Old 08-28-2012, 04:52 PM   #571
DEAVER
Oddometer: 137
Originally Posted by truckinwagen View Post
well, I got the new motor to fit into the frame!
very minimal cutting, just the hoop that the skidplate hooks to and the lower engine mounting tabs.
the rest of the "fitting" was accomplished by spreading the frame just a little with a highlift jack.
now the new motor sits nicely in the frame.
this will change the head angle a little, but only a few degrees (I only spread the frame about an inch) and if that ends up being a big deal I can always put longer shocks in the rear end.
although since I have a larger tire in the back, this may bring me back to stock head angle(or close anyway)
now I just need to finalize the mounts and put it back together.
-Owen
Nice post, keep up the good work!
DEAVER is offline   Reply With Quote
Old 08-28-2012, 07:04 PM   #572
DEAVER
Oddometer: 137
Tw 200 footpegs
Did a little research on the tw forum and the stockers by all accounts seem to be the usual standard. in fact the tw crowd use IMS footpegs too. Some guys like these cheaper alternative (chinese) are these the footpegs u "trialed"
www.ebay.com/itm/Steel-Foot-Pegs-Yamaha-PW-50-PW-80-TW-200-/350583609088?pt=UK_Motorcycle_Parts&hash=item51a0695700
Old 08-29-2012, 12:33 AM   #573
Cliff h
[IMG]http://i219.pho
Oddometer: 257
Originally Posted by DEAVER View Post
I'm happy to say 60bucks for stock vs 79 for IMS. Are u sure the 2x3" ims are the same as the stock pegs?
No, I am not sure. I was looking for a higher quality set of pegs after my cheap made in China ones failed, so I was willing to look at a more quality set of pegs price be damned seeing how important it is to not have your pegs fail on you/me.
Cliff h is offline   Reply With Quote
Old 08-29-2012, 07:54 AM   #574
DEAVER
Oddometer: 137
hit my previous post link, are these the chinese one u had? they are like ims and of course larger than the stockers. again the tw forum seems to be happy with both with no complaints of failure.
Old 08-29-2012, 07:57 AM   #575
DEAVER
Oddometer: 137
Owen: are u gonna give that frame and engine a spray or 2 of paint? I would once u get it all figured. Since u got it all apart, i'd be nice.
Old 08-29-2012, 08:22 AM   #576
Cliff h
Oddometer: 257
Deaver, yes my failed pegs were cheap, made in China pegs made from aluminum. They were made for a TW 200, but I put them on my BW 350 in order to have the larger size that the TW pegs have. If they were made of steel, they might have lasted more than 1-2 rides.
Old 08-29-2012, 01:09 PM   #577
DEAVER
Oddometer: 137
http://www.ebay.com/itm/Steel-Foot-P...item51a0695700
these are steel and by all accounts on tw200 forum they are IMS without the tag. i just ordered and will update upon installation.
Old 08-29-2012, 07:20 PM   #578
truckinwagen
Oddometer: 31
yeah, I will paint all the new mounts and stuff.
the frame still has the factory paint on it in really good condition, and anything I do on my back porch wont be nearly as good as that, so I will leave the frame itself alone.
just started a new job, on top of college, so progress may slow a bit (I no longer have 8 hours in the middle of the day free) but I am going to try and have the mounts finished tomorrow night so I can re-assemble it on friday and take it to homer for a test ride.
I got the rear motor mounts built, and the front one mocked up yesterday.
should be pretty quick work to finish up..
-Owen
truckinwagen screwed with this post 08-29-2012 at 07:29 PM
truckinwagen is offline   Reply With Quote
Old 08-29-2012, 08:56 PM   #579
kubiak
Oddometer: 4,810
-Owen
looks like a exciting build!
kubiak is online now   Reply With Quote
Old 08-30-2012, 08:59 PM   #580
Mr. BigWheel OP
b00b
Mr. BigWheel's Avatar
Oddometer: 749
That's going to be AWESOME!!!
If you have that done by Friday then you will have completed a non-stock engine swap in less time than it takes me to change a fork seal.
We'll have to go run that out to the Knik Glacier when it's done and properly baptize it.
Regards,
Mr. BigWheel
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos:
http://www.youtube.com/user/MisterBigWheel?feature=mhum
Mr. BigWheel is offline   Reply With Quote
Old 08-30-2012, 09:06 PM   #581
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,177
By immersion, right?
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 08-30-2012, 09:27 PM   #582
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,192
the 250r motor is water cooled as well
Might be a bit late here, but the ATC 250R was air cooled 1981-1984, the 1985-1986 models were pumpers.
I'm a massive 3 wheeler nut, same with big wheels, this thread has my attention
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 08-30-2012, 09:41 PM   #583
truckinwagen
Oddometer: 31
yeah, I know about the early 250r being air cooled, but the only one local that was reasonably priced was not one of them.
hoping it stops raining tomorrow so I can get back to work on it.
not too much more to do, but without an indoors to work on it, I am at the mercy of the rain gods.
-Owen
Old 08-30-2012, 10:20 PM   #584
XpressCS
XpressCS's Avatar
Oddometer: 1,192
Time to get yourself one of them fancy awning things.
2004 KLR650
Old 08-30-2012, 10:29 PM   #585
truckinwagen
Oddometer: 31
its on the list, but on the student budget it was either the new motor or an awning to install it under, not both
truckinwagen screwed with this post 08-30-2012 at 10:48 PM
Times are GMT -7.   It's 09:44 AM.
