03-16-2013, 12:47 PM
#991 | |
Oddometer: 434
Yes,it could be done with some custom parts. If there is an interest in this I could work it out. Choosing a common disc and caliper would be the first step. I am converting my BW to disc but I am using a CR/XR disc and caliper on TriZ forks. |
03-16-2013, 09:50 PM
#992 |
screaming chicken
Oddometer: 28
Not sure the cost to pull off the front fork conversion but it seems to me that the conversion would be worth some money
The Defynce big wheel, Going where no big wheel has gone before................. '86 Bw 200 '77 T/A '12 camaro |
03-17-2013, 01:04 AM
#993 |
b00b
Oddometer: 549
There is always a bit of interest in a front disc for the BWs. I would estimate the costs of converting to a Tri Z front end as follows:
Forks - $100 Axle - $20 Brakes - $100 Hub - $35 Rotor - $20 Triple Clamp - $50 You could be a patient, smart shopper and get all of those items considerably cheaper, but that takes some time. That's a total of $325. Like all estimates, it is probably safe to double that number to cover all of the variables. For example; 1) Are the bearings in the used hub you bought usable? 2) Will you need new brake pads? 3) You will probably need fork seals and possibly bushings 4) Are you using '86 Tri Z forks? - they usually go for more $ 5) Did you get all of the hardware or will you need new stuff? 6) Does the caliper need to be resealed? You can use your old BW fender with some spacers, otherwise a new Maier Tri Z is about $120 on eBay. Shipping is going to add 10 to 20%. For all of that money you get a 25 year old brake system and a 25 year old right-side-up fork. The forks are better (longer travel, somewhat better dampening and larger diameter tubes) The brakes are better (what wouldn't be better?) and it all bolts together very easily. Is it worth it? Probably not. I really like having the Z fork but a Shercoman-modded original fork would be a very close second. Regards, Mr. BigWheel
The BigWheel channel - Home of the self-aggrandizing Enduro Alaska videos: http://www.youtube.com/user/MisterBigWheel?feature=mhum |
03-18-2013, 11:54 AM
#994 |
Oddometer: 32
did alittle bit to the old fat kitty over the weekend. new front fender, 6 pack holder, and trailer setup.
03-18-2013, 03:28 PM
#995 |
b00b
Oddometer: 549
WR450FADVn,
I think you could honestly label the rack as a half-rack holder. But it's completely superseded by that keg hauling trailer. Why does a Fatcat have two cables running to the rear brake? Further thoughts on the front disc brake setup: Perhaps the easiest modification would use a TW200 lower fork tube. This would be the left side: ![]() ![]() There is already a caliper mount so there would be no machining for the fork tube. The TW caliper and mounting bracket are bolt-on parts that are in plentiful supply. The inner fork tubes are 33mm and slide right into the BW triple clamps. The axle mounts are in the same location and there would be no change in the steering geometry. The forks are the same length, so there would be no need to get a longer rear shock as there is on the Tri Z conversion. The major obstacle would be the rotor mounting point and setting up spacers to keep everything centered. That is my academic treatise on the subject. Of course, I am utterly worthless as far as enacting any such project. Regards, Mr. BigWheel
03-18-2013, 04:08 PM
#996 |
screaming chicken
Oddometer: 28
So guys I have a big(wheel) problem
03-18-2013, 04:12 PM
#997 |
screaming chicken
Oddometer: 28
The big wheel will not kick over, I changed the oil And three I. A new filter and now it will not start. I had a friend helping me and he put both full quarts of oil in the bike before I could get to it and now I am not getting power to the coil back and it's driving me nuts, it ran just fine two days ago and now nothing. How would over filling the oil make the cool go without power?
03-18-2013, 05:27 PM
#998 |
Oddometer: 336
Maybe the ls vegas heat burnt it up? Did you accidently pull the coil wire off,make sure coil and plug wires are secure,did you break a ground off the coil wire etc?Coil aare like fuel pumps tho one day they work fine the next minute your motoring along and kapow the bitch just quits.usually a bad coil when it gets hot it will start missing bad before it totally quits,wont restart when it coold down it fires fine till it gets hot again.maybe cdi is bad if the other stuff checks out,not sure if bike has fuses but check them too
03-18-2013, 06:08 PM
#999 |
screaming chicken
Oddometer: 28
I'm not getting power to the coil and can't figure out why not
03-18-2013, 06:54 PM
#1000 | |
Oddometer: 434
Mounting the caliper is the hard part of this project so that is taken care of. Machining a disc mount to adapt to the original hub would be the easier part. Would a TriZ hub work in these forks? That would simplify thing even further but the spacing might be an issue. |
03-19-2013, 06:59 AM
#1001 | |
Oddometer: 32
03-19-2013, 09:40 PM
#1002 |
b00b
Oddometer: 549
I guess the distinction between the two is that the BigWheel is a three-wheeler with two wheels while the Fatcat is a four-wheeler with two wheels.
Shercoman, I believe that the Tri Z axle has a slightly smaller diameter than the BW. Perhaps the Z hub could be used on the BW axle if there are bearings that have the hub's I.D. and the axle's O.D. I'm on the road until the weekend but I will confirm that observation when I get home. I'll put a BW front end together and fit a Tri Z hub for some pictures so you can see what kind of clearance issues there are. Regards, Mr. BigWheel
03-20-2013, 05:21 PM
#1003 |
Oddometer: 537
Got the motor split, now just trying to get the damn circlip off the main axle!!! Been trying with flat head and small pliers but just can't get it.. gonna try again later when I am less frustrated.
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 85 Yamaha BIG Wheel 200 www.drriders.com |
03-20-2013, 06:53 PM
#1004 | |
Oddometer: 434
Less time cussing and more time rebuilding!
03-20-2013, 07:00 PM
#1005 |
Oddometer: 9
bw350 airbox
I need to remove a bw350 airbox to clean it up. Previous owners did some messy stuff to it (see pic). I am going to go thru the carb too so I figure this would be a good first step. Can anyone walk me thru this getting the airbox out?Thanks, duster11
I like Big Wheels and I cannot lie! 1986 BW200 | 1987 BW350 | 1999 Rokon Trailbreaker | 1992 RT100 | 2002 XT225 1970 Plymouth Superbird | 1970 Dodge Charger R/T | 1976 Plymouth Feather Duster | (2) 1976 Dodge Dart | 1974 Plymouth Duster | 2005 Jeep Wrangler | 1996 Dodge Dakota |
