Old 02-04-2011, 08:49 PM   #1
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 644
JTH's HD 883 Dual Sport'ster conversion
www.carduccidualsport.com
Theres been some interest in this build, so thought I would post the development progress and hopefully get some insight from the inmates, as there are alot of challenges.
Ive wanted to do this for years, but kept putting it off, but recently have seen a few nicely done conversions that have been the inspiration and ambition to finally give it a try.
So, with a vision in mind, I started with a stock 03 HD 883 Hugger, 100th anniversary, that I picked up on new years ever last year. Next day began tearing it appart.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog screwed with this post 12-08-2012 at 07:23 AM
JimmyTheHog is offline   Reply With Quote
Old 02-04-2011, 08:51 PM   #2
JimmyTheHog OP
Oddometer: 644
Tear down...
Jim
Old 02-04-2011, 08:55 PM   #3
JimmyTheHog OP
Oddometer: 644
KTM front end mock-up. Bearings and stem length are perfect fit...
Jim
Old 02-04-2011, 09:02 PM   #4
JimmyTheHog OP
Oddometer: 644
Now the details:
- Trail Tech 8" head light
- Tracker 1" bars
- Joker Machine 1" bar clamps
- Applied Racing Triple Clamps
- Stock controls - no rewiring required (grips gotta go though...)
- Tach/Speedo mount custom designed & fab'ed billet bracket
- Steering stop custom des/fab billet bracket
- UFO front fender - KTM RFS
- New brake line 52" sst from CC
- Front wheel & caliper from KTM 525 - soon to have wider Sun rim for TKC80
Jim
JimmyTheHog screwed with this post 02-13-2011 at 09:29 AM
Old 02-04-2011, 09:04 PM   #5
JimmyTheHog OP
Oddometer: 644
Tach/speedo mount... sorry for the bad cell phone pic..
Jim
Old 02-04-2011, 09:06 PM   #6
JimmyTheHog OP
Oddometer: 644
Steering stop - bolts to bottom triple clamp.
Jim
Old 02-04-2011, 09:13 PM   #7
JimmyTheHog OP
Oddometer: 644
So, the front end is mostly done. Moving on to the rear end - swingarm / monoshock mount.
The plan is to mock up the stock swingarm with extensions to lengthen it, install the new 18" rear wheel, and get the geometry set right before jumping into design of the swingarm / mount.
Here is the rear wheel from Buchanan's:
- 18" Sun rim
- Storz billet alum hub
- TKC80 140/80-18
Jim
Old 02-04-2011, 09:14 PM   #8
JimmyTheHog OP
Oddometer: 644
Waiting for my swingarm mock-up extensions to come in from fab....
Jim
Old 02-04-2011, 09:14 PM   #9
JimmyTheHog OP
Oddometer: 644
Forgot picture....
Jim
Old 02-05-2011, 04:48 AM   #10
marret
Transient
Oddometer: 151
Looking great.
What year front end are you using?
Thanks for posting.
marret is online now   Reply With Quote
Old 02-05-2011, 07:13 AM   #11
JimmyTheHog OP
Oddometer: 644
The forks are from a 2003 KTM 525 EXC (which you see sitting next to it in sad shape) and have been reworked by Hlebo Bros racing suspension for a 230 lb rider. I dont have the specs as the PO did the work and didnt know.
We'll see if they are adequete when the build is done. I had a dream last night that I was riding it and it worked perfectly...
Jim
Old 02-05-2011, 07:31 AM   #12
jphish
Oddometer: 596
Very Cool ! You are an Arti'st. Like a Ulysses - but a few steps farther.
jphish is offline   Reply With Quote
Old 02-05-2011, 07:33 AM   #13
jphish
Oddometer: 596
PS: Final drive - chain or belt ??
Old 02-05-2011, 07:54 AM   #14
JimmyTheHog OP
Oddometer: 644
It will be a 530 chain. The sprockets are on order: 24/51 tooth.
The hardest part is the wait for the parts to come in !
Jim
Old 02-05-2011, 11:07 AM   #15
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
Send a message via AIM to johnwesley
hey Jimmy thanks for putting this up looks like its going to come out great. This makes two builds going on in the forum with a sporty. I hope you guys stay far enough ahead of me to make it easier to follow suit. I already see I should have went with the ktm forks to make the forks a bolt on deal. We'll see how hard the conversion will be for the yz set up.
johnwesley is offline   Reply With Quote
Times are GMT -7.   It's 12:48 PM.
