Old 05-07-2014, 05:08 AM   #2866
RobDek
Oddometer: 202
The holy grail of the BW350...
Of course, after I took the pic, dropped it!!! Cracks add character, right? Damn, they're so fragile with age and sun exposure.
But, there must be a way to cast a small number of these for low cost even if they're a solid amber colour and not translucent.
2014 V-Strom 1000, 2011 Ural Gear-Up, 1985 Honda Odyssey FL350R
RobDek is offline   Reply With Quote
Old 05-07-2014, 05:43 AM   #2867
jpswift1
jpswift1's Avatar
Oddometer: 46
Originally Posted by yupper View Post
The 250R forks are 37mm and the BW350 forks are 33mm, so the stock BW triple trees would need to be bored out to accommodate the 250Rs.
You're right. That's why the stock ATC250R forks were used with the stock ATC250R triples on my BW instead of boring the stock BW triples out, but I do believe some folks bored the BW triples to accommodate the Tri-Z forks.
jpswift1 screwed with this post 05-07-2014 at 08:06 AM
jpswift1 is offline   Reply With Quote
Old 05-07-2014, 06:55 AM   #2868
whythawk
Sweet Home Alabama
Oddometer: 21
Bw200 front sprocket
Hey guys I have a question how many teeth sprocket is original equipment on 86' bw200 ?
whythawk is offline   Reply With Quote
Old 05-07-2014, 01:54 PM   #2869
RobDek
Oddometer: 202
Spent yesterday harvesting what I needed for my machine....spare wheels, airbox, plastics, swing arm, tail light, etc. Here's the stuff I'm parting with.
RobDek screwed with this post 05-07-2014 at 02:03 PM
Old 05-07-2014, 04:26 PM   #2870
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,774
PMd
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 05-08-2014, 01:33 AM   #2871
RedMan66
Oddometer: 25
Wink Front end Mods
Thank you gentlemen for your time and Advice..
Cheers Brothers
I Don't read the Rules!!!
I Wrote Them!!!!
RedMan66 is offline   Reply With Quote
Old 05-08-2014, 06:30 PM   #2872
RedMan66
Oddometer: 25
Laugh ATC 250R front end!!
Brothers!!! How the Hell are ya???
Found a complete front end on eBay from a 1983 ATC 250r , thing is he wants $980 Australian to supply and deliver.. Bit pricy or what?? guess they are getting rarer but hey fair suck of the sausage. thats up there. hahaha Might see how bad the BW front end is first as i am barstardizing an 1997 XR 400 into a Big Wheel. On second thoughts STOPPING might be a priority... lol
I Wrote Them!!!!
Old 05-08-2014, 11:54 PM   #2873
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,378
Watch those atc triples some have rake built in.
I am building a smaller honda into a bw fatcat style of bike.
I have a set of those raked triples,which are no good unless the headstock is the same length as the donor or you get creative.
I ended up with atc350 triples which aren't raked.They take 35mm fork tube which i have a few off[cr80].Add a chinese quad hub...cheap$$ and a chinese quad wheel cheap$$ .Find the right length axle and add disc and spacers and little creativity and you have a pretty cheap front end.
ATC Triples landed in oz $60-100.Atc Front wheel around 200-300 landed etc
980 is crazy
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 05-09-2014, 08:51 AM   #2874
HairTrigger
Oddometer: 19
Please keep us updated. I was thinking of the same project, but with a 96 XR400.
HairTrigger is offline   Reply With Quote
Old 05-09-2014, 06:06 PM   #2875
whythawk
Sweet Home Alabama
Oddometer: 21
Front tire
Anyone ever tried a Carlisle AT489 tire up front on the bw200?
I took sixpeppers advice & went with the kenda K535 knarly on the back.
Old 05-09-2014, 08:15 PM   #2876
RWBWheel
RWBWheel's Avatar
Oddometer: 130
I believe Mr. Big-Wheel has that tire on a front rim or two...
RWBWheel is offline   Reply With Quote
Old 05-10-2014, 06:11 PM   #2877
BWSwamper
Oddometer: 196
AT489 on front...
I have one on my BW200. The 25x8-12 isn't as wide as many other tires called 25x8-12. However, the tread works pretty well on the bike.
BWSwamper is offline   Reply With Quote
Old 05-10-2014, 07:35 PM   #2878
OZZZ
OZZZ's Avatar
Oddometer: 18
Does the 489 25" fit the rear ok (anyone)? I was looking at the trail wolf, http://www.ebay.com.au/itm/141270662692
(or something heavier lugged than the Duro's) for rock and trail. Nice looking boots!
OZZZ is offline   Reply With Quote
Old 05-11-2014, 06:09 AM   #2879
BWSwamper
Oddometer: 196
AT489 rear?
Have you considered the 24x11-10 AT489 using the DMO adapter?
Old 05-11-2014, 06:42 AM   #2880
OZZZ
OZZZ's Avatar
Oddometer: 18
Thanks, I have. I'd like too... just baulk at the extra expense. Nothings ever a bargain on this side of the planet, most often involves post$$ eg even the duro 25" cheapest I could find is around $130au/$120us. I do want Bill's swingarm mod but baulk at the wheel adapter mainly for the extra expense. And sourcing the right rim. Tried AMS swamp fox but it was square and too tight.
Times are GMT -7.   It's 08:42 PM.
