Old 08-16-2013, 09:31 AM   #1501
kubiak
Oddometer: 4,829
nice bead breaker!
Old 08-16-2013, 10:09 AM   #1502
atctim
Big Red Pig Farmer
atctim's Avatar
Oddometer: 17
Why yes, yes they are Jason Hall triples!
atctim is offline   Reply With Quote
Old 08-16-2013, 10:27 AM   #1503
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
Originally Posted by epix1718 View Post
damn!!! that is cool! Any videos of it in action?
Wow
Old 08-16-2013, 05:55 PM   #1504
Mr. BigWheel OP
b00b
Mr. BigWheel's Avatar
Oddometer: 749
I have a set of those that I'm working on. I'm sure you can only imagine my intentions for them.
That is an extremely sweet set up. I am totally jealous.
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 08-16-2013, 06:18 PM   #1505
DirtHog350
BigWheeler
DirtHog350's Avatar
Oddometer: 18
Ok now I get to be a n00b in the conversation. What is so great about Jason Hall triples?
Sent from the AMAZBALLS Galaxy Note 2
Busted Knuckles, Battered Knees but still Banging Berms and Breakin Trail... BigWheel Style
DirtHog350 is offline   Reply With Quote
Old 08-16-2013, 11:07 PM   #1506
Mr. BigWheel OP
b00b
Oddometer: 749
DirtHog350,
There is nothing especially great about Jason Hall triples. They are simply big beautiful blocks of billet milled into a shape to adapt a three wheeler to an inverted fork. There are some three wheeler enthusiasts who are as rabidly into their mid-80s rides as we are into our technologically backwards bikes. The inverted fork is the Holy Grail to the modern three wheeler. Jason Hall provides the means for the dream to become reality:
He just also happens to make a set that fit the Yamaha Tri-Z. That's all...
Old 08-17-2013, 08:27 AM   #1507
BWSwamper
Oddometer: 192
More on inverted forks... please.
Mr. BigWheel,
Could you tell us more about those triple clamps? If the Tri-Z clamps fit both the 200 or 350 frames, then I'm assuming that those custom clamps will work with either as well.
(Just still thinking about that BW-XT 225/250+ idea.)
http://www.xt225.com/forums/ubbthrea...r=61613&page=1
BWSwamper screwed with this post 08-17-2013 at 11:58 AM
BWSwamper is offline   Reply With Quote
Old 08-17-2013, 08:39 AM   #1508
epix1718
epix1718's Avatar
Oddometer: 720
Ongoing progress to find why my BW200 is only giving 35psi compresion..
Well I pulled the head/cylinder this morning off the BW200, tip from a friend over the phone was to first spray carb cleaner into the intake and exhaust ports on the head and see if any comes dripping out from the valves.. well no drips out the exhaust side but a verrrrry slight weeping on the intake side. No drips, just a tiny bit of soaking thru and took a bit of time as well.
Next I removed the top piston ring from the piston, came over very easy.. with just one hand (that normal?) I placed just the top ring into the cylinder and got it lined up to measure the gap. Factory Service Manual states a standard end gap of 0.15-0.30mm with a limit of 0.6mm
Well I couldn't find my feeler gauges but had a pocket full of coins and was able to slide in US nickel which has according to the US mint a width of 1.95mm, even with the nickel there was still a bit of gap left on which I'd estimate the piston ring end gap to be near 2.3mm.. that seem very excessive?
Looking at the piston itself it looks in good condition, the cylinder wall has no gouges, the bottom 1/4 of the cylinder wall has the factory crosshatching, then the next portion is all very smooth, and finally the top tiny portion of the wall is not as smooth, guessing that is where the piston does not travel past TDC..
Next step I'm going to do is have the actual piston and cylinder wall measured at a shop to see if I just need to replace the rings or even need to bore it and replace with new piston/rings.
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 08-17-2013, 10:25 AM   #1509
DirtHog350
BigWheeler
DirtHog350's Avatar
Oddometer: 18
Thanks Mr. BigWheel for the education :)
Once I'm ready to do a full build on my bike I will add a set of those to my wishlist.
epix,
In my opinion it sounds like your top end is due for a slight over bore and over sized piston.
Check out this article.
http://www.dansmc.com/pistons.htm
Old 08-17-2013, 06:26 PM   #1510
wingnut racer
wingnut racer's Avatar
Oddometer: 110
Da Brooklyn BOMBER!
Well I took it for it's first LEGAL ride! Ok the trip to the shop was quazi legal plate on, signals on not wired and tail light w no brake light. Severasl hrs later took to the mean streets and even had a horn! Pumped up the tires to a whopping 12psi makes it more road friendly. Will post some pics tomorrow. Also some F*%KTARD trieed stealing it and my XR350 flat tracker. Found the lock cut this morning. Next investment is a camera to watch over the beasts and maybe a 12 gauge. LOL City living at it's finest.
wingnut racer is offline   Reply With Quote
Old 08-17-2013, 09:09 PM   #1511
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,311
This just popped up on the local buy & trade if anyones interested... No affiliation whatsoever.
Posting for my in laws: 3 Yamaha Big Wheels: 1988 350, electric start, front rear and rifle rack, new seat and battery, $1,750 OBO. 1987 200, electric start, new battery, rear and rifle rack, $1,500 OBO. 1990 80 2 cycle, 3 speed no clutch. Great for kids. $700 OBO. All run good. Dodge Pickup bed trailer 1/2 ton. Package deal with all 3 bikes $3,500. In Pocatello, call 237-5890.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 08-18-2013, 10:26 AM   #1512
greg24
greg24's Avatar
Oddometer: 17
update
well I don't have any pics cant find the camera I have been working on the swingarm got it setup and ready just got the last package of parts . ordered all new chains,spockets ,greased the swingarm, got new tires putting on black diamond atr radial tires
greg24
greg24 screwed with this post 08-18-2013 at 10:33 AM
greg24 is offline   Reply With Quote
Old 08-18-2013, 06:30 PM   #1513
BWSwamper
Oddometer: 192
ATR Rear
Greg24,
Earlier you posted you were going with the ATR 25x12-9 on the rear. What mounted diameter did you get for that tire? What's the swingarm clearance?
Old 08-18-2013, 09:44 PM   #1514
greg24
greg24's Avatar
Oddometer: 17
have not got it on the bike yet been working to much but i have a new duro 26-12-9 to go on the other bike and it looks about the same size
greg24
Old 08-18-2013, 09:52 PM   #1515
jaubuchon
Cheapest Boy Alive
Oddometer: 36
Thumb the mega bm
So the bigmower is back. Got a little sidetracked with the suburban and the 67 and the vista cruiser and the blaster and yz. But my custom hubs and rear end mounts are done finishing up the brakes soon. And then finally finishing the got dang wiring harness. Any ideas for it?
jaubuchon is offline   Reply With Quote
Times are GMT -7.   It's 07:07 AM.
