Old 01-02-2012, 08:37 PM   #166
Mr. BigWheel OP
b00b
Mr. BigWheel's Avatar
Oddometer: 756
This is the difference between the 25 and 22 inch tires. It also illustrates a square profile on the 22' tire that is just a little too flat for a motorcycle.
The one on the right is what CliffH will be riding on soon.
Tonight I'm trying to fit a 26x9 - 12 onto the front of the BW. I know that the world waits with baited breath for the results, so I'll keep you all posted.
Regards,
Mr. BigWheel
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 01-02-2012, 11:46 PM   #167
Cliff h
[IMG]http://i219.pho
Oddometer: 261
Mr. Bigwheel, I am very thankfull and gratefull to have to opportunity to use your tires. You have done much to promote, educate and entertain many people about the Yamaha Big Wheel. I thank you for your valiant efforts!
Cliff h is offline   Reply With Quote
Old 01-03-2012, 01:34 PM   #168
bouldertag
WannabenarlyADV'rrrr
bouldertag's Avatar
Oddometer: 460
Regards,
Mr. BigWheel
Holy solidified water destroyer Batman!!
Burn out dont fade away!!
bouldertag is offline   Reply With Quote
Old 01-03-2012, 02:17 PM   #169
LDL
Oddometer: 71
About that Tire
Hey there Mr.Big Wheel , what is the name brand on that 25 " tire ?
LDL is offline   Reply With Quote
Old 01-03-2012, 07:12 PM   #170
Shercoman
Oddometer: 457
Both look great.
What are the brands and exact sizes for both of those?
I have considered the possibility of making an adaptor to allow the use of standard,offset ATV wheels on the BW.
If this would open up the tire choices, I will pursue the idea.
If anyone would be interested,let me know. I could design using modern size,aluminum rims.
Back in the 80's I built a BW using a Yamaha TT500 motorcycle. I used the biggest tire I could find at the time,called a "Spider Track".
I fabricated the entire swing arm,triple clamps,both wheel hubs and copied the jackshaft arrangement used on our BW's.
The bike was awesome.
I have some pictures of it somewhere.I wish I could find them.
Shercoman screwed with this post 01-03-2012 at 07:20 PM
Shercoman is offline   Reply With Quote
Old 01-03-2012, 07:19 PM   #171
Shercoman
Oddometer: 457
Mr. Bigwheel,
And all other BW people...
Thanks for this thread.
You are getting me interested in my BW again.
Have to start wrenching on it again!
i'm currently building a CB750 powered Suzuki Quadzilla sport quad.Had to cut the frame into four pieces to open it up enough to fit that engine.
Currently welding the frame back together.
Shercoman screwed with this post 01-03-2012 at 08:45 PM
Old 01-03-2012, 11:07 PM   #172
Mr. BigWheel OP
b00b
Oddometer: 756
The tires are:
Dirt Devil A/T 22x11 - 9
Goodyear Rawhide ATT 25x12 - 9 This is my favorite tire ever, which must be why it has been discontinued. I would desperately like to find some new ones.
The 26 inch tire installation was successful. I gave up on it after 2 days and took it to a tire shop. They spent two hours heating, freezing and beating on it. The entire staff got involved and used over a gallon of tire lube to seat the bead. When they finally got it to seat, I felt obligated to give it a trial fit and stud it up.
That one is a Goodyear Grip 26x9 - 12
Old 01-03-2012, 11:37 PM   #173
Mr. BigWheel OP
b00b
Oddometer: 756
Shercoman,
I am not the first to be utterly frustrated by the pursuit of another rear wheel that will allow the fitment of something other than a 9" tire. The lug spacing on the rear shaft is almost unique and there are only a few other Yamaha three and early four wheelers that use it. 4/125 with zero offset is apparently rare as hens teeth on a dodo bird.
Your idea about the spacer might be the best solution. And I would guess that if you could make something useful out of a TT500, then you're the right man for the job.
The BW World needs you.
