01-02-2012, 08:32 PM
#1171 |
Oddometer: 16
01-02-2012, 09:34 PM
#1172 |
Hoinar
Oddometer: 232
I am afraid that "S" would be for Straße.
01-02-2012, 10:24 PM
#1173 |
Smile 4 Miles
Oddometer: 1,375
Who can read this?
... Cooled ? ![]() Source: Motorrad |
01-03-2012, 12:23 AM
#1174 |
Oddometer: 470
01-03-2012, 12:27 AM
#1175 |
Tuscan rider
So we'll have the Street model (which is now called the R-model), the GS and the GSA.
Then, maybe, the GS will be "downgraded" to an even more street-oriented design than today. Leaving the GSA where my 2000 R1150GS is. [TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here. Renting out motorbikes in Toscana, Italy Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index. IBA: 33616 |
01-03-2012, 12:48 AM
#1176 |
Oddometer: 333
1250 water cooled
I am looking at some of the pictures posted and I do not like what I see. Transmission gears and engine in the same case!! Bad!!. Engine block is now a throw away block. Cylinders are now cast as part of the block? No worry about having to rebuild the engine when it needs it. Just throw the block away and restart with new. I am old school and will take the older model engine that can be rebuilt and has the clutch and transmission separate. When all cars and trucks out on the highway and farm machinery etc. go to integral transmissions with wet clutches with belt drives etc. maybe I will rethink the above statement. Sounds like BMW has went cheap!. Of coarse it will cost much more and can't be worked on easily by the owner. Looks like BMW has everyone excited over the new boxer engine and such. All the while giving us something much cheaper to build while costing more. They have changed the design to sell more bikes and less parts in the future. Just doesn't appear that BMW cares about longevity. It won't be long before the boxer is gone for good. They have taken everything away that made BMW.
01-03-2012, 02:29 AM
#1177 |
Syndicated
Oddometer: 11,285
I think someone mentioned throttle-by-wire earlier on. The box on the backside of the throttle body might be a throttle servo.
01-03-2012, 03:05 AM
#1178 |
Oddometer: 82
01-03-2012, 04:58 AM
#1179 | |
me specie in dea ist
Oddometer: 499
Total BS
Its all wrong in fact this design is for a more longtivity of the engine and faster repair if the cylinders blow. The oil for the engine an gears are as one. In real life it works like this with oil change. you can drain the bike from the oil filter to leave the oil in there for the gears. Or you can drain it from below and take out all the oil engine and gears. The gears are the main drive system of any bike and with this its always in lube. This is top engineering. Gears are the heart of every motor with good gears you get high milage and many do not keep there oil level up in specs and it becomes a stress factor on the motor. This is now gone with the high tec motor. The Motor If you make the Cylinder walls as good as BMW has done to this day the Piston rings should not need to be replaced until ??? 250.000km. McFury.
So Close Yet So Far. ![]() ![]() ![]() McFury sending and spreeding out gas fumes inn Islandic Highlands. What´s you gonna do when they come for you. ![]() ![]() ![]() ![]() Whats next ? Man walking on the moon ?. All typing is done with One Finger using a MacPro Computer. McFuryMcNugget screwed with this post 01-03-2012 at 05:15 AM |
01-03-2012, 05:32 AM
#1180 |
Oddometer: 60
So there should be only one wet head thread? Should we start having only one cam head thread or 1200GS thread?
01-03-2012, 05:39 AM
#1181 |
I have little to say
Along with water cooling, why not go hydraulic lifters. This would all but eliminate having to go into the head for service. While you're at it, why not go with spark gap ionization for the anti-knock sensing. Oh, and get rid of the silly dual plug design and the COP design....water cooling could make the boxer a much simpler engine.
01-03-2012, 05:52 AM
#1182 | |
Hooked Up and Hard Over
Oddometer: 7,435
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
01-03-2012, 06:09 AM
#1183 | |
wanderer
Oddometer: 417
I do not like the statement the engine is mounted more forward in the chase for more weight on the front wheel. This design is proper for street sport bikes/race bikes...is wrong for dirt bikes (remember keep the front light over gravel, etc). It clearly indicates that BMW is following the market and the real use of the GSA as a better big street bike. If so lower the height so tip toes are not needed, help the C of G,etc etc. |
01-03-2012, 06:10 AM
#1184 |
There are plenty of models in the BMW lineup to keep dealers busy.
01-03-2012, 06:35 AM
#1185 | |
Grumpy Old Goat
Oddometer: 4,336
I found Jesus. He was behind the sofa the whole time. 1996 M900, "Patience" 2012 GS "Sonar" 2008 Megamoto "Big Blue" 2008 S2R "WTF" |
