Old 04-13-2014, 11:49 AM   #2731
Mr. BigWheel OP
b00b
Mr. BigWheel's Avatar
Oddometer: 749
Raptor 700 BW200 - really
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 04-13-2014, 11:58 AM   #2732
MntDog
Oddometer: 26
Originally Posted by dirtydeeds View Post
That's right in line with what I paid at Amazon. $30.
Except I had shipping to canada. Add another $20 for that.
Mine says Mikuni on it. It's a really good copy.
Hopefully it works as well as it looks.
That open port on the right with no hose on it in your picture, where does that go?
MntDog is offline   Reply With Quote
Old 04-13-2014, 12:10 PM   #2733
MntDog
Oddometer: 26
Can someone take a close up of a BW 200 Kick starter mounted on the engine where the shaft goes through the kickstarter?
I bought a replacement from Yamaha but it doesn't fit right. I need to see if something isn't right on this one. The splines on the shaft have a slight twist in them, I think the previous owner must have had it come loose while kicking it over. Now the new kickstarter doesn't want to stay on the shaft after a couple of kicks.Ill take some pics maybe one of you have ran into this before.
MntDog screwed with this post 04-13-2014 at 12:21 PM
Old 04-13-2014, 01:12 PM   #2734
MntDog
Oddometer: 26
This is what the splines on the shaft look like
Sent from my iPhone using Tapatalk 2
Old 04-13-2014, 01:14 PM   #2735
MntDog
Oddometer: 26
Does the luck starter on the 200's have that void in the end when mated up to the shaft?
And ideas on a fix with this other than change the shaft ?
Old 04-13-2014, 02:15 PM   #2736
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
It goes to a tee with a breather on top side and an orfice on a drain tube.
I'll see if it actually does anything...
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds screwed with this post 04-13-2014 at 04:15 PM
dirtydeeds is offline   Reply With Quote
Old 04-13-2014, 02:58 PM   #2737
whythawk
Sweet Home Alabama
Oddometer: 21
Thanks for giving me the fever !!
Hey Guys !!! I'm new to the forum, I'm from Alabama and just bought a 1986 BW200ES. I bought one in 86' when they were new and sold it a few months later due to moving. And I've often considered getting another just never did. For some reason they weren't big sellers in these parts so finding one local is almost impossible. Any chance any of you guys have some cargo racks they'd be willing to part with ? And I also need a maintenance manual. Anyway enough for now I've lurked and read all the last few years posts up til now and figured it was time to post.
whythawk is offline   Reply With Quote
Old 04-13-2014, 06:11 PM   #2738
Vintmxman
Oddometer: 4
Originally Posted by DEAVER View Post
Yeah congrats, really looks like a clean bike, how does she run?
If anyone is looking I have a real clean BW350 for sale on Pa. All stock plastics with OEM front and rear racks. Also have aftermarket pipe that was never used p,us a bunch of spares I collected over the years but never needed.
Asking 3k for the whole shooting match
PM me here if interested....
On CL next week.
Vintmxman is offline   Reply With Quote
Old 04-13-2014, 07:35 PM   #2739
MntDog
Oddometer: 26
I just figured out the Kick shaft has broke off and the previous owner ground the end down flat.
Guess im going to have to replace the shaft, fun stuff....
Old 04-13-2014, 08:07 PM   #2740
whythawk
Sweet Home Alabama
Oddometer: 21
Pm sent
Vintmxman. Pm sent
Old 04-14-2014, 03:22 PM   #2741
whythawk
Sweet Home Alabama
Oddometer: 21
Wicked Alabama BW riders
Any of you guys in Alabama interested in a BW350 ? pm me ASAP.
Old 04-14-2014, 05:56 PM   #2742
sixpepper
Oddometer: 72
Cdi's are ready
I now have 3 200 non-electric cdi's available. They are off another bike and
seem to work as good or better that the original. They seem to give more rpm's and much better throttle response. Wanted to see if anyone here
needs one, they bolt to the original location and plug in just like the originals...no splicing or rewiring needed. I would like to get feedback
from anyone that gets one on its performance..NO RISK..if you don't
like it send it back for a full refund including your shipping cost. Not
really making any cash on these due to testing cost..they are $75
plus $5 shipping..the harness is the key to this..the cdi's used can be
purchased for $30- $60...at times and new ones are under 200 I believe.
sixpepper is offline   Reply With Quote
Old 04-14-2014, 06:02 PM   #2743
whythawk
Sweet Home Alabama
Oddometer: 21
Cdi's
Six are you working on some for the electric start bw200's ?
I sent you a pm with my contact info. Give me a call sometime.
Old 04-14-2014, 06:24 PM   #2744
Raymondgene1
Oddometer: 5
bw200 carb problems
hey guys , just a little info, I had bought a mikuni carb but had trouble with it fitting because of the tubing on top, well I found a company that sells a carb that replaces the original carb. it was $35.00 from wincycles.com in florida. when I opened the box I was disappointed to find the exact same tubing on the top of the carb but then ,in the bottom of the box was another cap with the bent tubing just like the original, yep! that's right . the carb came with two screw on caps with different angular tubing. just wanted to let yall know for any of yall having clearance issues. I will be installing carb tomorrow and will give updates later
Raymondgene1 is offline   Reply With Quote
Old 04-14-2014, 06:42 PM   #2745
sixpepper
Oddometer: 72
electric start cdi's
Yes, that is my next project...I was in the Army down there in LA...back in the 70's...what city are u in..
Times are GMT -7.   It's 10:21 AM.
