Old 02-23-2011, 05:38 PM   #76
Süsser Tod
Süsser Tod's Avatar
Oddometer: 566
Originally Posted by PeteN95 View Post
600s and 750s are the same, it depends on the year. '04/'05 have 300mm discs and '06/'07 have 310mm same as SV. Here is a chart with some good info:
I was pretty close, K7/K8 GSX-R 750 has 310mm rotors
I remember that it was possible to come up with a combo that would let you use the stock SV wheel, with stock SV rotors, GSX-R forks, calipers without spacers, both triple trees and retain the ignition lock.
But I can't remember what it was...
Süsser Tod is offline   Reply With Quote
Old 02-25-2011, 02:42 PM   #77
PeteN95
PeteN95's Avatar
Oddometer: 1,688
'07 GSXR 600/750 forks don't need caliper spacer and '05 GSXR 600/750 triples fits stock ignition and stem bearings. Any radial calipers will work.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/Christini
PeteN95 is offline   Reply With Quote
Old 02-26-2011, 06:24 AM   #78
Süsser Tod
Süsser Tod's Avatar
Oddometer: 566
05 needs the upper triple tree bored, right? I know of several places in Mexico City that could do that... But I don't think a single one of them could do it right.
Old 03-03-2011, 06:48 PM   #79
williefast
williefast's Avatar
Oddometer: 421
Here's my 07. 39,000 miles and counting, all pimped out.
williefast is offline   Reply With Quote
Old 03-03-2011, 08:02 PM   #80
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,431
Mine on a trip to Vashon Island WA
In touring mode....everything is wonderful except the seat....even with the airhawk on there it is still only a 200 mile per day bike. Much prefer my Ninja 250 or 500 for the long distance stuff.
Jimmy the Heater is online now   Reply With Quote
Old 03-03-2011, 09:09 PM   #81
fly2low
Oddometer: 114
Williefast:
The 3rd/last picture: is it Badlands? I so wanna go there!
fly2low is offline   Reply With Quote
Old 03-04-2011, 06:57 AM   #82
williefast
williefast's Avatar
Oddometer: 421
Yup thats the badlands.
Old 03-04-2011, 07:55 AM   #83
arshishb
arshishb's Avatar
Oddometer: 734
Send a message via MSN to arshishb Send a message via Yahoo to arshishb
That 2 into 1 can must be LOUD! How often do you have to replace the packing?
arshishb is online now   Reply With Quote
Old 03-04-2011, 09:33 AM   #84
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 7,925
Send a message via AIM to eatpasta
if anyone is interested, im actually selling mine....
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
Originally Posted by Burnszilla
I was SO high, I could have hunted duck with a rake
Originally Posted by VxZeroKnots View Post
MX stuff isn't my cup of tea, but falling down the side of a mountain is
eatpasta is online now   Reply With Quote
Old 03-04-2011, 02:38 PM   #85
PeteN95
PeteN95's Avatar
Oddometer: 1,688
No, the '04-05 bolts right on, I did it! I think the '06-07 needs to be bored out?
SVN/XRR/Christini
Old 03-04-2011, 11:59 PM   #86
Süsser Tod
Süsser Tod's Avatar
Oddometer: 566
OK, I figured out why nothing I say seems to make sense.
04-05 front end "almost" bolts in, just needs caliper spacers, retains steering lock.
06-07 front end bolts in, but you lose the steering lock.
06-07 front end with 04-05 top triple clamp allows you to keep the steering lock and doesn't need spacers for the calipers, but the top triple clamp has to be bored as the 06-07 steering stem is wider.
06-07 with 04-05 triple clamps must have the lower triple clamp shimmed, as the 06-07 forks are 1mm thinner in the lower triple, but then you don't have to bore out the top triple.
When I looked into it I was dead set on the 06-07 + 04-05 top triple.
Old 03-05-2011, 05:52 AM   #87
williefast
williefast's Avatar
Oddometer: 421
Its not too loud. I've never repacked it.
Susser: wow you did a lot of research. I picked up my 05 front forks/lower triple on craigslist. Bolted right on with the top triple I had in the garage off of my 03 1000. Calipers spaced with washers. No problems for the 30000 miles I've had it. Looking for a gsxr wheel to rid the spacers someday. Any t-clamp boring sounds like a bad idea to me.
Jimmy the Heater: 200 mile day?? This is easily done before lunch for me. Throw away that gel seat or somethin. I like to ride mine in rallys.
Old 03-05-2011, 07:28 AM   #88
Speedo66
Oddometer: 4,591
You must truly have an "iron" butt. Worst seat I've ever had on any motorcycle.
'01 Kawasaki W650
'05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 03-07-2011, 09:00 PM   #89
MGonzo
MGonzo's Avatar
Oddometer: 1
Purchased a 2007 SV1000S about two months ago. I was originally looking to buy a 650 but I happened upon a deal I couldn't pass up so I went with the 1000. It's not the most comfortable bike, but the Convertibars help a lot.
MGonzo is offline   Reply With Quote
Old 03-08-2011, 02:32 PM   #90
scott26
Oddometer: 4
Here
2005 SV1000S
-Racetech Springs
-Redline Fork Oil
-GSXR Rear Shock
-Techspec Tank Pads
-Amsoil
-K&N
-Puig Screen
-Custom Built REAL Frame Sliders
-Black Lowers
Just got done making a custom trunk rack for it with a Sears top case... at the powder coater now.
scott26 is offline   Reply With Quote
Times are GMT -7.   It's 04:24 PM.
