Old 01-03-2012, 07:42 PM   #1216
flightestman
Oddometer: 178
IT appears that your guys are all wrong
Well it appears that the emissions standard was met by the air/oil whoever said that it met the emissions already was the only guy to say it, everybody on else was saying it has to change including highly esteemed magazines like motorcycle magazine, one said sure rain is wet that it be this coming summer in 2012 and went on to say every little detail including exact hp and how the engine would be cooled beyond the water jacket, they sounded like the knew exactly what they were talking about like it came right from BMW but it turns out none of them were close BMW plans to keep this new DOHC for a little while longer to get back it investment again the dealer said the air hold will not be changed for quite some time however i don know how long quite some time would be, but i know i made the right choice buying a 2012GS this year in late fall for 2 months i was able to run hit very nice weather i found out if you dress right for it.
flightestman is offline   Reply With Quote
Old 01-03-2012, 07:42 PM   #1217
Callisto224
Callisto224's Avatar
Oddometer: 1,110
Originally Posted by tallguy-09 View Post
...at this point, these pics have made the rounds of all related forums... this one shows the legroom.
Looks like the cylinders are higher but also more forward? This should help with available legroom for tall riders, what do you think?
https://skydrive.live.com/redir.aspx...NpH0QC1Ffln9qY
Artistic rendering based on "Motorrad" 01/2012
Looks like it has plenty of legroom to me.
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 01-03-2012, 07:49 PM   #1218
OConnor
Bad juju
OConnor's Avatar
Oddometer: 3,687
That is the loooongest sentence I have seen to date.
2013 Husky TR650
2008 GSX1250N
1990 HD Ultra Classic
2000 SV650 track bike
1971 CB175 vintage racer inabox
OConnor is offline   Reply With Quote
Old 01-03-2012, 07:51 PM   #1219
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
No more banging my shins on the cylinders (intake), with 6'7" I'm definitely appreciating this
tallguy-09 is offline   Reply With Quote
Old 01-03-2012, 09:49 PM   #1220
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Who can read this?
... Cooled ?
Liquid
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 01-04-2012, 01:03 AM   #1221
NZRalphy
NZRalphy's Avatar
Oddometer: 249
Originally Posted by rritterson View Post
My biggest complaint with the current bike? The front end is twitchy, on road and off. I went over a botts dot yesterday and got a whole bunch of headshake. None of the changes we've seen seem to address that problem.
Never (never ever!) happens to me. Yesterday I was trail riding in gravel and took my hands off for a laugh loads of times and got no head shake. I'm picking you have a suspension or steering fault that needs fixing.
For others that say the GS is a great road bike... You are right.... but, it is also a GREAT off road bike.... and BMW needs to carry it over to the new bike.
NZRalphy is offline   Reply With Quote
Old 01-04-2012, 03:09 AM   #1222
KSBEERHUNTER
Oddometer: 353
Originally Posted by McFuryMcNugget View Post
I dont agree with this statement.
Its all wrong in fact this design is for a more longtivity of the engine and faster repair if the cylinders blow.
The oil for the engine an gears are as one.
In real life it works like this with oil change.
you can drain the bike from the oil filter to leave the oil in there for the gears.
Or you can drain it from below and take out all the oil engine and gears.
The gears are the main drive system of any bike and with this its always in lube.
This is top engineering.
Gears are the heart of every motor with good gears you get high milage and many do not keep there oil level up in specs
and it becomes a stress factor on the motor. This is now gone with the high tec motor.
The Motor
If you make the Cylinder walls as good as BMW has done to this day the Piston rings should not need to be replaced until ??? 250.000km.
McFury.
Yea right. Made for easier repairs and "if the cylinders blow" It is made for faster repairs and more longevity. It doesn't look like you can repair those cylinders at all. Just like the present boxer cylinders. You have to replace the cylinder because it can't be rebored. You buy another pair of cylinders. With the new engine it looks like you can't even replace them because they are cast in as part of the block. As far as the statement that "this all wrong" I think you have no mechanical background or experience with rebuilding engines and wouldn't recognize a good design from a poor one. Especially BMW engines. If you think that putting the transmission in the same block as the engine so you can "take out all the oil engine and gears" is good for longevity then power too you. Run right out and buy one. I will keep my rebuildable 1150 gs with 155,000 miles on it. It has never had the heads off and when it comes time that I need to rebuild I can! I am not one that trades a bike off every time a new model comes out in a different color. Like I said before, when Cat, Cummins, GM, Ford decide that their engines will last longer with the transmission and engine sharing the same block and oil I will rethink my logic. As for now I still believe in what has worked in the past. I am one of those BMW guys that think my old air head was the most reliable and easiest to service and longest lasting bikes I have owned. I hurt every time I think about selling it.
KSBEERHUNTER is offline   Reply With Quote
Old 01-04-2012, 03:53 AM   #1223
DrunkWombat
GS and Proud
DrunkWombat's Avatar
Oddometer: 2,262
Well Jap bikes have had nikasil bores for nearly 2 decades now. They last forever and are repairable. I think a lot of the water cooled paranoia is unjustified. If evolution and improvement were so evil we would still be riding horses.
