Old 01-17-2014, 07:18 PM   #2131
jgarrettg
Fleet Servant
jgarrettg's Avatar
Oddometer: 47
Originally Posted by RobDek View Post
Is it typical for the chain to be out of alignment?
The stock sprocket is dished out so the chain lines up. Looks like they put the wrong sprocket on there at some point.
DMOBill sells an adaptor to correct this. It uses Honda 400EX sprokets.
jgarrettg is offline   Reply With Quote
Old 01-17-2014, 07:52 PM   #2132
RobDek
Oddometer: 193
Thanks much for the reply!!
RobDek is offline   Reply With Quote
Old 01-17-2014, 08:17 PM   #2133
DMOBill
Oddometer: 114
Robdek,
There may be more going on than just the wrong sprocket. I can tell by the picture that the sprocket is definitely wrong. But there is still too much gap between the swingarm and the wheel. This is possibly caused by the chain adjusters being on the wrong sides. I`d like to see more pics of what`s going on with that setup. You definitely have to fix this or I`ll guarantee a chain through the case.
DMOBill is offline   Reply With Quote
Old 01-17-2014, 09:12 PM   #2134
jgarrettg
Fleet Servant
jgarrettg's Avatar
Oddometer: 47
Mr Big Wheel Was up?
Originally Posted by Mr. BigWheel View Post
Mr Big Wheel, I've been drooling over this picture for months. Are you going to have an update soon?
Old 01-18-2014, 04:35 AM   #2135
RobDek
Oddometer: 193
Originally Posted by DMOBill View Post
Robdek,
That was my first guess as well but it looks okay according to the parts diagram. I'll post a couple more pics later today.
Still trying to remove the axle. It should just slide out, right? Spins freely but moves only about inch and then notta. I let it soak with penetrating oil overnight...hope that helped!!!
Old 01-18-2014, 05:02 AM   #2136
DMOBill
Oddometer: 114
RobDek,
If you can move that axle an inch, cut it and pound it back thru. You should be able to remove the wheel then. At that point, you may have to drive the axle out one side with a wheel bearing.
Old 01-18-2014, 05:06 AM   #2137
DMOBill
Oddometer: 114
Mr. Bigwheel,
I sure hope those aren`t Honda forks.
Excellent work. On that triple clamp, are the forks moved forward over OEM to keep from hitting the tank? What diameter forks did you use?
Old 01-18-2014, 05:14 AM   #2138
RobDek
Oddometer: 193
RobDek,
That's my next plan. I was also thinking of employing a slide hammer but I'm not sure if there's an accessory that would attach to the bolt head somehow. Damn discouraging to be shutdown by a simple task!!!
Looks I'll be ordering from you in the near future. Do you also offer swing arm bushings?
Many thanks!!!
::: EDIT :::
This would be so cool to have right now!!!
http://www.toolcoonline.com
RobDek screwed with this post 01-18-2014 at 07:44 AM
Old 01-18-2014, 07:21 AM   #2139
Sparkes
Location: Glovertown NL. Currently living in Vancouver BC
Oddometer: 21
RobDek -Thanks that gives me more options to search
DomBill - Hows the tire adapter going?
Mr.bigwheel - All i have to say is NICE
Sparkes is offline   Reply With Quote
Old 01-18-2014, 09:58 AM   #2140
Mr. BigWheel OP
b00b
Mr. BigWheel's Avatar
Oddometer: 753
Progress on the project goes slowly. The bike ended up getting stripped almost to the frame. Some previous owner had good intentions when he replaced the stock skid plate with a slab of steel that was welded to the footpeg mounts and attached to the lower, forward engine mount. I found the mount broken off the case and the engine had to be scrapped.
The forks and triple clamp are now mounted on the Desert 100 BW that is in Washington.
A different engine got the new top end with a Wiseco big bore kit. Now it's going to displace 353 CCs!!!!
It is actually a higher compression piston, so now I get to run Premium gas in the BW.
The engine got hung in the frame a few days ago and I would be able to focus on the front end if there weren't other persistent problems cropping up. I guess that's to be expected when you take apart 25 year old dirt bikes.
The real reason is that I'm lazy and would rather sit around and eat BigWheels than work on them:
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 01-18-2014, 10:57 AM   #2141
jgarrettg
Fleet Servant
jgarrettg's Avatar
Oddometer: 47
Big Wheels
Yum! Those look delicious.
I like the red paint on the cylinder.
What compression ratio did you end up with?
Thanks for the update!
Old 01-18-2014, 11:58 AM   #2142
Mr. Magoo
n/a
Oddometer: 4,978
Originally Posted by Sparkes View Post
Anyone know where i can find a chain guard for my BW350?
A bw200 one works. I recently bought one from parts source.
Mr. Magoo is offline   Reply With Quote
Old 01-18-2014, 11:59 AM   #2143
RobDek
Oddometer: 193
Finally got that axle out!!! No wonder it was stuck....the axle was frozen in a steel sleeve...no way no how it would've come out peacefully.
Got the brake over and put some more heat on the situation. You can see a previous cut attempt but I couldn't get at it to finish.
Finally enough room to make a good cut.
Ahhh...the culprit finally emerges!!!
What a mess of parts!!!
Old 01-18-2014, 12:08 PM   #2144
RobDek
Oddometer: 193
Where my cookies...I deserve them!!!!
Old 01-18-2014, 05:09 PM   #2145
RobDek
Oddometer: 193
And the restoration begins in earnest...axle and chain tensioners ordered from eBay (wyldflower002) and a $300 order from Partzilla. Also waiting on DMOBill about swing arm bushings before ordering the sprocket adapter and jackshaft kit.
I tried to order some stuff from bigrus60 on eBay but he's not interested in doing business with Canadians....oh well...his loss.
Times are GMT -7.   It's 03:23 AM.
