Old 08-26-2012, 09:44 PM   #556
truckinwagen
Oddometer: 32
Well I picked up a bike to swap the motor into mine.
Its an 89 klr250. The bike is pretty ratted out, but the motor starts right up, and runs strong.
Its a kick start, four valve, water cooled motor with a six speed that makes 28HP.
Looks like an almost built-in too, the mounts are almost identical, the hardest part will probably be deciding how to hang the radiators.
Pics to follow tomorrow when the project begins.
-Owen
truckinwagen screwed with this post 08-26-2012 at 09:59 PM
truckinwagen is offline   Reply With Quote
Old 08-27-2012, 04:00 AM   #557
DEAVER
Oddometer: 137
Originally Posted by Cliff h View Post
Deaver:
Footpegs from a TW 200 will fit on the 350. It is on the short list of things for me to do, but IMS makes some pegs for the TW 200 (I believe they are made of stainless steel), but are fairly costly to the tune of something like $80 which is why I haven't done it quite yet. But what price tag can you put on safety (as for me, it is more than $20).
I'll check ebay for these?
-Owen
Lookin forward to seeing your progress.
DEAVER is offline   Reply With Quote
Old 08-27-2012, 04:26 AM   #558
DEAVER
Oddometer: 137
Deaver:
What about oem stock tw200 footpegs, i found them cheaper than IMS. Anybody try those? Are they the same dimensions as the IMS.
Old 08-27-2012, 07:48 AM   #559
Cliff h
[IMG]http://i219.pho
Oddometer: 260
Deaver:
Here is the IMS website: www.imsproducts.com (Super Stock series)
Since you would be ordering pegs for a TW 200, They should be the same as your BW 350, the only minor difference has to do with the return spring and the way it mounts, but is fairly self explanatory once you compare the two side by side.
Cliff h is offline   Reply With Quote
Old 08-27-2012, 12:19 PM   #560
DEAVER
Oddometer: 137
Deaver:
so the these are wider than the stock TW200 pegs? the reason i ask, is that i'll be placing a order with a OEM supplier and i would save on shipping by dealing with one company.
Old 08-27-2012, 12:33 PM   #561
DEAVER
Oddometer: 137
IMS are currently out of stock till a 2-3 weeks.
Old 08-27-2012, 01:43 PM   #562
Mr. BigWheel OP
b00b
Mr. BigWheel's Avatar
Oddometer: 756
Three weeks would allow Cliff to save $30/week and have money left over for shipping.
If we tell him that they are bling and not safety or performance related, he will start saving now.
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 08-27-2012, 02:43 PM   #563
DEAVER
Oddometer: 137
haha.
Old 08-27-2012, 04:01 PM   #564
LDL
Oddometer: 71
Mr.Big Wheel , Cliff h , and Deaver , you guy's ever get together I hope somebody has there GoPro's running . It sound's like you guy's are makeing a Frankinsteinberg bike way up there in the northland . Keep it up ! We're all takeing notes and learning from this forum .
LDL is offline   Reply With Quote
Old 08-27-2012, 06:38 PM   #565
truckinwagen
Oddometer: 32
well, I got the bikes stripped down, fought the overly-complicated wiring on the donor bike down to just the essentials, and got to the first test fit.
the engine is just a little too long to slide right in.
not un-doable, but more work than I thought initially.
-Owen
Old 08-27-2012, 07:03 PM   #566
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
Break out the grinder, you'll have that engine fitting in no time.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 08-27-2012, 09:53 PM   #567
truckinwagen
Oddometer: 32
well, I want to try and do this without modifying the bike too much.
and unfortunately my welder just quit, so some care will have to be taken with what is cut.
anyway time for some pics!
the frame, unencumbered of anything to make it go:
the old, dead, motor:
the new motor, in all its glory!
the mess of wiring removed from the donor to get rid of all the non-essential functions:
and finally, the carcass of the KLR:
work will resume tomorrow, I am hoping to have the darn thing running by saturday morning so I can take it down to Homer and go tear up the beach!
also, the tank fell and broke, the whole top came off.
luckily the donor bike has a tank I can use(its metal, so no cracking issues) but it will be really ugly.
hoping I can find a more elegant looking tank to slam on it (the donor tank is off an XT650)
-Owen
Old 08-28-2012, 01:23 AM   #568
Cliff h
Oddometer: 260
No, I don't belive that the IMS pegs are any wider than the stock TW 200 pegs, just made from a more exotic material, read: More expensive. I am not sure how much stock TW 200 pegs are, but would be interested to know.
Old 08-28-2012, 01:09 PM   #569
DEAVER
Oddometer: 137
I'm happy to say 60bucks for stock vs 79 for IMS. Are u sure the 2x3" ims are the same as the stock pegs?
Old 08-28-2012, 02:45 PM   #570
truckinwagen
Oddometer: 32
well, I got the new motor to fit into the frame!
very minimal cutting, just the hoop that the skidplate hooks to and the lower engine mounting tabs.
the rest of the "fitting" was accomplished by spreading the frame just a little with a highlift jack.
now the new motor sits nicely in the frame.
this will change the head angle a little, but only a few degrees (I only spread the frame about an inch) and if that ends up being a big deal I can always put longer shocks in the rear end.
although since I have a larger tire in the back, this may bring me back to stock head angle(or close anyway)
now I just need to finalize the mounts and put it back together.
-Owen
Times are GMT -7.   It's 05:49 AM.