Scenery: That blurry stuff on the side of the road.
DrunkWombat is offline   Reply With Quote
Old 01-04-2012, 03:57 AM   #1224
pmelby
Home Brew Adventurer
Oddometer: 727
....I will keep my rebuildable 1150 gs with 155,000 miles on it. It has never had the heads off and when it comes time that I need to rebuild I can! I am not one that trades a bike off every time a new model comes out in a different color. Like I said before, when Cat, Cummins, GM, Ford decide that their engines will last longer with the transmission and engine sharing the same block and oil I will rethink my logic.....
Did you enjoy splitting your 1150 in half to replace the clutch?
I can think of at least three good reasons to ditch the dry clutch:
1. More robust, able to operate in the friction zone, without fear of damage
2. No worry about a rear main seal leak destroying the clutch
3. Better access to the slave cylinder (will probably be external)
Cons also come to mind:
1. Engine and clutch/tranny using the same oil
The new boxer motor design is clearly a response to the challenges presented by the competitors, Ducati, KTM, Triumph, Yamaha, etc.
I also think that the oilhead, hexhead, camhead motors and bikes were and are still great machines. There is no reason that the new generation boxer won't be good as well.
cheers,
melby
Melby
'14 1190 ADV
'09 G450X
'85 K100RT
pmelby is offline   Reply With Quote
Old 01-04-2012, 03:59 AM   #1225
cardoctor1
cardoctor1's Avatar
Oddometer: 541
linky for the watercooled hd engine
http://www.cyrilhuzeblog.com/2011/06...-heads-patent/
IBA#35592
RIDE EVERY RIDE LIKE ITS YOUR LAST
00 R1150GS
cardoctor1 is offline   Reply With Quote
Old 01-04-2012, 04:09 AM   #1226
McFuryMcNugget
me specie in dea ist
McFuryMcNugget's Avatar
Oddometer: 499
Crome wall.
Crome Steel all the way.
If you look at the market spectrum you will soon find out that the old engines are T-Rex creatures ,Gas eating and Fart puffing , Outdated engines.When gas was cheaper then Pepsi.
Climb up to smell the roses. To get better gas milage you need a crome cylinder,Its true they cant be bored out as the old T-Rex cylinders. You just get a new one as well as pistons.
But most just need the pistons since the crome walls on these babys are strong.
The US was a leader in big engines and muscle cars true back in the day. NOT NOW.
I notice you name CAT Cummins Industrial producers of Diesel engines. And only 1 automaker FORD.
Well i have a old Ford with a 302 Cid engine trusted Van and hold up well but a real gas guzzler.
When the engine is running and i have to attach my trailer to the Van i weap over the flow of gas running out my exhaust pipe.And its in top condition.
http://en.wikipedia.org/wiki/Rudolf_Diesel
All new diesel engines do not offer a bore out option.And if you think a integrated or seperate gears box has anything to do with engine Life your wrong.
A gear box is the hearth of the engine.
Engine makes combustion power , Gears take that power thru the gears.
To bore out a cylinder block is totaly outdated and obselite thinking bare in mind in a old fuck as well.
To have Crome cylinder for the Piston is like having a tight wrap around all the time
Happy New Year Baby.
McFury
So Close Yet So Far.
McFury sending and spreeding out gas fumes inn Islandic Highlands.
What´s you gonna do when they come for you.
Whats next ? Man walking on the moon ?.
All typing is done with One Finger using a MacPro Computer.
McFuryMcNugget screwed with this post 01-04-2012 at 04:38 AM
McFuryMcNugget is offline   Reply With Quote
Old 01-04-2012, 05:46 AM   #1227
GB
Mod Squad
GB's Avatar
Oddometer: 56,717
The naysayers appear whenever a new model appears.. and you gotta laugh when you read such thoughts when there's very little known about the new liquid cooled engine. Nothing official has been released, but hey, that's what makes these forums "interesting". Everyone's an expert on the interwebs. Honda's GL1800 Goldwings have no separate engine and transmission oils and I've seen bikes with 200, 300 and even 400,000 miles..
Old 01-04-2012, 05:53 AM   #1228
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Speculation is all we have, and some gravitate towards the negative, and some positive. Since we know virtually nothing about this mythical new wethead, we just make stuff up. Also, there are always those who hate change, those who live for change, and those who bitch about both change and a lack of change.
Welcome to the wonderful world of the BMW Motorcycle!
Old 01-04-2012, 09:17 AM   #1229
rritterson
Oddometer: 207
Same complaint was lodged against the GS in the recent cycle world comparison.
rritterson is offline   Reply With Quote
Old 01-04-2012, 10:02 AM   #1230
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
If it is twitchy to you it is probably set up wrong. A few who come from conventional forks never adjust to the telelever. Apparently they just can't figure out how to set it up and ride the way it is designed.
Jim
Times are GMT -7.   It's 02:13 AM.
