Old 04-24-2011, 10:03 AM   #151
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 716
Originally Posted by johnwesley View Post
From south Africa:
Your going to love the exhaust sound. Quite awesome IMO
Your making me anxious to get home and get back to work.
Looks great man
Do you have the rub block done yet?
Thanks - I got the V&H idea from yours. I think its going to work great.
The rub block is done but I have not received it yet. Should be soon. The machine shop and I are too tied up with our day job stuff that we keep forgetting.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 04-24-2011, 11:05 AM   #152
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,403
Badass ride. Bravo
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 04-27-2011, 09:25 PM   #153
JimmyTheHog OP
Oddometer: 716
Chain slider received and installed - missed the boat on this design
The most important part around the swingarm pivot is not protected enough. Easy fix though - trim this guide back and add a round cover over the pivot. It will be a 2-peice solution. Back to the drawing board....
Jim
Old 04-28-2011, 11:37 AM   #154
DC,Chad
DC,Chad's Avatar
Oddometer: 322
this is without a doubt going to be an amazing bike , the quality of workmanship is fantastic i applaud you sir
i would love to hear that engine burbling through that can
GS gone now on a 1990 Electraglide sport natural balance gone to Ratshit
RD03 Africa twin slowly coming together
DC,Chad is offline   Reply With Quote
Old 05-01-2011, 06:54 PM   #155
JimmyTheHog OP
Oddometer: 716
Thank you! - It should be burbling soon!!!
Jim
Old 05-01-2011, 07:03 PM   #156
JimmyTheHog OP
Oddometer: 716
The chain slider design is done. Its now 2-pieces. The round part will most likely get the most wear and be consumable, so making it 2-pieces, where the round piece is small, inexpensive, and easy to replace, should be the most economical and work nicely - we shall see....
Now to get it machined. Material will be black delrin...
Jim
Old 05-03-2011, 09:52 PM   #157
JimmyTheHog OP
Oddometer: 716
Rack mounting brackets designed and being fab'ed. Slowly but surely its comming together....
Jim
Old 05-04-2011, 09:40 PM   #158
JimmyTheHog OP
Oddometer: 716
Fork springs didnt fit !
Heads up to anyone installing stiffer fork springs - I bought some custom made stiffer springs for the KTM 525 forks - .070's. The outside diameter is about the same as stock, but with the larger gauge spring wire, the inside diameter gets smaller - hence, doesnt fit over the guides now
I talked to MX-TECH about it, and they said this is typical ( It was new to me) - but I guess it makes sense - I should have asked before. Now I know.
Anyway, heres a plug for our local cycle accessory shop - Santa Clara Cycle Accessories - they are changing the springs and seals, and are working with FabricationsUnlimited in Alviso to turn down the guides diameter on the a lathe for me ! Great service
Jim
Old 05-15-2011, 04:30 PM   #159
exlogger
Oddometer: 35
what's up?
Just thought I would bring this thread to the top. Are you making any progress on the best build on the web?
exlogger is offline   Reply With Quote
Old 05-15-2011, 05:18 PM   #160
JimmyTheHog OP
Oddometer: 716
Hey, Thanks ! - Some progress, but still waiting for the rear fender and now the brake lever. Should be here in a week tops.
I did receive the new chain slider today and installed it. Fit is good. Should work fine. Front fork springs also installed.
Tomorrow I get the gas tank bracket welded to the frame, and then install the tank w/ gas - and then can start it. I'll post a vid of it runnig.
Here is a pic of the chain slider around the swingarm pivot.....
Jim
Old 05-15-2011, 05:25 PM   #161
JimmyTheHog OP
Oddometer: 716
Quail motorcycle gathering
I took the weekend off from the build, work, etc..., and went to the Quail motorcycle gathering this Saturday in Carmel Valley - vintage bikes extraordinare !!! Good for some inspiration.
Here are some favorites.....
Jim
Old 05-15-2011, 05:27 PM   #162
JimmyTheHog OP
Oddometer: 716
Quail motorcycle gathering...
Quail...
Jim
Old 05-15-2011, 05:28 PM   #163
JimmyTheHog OP
Oddometer: 716
More....
Jim
Old 05-15-2011, 05:30 PM   #164
JimmyTheHog OP
Oddometer: 716
More????
Jim
Old 05-15-2011, 05:31 PM   #165
JimmyTheHog OP
Oddometer: 716
Nice Duc...
Jim
Times are GMT -7.   It's 10:29 PM.