Regards,
Monsieur BigWheel
Old 01-04-2012, 08:57 AM   #174
tpar1220
such a pud..
tpar1220's Avatar
Oddometer: 2,634
bigwheel... i gotta ask. whatcha gonna do if ya have a flat?
that was my concern when i was mounting an atv tire to my tw in my pics above. i actually bent my rim a lil tryin to spoon that damn thing on. figured that if i ever had a flat... i was done for. no way i would ever be able to repair it trail side.
i finally decided to take a razor knife and trim the bead slightly. i know... i know... you are not supposed to do that. but i will try to keep the tw under 150mph!
there is a metal band inside bead, i didn't mess with that at all.. i just trimmed about 1/8th off the bead and it mounted/seated normally.
although the sidiwall on the atv tire is so stiff, i could prolly ride it back home with it being flat.
this thing is AWESOME... and makes the mach V look like a vagina!
There will only be two things left moving after WW3.
Cockroaches & KLRs.
tpar1220 is offline   Reply With Quote
Old 01-04-2012, 09:02 AM   #175
tpar1220
such a pud..
tpar1220's Avatar
Oddometer: 2,634
oh, and how much air pressure did it take to finally POP! onto rim? i couldn't get mine to seat no matter how much air i put in it. i was nervous as hell... any lil noise and i dropped everything and ran for dear life!
Cockroaches & KLRs.
Old 01-04-2012, 12:09 PM   #176
Mr. BigWheel OP
b00b
Oddometer: 756
tpar1220,
When the BW200 was introduced it had tires with thinner sidewalls that would flex and rub the swingarm when flat. That tire was immediately replaced by Yamaha with one that didn't immobilize the bike when the air got on the wrong side of the rubber. Most of the tires I run have even stiffer sidewalls than the original BW tires since they have to carry the weight of those huge, portly four wheelers.
I think I could ride for a reasonable distance on a flat but I carry a plug kit and a tire pump and wear my lucky rabbits foot just in case. It's worked well so far.
The 26" tire was only difficult to seat because the beads were nearly touching one another after being flattened during shipping. I've never really been nervous seating the bead on the BW tires except when using the Redneck Bead Seating Method:
Of course the mohawk is optional, but any safety gear is apparently optional too.
Regards,
Mr. BigWheel
Old 01-04-2012, 05:57 PM   #177
Shercoman
Oddometer: 457
Shercoman,
Regards,
Monsieur BigWheel
My experience is with sport quads and the 9 inch rim is very popular. The hard part is finding a round profile tire because square is good on a sport quad.
I was going to make an adaptor for the Honda 9 inch rear rim as they are plentiful but that doesn't sound like a good idea if tires are a problem.
Since you have done more research on this,what size rim would you go to? Picking the right size (common?) rim would be best and then design an adaptor around that.
What do you suggest?
Old 01-04-2012, 07:02 PM   #178
Onederer
Crunch Nugget
Onederer's Avatar
Oddometer: 867
I have got these in 25x12x9 on my ATC and they have far more bite than they look to have. I wasn't sure how they would do in mud until last weekend when they propelled the ATC thought every hole that wasn't over waist deep, which at that point I lost traction due to floating and had to push it across. Far, far better in mud than I would have thought and they clean well enough that a whole lot of wheel spin isn't needed. I have taken them through fresh clear cuts, running over cut and broken saplings and haven't punctured them. They are radials and when running them with 2-3 psi, they ride very smooth, as smooth as a hard tai ATC gets anyway. They are stable enough that top gear slides aren't too much of a worry but the sidewalls are soft enough that side hilling the ATC with these takes a little more angle of the dangle. On a BW they might be too squishy for high speed handling, if a BW had high speed handling to start with.
Figured I'd throw out my experience with these. Look like they might work good for a BW rear. I got the XT200 engine into my BW, but that is as far as I have got before some other projects toke precedence.
I staired a whole thru the breaks until I remembered the carb prolly has a problem to and I'm gonna hafta work on em.
Onederer is offline   Reply With Quote
Old 01-04-2012, 07:09 PM   #179
Shercoman
Oddometer: 457
Those look good.What brand and model is that?
Nice and round profile.
Old 01-04-2012, 07:52 PM   #180
Happy Seal
Happy Seal's Avatar
Oddometer: 2,538
The tires are:
Same plane? We need more plane footage Mr BW! cool thread!
with his videos I've been able to crash into trees even faster than before. ( Darius re Shane Watts)
Happy Seal is offline   Reply With Quote
Times are GMT -7.   It's 11:01 PM.
