Old 05-05-2014, 05:03 PM   #2851
RobDek
Oddometer: 202
You bet!!!
2014 V-Strom 1000, 2011 Ural Gear-Up, 1985 Honda Odyssey FL350R
RobDek is offline   Reply With Quote
Old 05-05-2014, 05:28 PM   #2852
heli-mech
Oddometer: 132
Originally Posted by RobDek View Post
You bet!!!
Haha! Thats awesome .... well worth the drive then!
heli-mech is offline   Reply With Quote
Old 05-05-2014, 07:34 PM   #2853
mikesova
mikesova's Avatar
Oddometer: 1,970
Hey guys, I've got an opportunity to purchase a Bw200. It looks to be in decent shape with a cycle rack. The bad: the current owner says the bottom end is "siezed up". I asked him to elaborate and he said that the "gears for the crank are all screwed up" and "the bottom end gears need to be replaced". I asked if he's had it apart and he said "Nope, but you can feel it through the kicker."
So, what do you guys think it's worth and how much do you suspect it would cost in order to get it repaired? I've done a little research and didn't come up with much, but is there any other more common engines that are a direct swap into this bike?
Thanks for any help. :)
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 05-06-2014, 03:49 AM   #2854
RobDek
Oddometer: 202
$250-300
It's worth more in parts.
Old 05-06-2014, 05:15 AM   #2855
Röhrich
big wheel freak
Röhrich's Avatar
Oddometer: 195
Your TW200 engine will fit.
Röhrich is offline   Reply With Quote
Old 05-06-2014, 06:42 AM   #2856
jpswift1
jpswift1's Avatar
Oddometer: 46
I have a complete running BW200 engine that's ready to bolt in if you pick this one up. Also a TW200 engine will work, as previously mentioned. So will a Yamaha TTR225.
jpswift1 is offline   Reply With Quote
Old 05-06-2014, 06:45 AM   #2857
jpswift1
jpswift1's Avatar
Oddometer: 46
Originally Posted by RedMan66 View Post
Hey Yupper,,
Is the front Rim the same on the Tri Z as that as the BW ? And another option, do the ATC 250R forks fit the BW triple tree?
Regards
I actually have 1986 Honda ATC250R forks, triple tree, front wheel, brake, and hub on my 1985 BW200. It's a HUGE improvement over the stock BW forks and drum brake setup.
And by the way, just in case anybody is considering buying DMOBill's new eccentric swingarm adjuster kit, DO IT! I got mine and it is top quality and MUCH better than the factory Yamaha design. Thanks a million, Bill!
Old 05-06-2014, 06:46 AM   #2858
BWSwamper
Oddometer: 196
Tw200
Lads,
The BW200 uses a jackshaft setup whereas the TW200 uses a longer countershaft setup. That means the XT225 and TTR225 engines are direct bolt-ins, but the TW200 would need a bit of modification. Compare the parts drawings for the two transmissions.
BWSwamper screwed with this post 05-06-2014 at 07:14 AM
BWSwamper is offline   Reply With Quote
Old 05-06-2014, 01:30 PM   #2859
yupper
Oddometer: 40
Hey Yupper,,
Regards
The 250R forks are 37mm and the BW350 forks are 33mm, so the stock BW triple trees would need to be bored out to accommodate the 250Rs.
I can't comment on the Tri-Z/BW wheel compatibility, but I think I remember reading they are compatible in an earlier post.
Can others share on the Tri-Z/BW wheel factoid?
yupper is offline   Reply With Quote
Old 05-06-2014, 01:58 PM   #2860
RobDek
Oddometer: 202
What a mess!!!
But found a treasure I needed!!!
I wonder what those extra doohickeys were used for?
Old 05-06-2014, 02:34 PM   #2861
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,779
I think there are a few people looking for air box pieces. If you're getting rid of stuff, I'm sure one of the members here would take them.
What did I miss?
What are you going to use the swing arm for?
Building something interesting?
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 05-06-2014, 02:53 PM   #2862
RobDek
Oddometer: 202
Ah yes...the airbox too I'm keeping. The one I have, the plastic stud is broken off and tabs on top are gone. Too bad it's such a miserable job reinstalling them!!! My existing swing arm is bent or crooked...I have to squeeze them together to install the axle and even then I can only tighten the nut so much.
Old 05-06-2014, 04:39 PM   #2863
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,779
That's odd. I remember you writing about that now.
With pipe, when we need it to bring it a certain way, an oxy-ace torch with a rosebud tip can be really handy. Just heat up an area in the shape of a diamond. It'll come that way a bit.
If you did that on the indide of both sides of the swing arm, you may solve your problem.
Old 05-06-2014, 06:26 PM   #2864
mikesova
mikesova's Avatar
Oddometer: 1,970
PM'ed.
2005 Yamaha FZ6
2009 Honda Ruckus
Old 05-06-2014, 07:08 PM   #2865
BWSwamper
Oddometer: 196
Forks...
Redman66,
The Tri-z triple is a bolt on to the BW frame, but has a greater rake. The rake is more extreme with the 86 Tri-Z triple and forks than the 85.
The BW triples can be bored out to accept the 85 Tri-Z fork tubes. But the larger diameter 86 Tri-Z tubes would require too much material be bored out of the BW triples.
"HRE" has done a lot of these bore out jobs and doesn't overcharge.
The 85 Tri-Z tubes are 35 mm. 39mm is too much. Not sure about 37 mm. Mike at HRE will know.
Here is a link to HRE. They do a lot of three and four wheelers, but are familiar with Big Wheels and the various front end mods.
http://www.hreatv.com/index.html
And on the front wheel, same rim, different hub.
BWSwamper screwed with this post 05-06-2014 at 07:24 PM
Times are GMT -7.   It's 12:19 AM.
