmgEkbp5eM
good luck and if you try this let us know how it went.
cheers
smithdt is offline   Reply With Quote
Old 10-19-2013, 07:42 PM   #11016
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,503
Wicked Great pic!
I need to quit coming here... this bike will cost me money! I must resist!
[/QUOTE]
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 10-19-2013, 08:09 PM   #11017
iride4u
iride4u's Avatar
Oddometer: 321
At this point I would be thinking of drilling a hole and fabricating a new part. With the adhesives that are currently available you may be able to do a repair. When I said that the headlight could be repaired I was thinking about a rock strike on the lens.
2013 R1200GS LC red
2012 K1600GTL blue
iride4u is offline   Reply With Quote
Old 10-19-2013, 08:14 PM   #11018
iride4u
iride4u's Avatar
Oddometer: 321
Originally Posted by cug View Post
That'll be interesting. I have my 2014 only for 200 miles so far and I'm averaging 49 mpg. Not taking it slow, but my riding style is to not brake hard and to not accelerate hard and to generally shift early.
We'll see how this works out over time, but I'm very happy with where it is right now, lower than my Tiger 800 when I just got it.
As you break in your new bike your MPG will decrease but your fun per mile will increase.
Enjoy your new bike. I also came from a Triumph Tiger XC.
2013 R1200GS LC red
2012 K1600GTL blue
Old 10-20-2013, 07:56 AM   #11019
MIBavarian
Dude idonno...
MIBavarian's Avatar
Oddometer: 19
Talking
So I have been riding primarily in "Road" mode with ESA at normal. Feels good for every day riding. Bike is responsive, comfortable, predictable and fun...
This morning I just did a short jaunt in "Dynamic" mode with ESA at Hard (Default) and Holy Shit!
Throttle response is RIGHT NOW, not a millisecond from now - RIGHT NOW. Roads were damp with patches of dry from last nights rain, traction control rocked it. Definitely not going to hit 40MPGs in Dynamic mode...
I can see having a blast in this mode when conditions are optimal. It will take my brain a bit to adjust to the sensitivity of the throttle however. It really is like ridding two different bikes. After riding in one mode for a while muscle memory helps you determine throttle input on corners, tight maneuvers and the like. What you expect for throttle response determines body position at the moment you twist... Change modes, change everything.
Just a little ha ha for your amusement and illustration of what I have written above... Earlier this week I was pulling out of my garage, bike was in "Rain" mode with ESA at Soft from the night before. As I mentioned I am acclimatized to "Road"... So anyway, I start the bike up, drop into first and recognize I need to maneuver between a car parked in the driveway and side of my garage door. I roll forward, stand on the pegs ready to thread the needle, realize I need to give her a little gas to tighten up my balance and... My normal twist in "Road" was not what I got in "Rain"... Balance goes, bikes lists, plop... TG for the Touratech bars...
So, suffice it to say that the difference between Dynamic and Road is inversely proportional to the difference between Road and Rain.
First week of November I am headed to SC for BMW off-road training, I will be interested to learn the effects of "Enduro Pro" more fully... If I learn anything exciting (and I am thinking I will) I will report...
Have a great ride!
MIBavarian is offline   Reply With Quote
Old 10-20-2013, 08:26 AM   #11020
deacon51
deacon51's Avatar
Oddometer: 398
How do I stop that stupid yellow triangle from blinking when I lift the front wheel?
deacon51 is offline   Reply With Quote
Old 10-20-2013, 08:28 AM   #11021
MIBavarian
Dude idonno...
MIBavarian's Avatar
Oddometer: 19
AFAIK you can't.
Old 10-20-2013, 09:47 AM   #11022
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,187
Disable ASC?
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 10-20-2013, 09:49 AM   #11023
NLS
NLS's Avatar
Oddometer: 3,187
How come realOEM doesn't yet have the update with the front stabilizer?
(also doesn't have the Adventure yet, but that is normal I guess)
Can someone with a 2014 GS give us his serial? I want to see how realOEM reads it.
(or you check yourself)
NLS
My Blog
Old 10-23-2013, 02:38 PM   #11024
Cap0ne
Lex Talionis
Cap0ne's Avatar
Oddometer: 193
Does anybody know how dark the original tinted windscreen is ?
I would buy one if i knew for sure it is light tinted (like this one ) but i'm afraid it will be much too dark.
Everyone should have something in their life that requires a helmet
Cap0ne is offline   Reply With Quote
Old 10-23-2013, 03:21 PM   #11025
iride4u
iride4u's Avatar
Oddometer: 321
Here is a picture of mine in the sun.
2013 R1200GS LC red
2012 K1600GTL blue
Times are GMT -7.   It's 12:59 PM.
