Old 02-05-2011, 12:56 PM   #16
JohnBoy777
Pseudo-Adventurist
JohnBoy777's Avatar
Oddometer: 888
Jimmy,
Great idea - thanks for posting.
John
JohnBoy777 is offline   Reply With Quote
Old 02-06-2011, 08:08 PM   #17
John Ashman
Adventurer Wannabe
Oddometer: 2,049
I saw an 883 the other day for the first time and it was the first Harley I've seen that I wouldn't kick out of my garage. I know it's the "girl's" Harley, but it seemed like a natural bike, not all glitzed and hyped to be super macho and stupid. Seemed like fairly decent ergos too.
John Ashman is online now   Reply With Quote
Old 02-12-2011, 08:34 AM   #18
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 713
I just got my swingarm extensions for the swingarm mock-up. Insert them into the swingarm ends to lengthen it, find the right geometry, then begin cad design of the new swing arm. Mock-up pictures to follow...
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 02-12-2011, 08:40 AM   #19
wpbarlow
Oddometer: 10,627
You have to name this bike "Silk Purse"
wpbarlow is online now   Reply With Quote
Old 02-17-2011, 11:20 AM   #20
Keith
Slabbing it
Keith's Avatar
Oddometer: 907
Progress?
Random Crap
Keith is online now   Reply With Quote
Old 02-17-2011, 07:25 PM   #21
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,607
how much are you going to lengthen the swingarm or should i say how much do the extensions add.
johnwesley is offline   Reply With Quote
Old 02-17-2011, 09:31 PM   #22
JimmyTheHog OP
Oddometer: 713
The extensions are installed and looks like a ~4" increase in swingarm length feels & looks about right. Wheelbase will be ~64" when suspension is fully extended. I'll take some pictures this weekend and post them.
Next step is select rear shock and begin new swingarm design.... Any sugestions on a rear shock ? Im considering a Progressive 465 series but need to make sure spring rate and travel are adequate.
Jim
Old 02-17-2011, 09:40 PM   #23
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,607
we are tracking about the same I am having a swingarm built for mine. I have the shock location figured out and will be using a single shock. I am working with Rick at motocd.com on the shock. It will be a one off build, unless we end up with the same swingarm design then it may work on yours too. My swing arm will be 2" longer, I am trying to keep it no more than 62" WB. No good reason for that wb other than the longest of the ADV bikes is the KTM ADV and the 800 gs both right at 62" That is not to be a negative on 64" as that is what the HPN air head conversion bikes end up at.
enough rambling on your thread
Old 02-18-2011, 07:01 AM   #24
JimmyTheHog OP
Oddometer: 713
Sounds good. I had the Cogent Moab shock on a KLR from motocd and liked it. I'll check them out - thanks.
It will be interesting to see how close our designs get to each other. I'll post some pic's as I get into it.
Jim
Old 02-18-2011, 08:42 AM   #25
OLDschool1
OLDschool1's Avatar
Oddometer: 14
Very interesting project. Never seen a dual sport sporty. You might be on to something here. Can't wait to see how this project ends. So far it is looking pretty trick.
2003 FLHTCI
1985 VF1000R
1983 XR350R
1982 XL500R
1979 GS750E
1971 FX
OLDschool1 is offline   Reply With Quote
Old 02-18-2011, 09:10 AM   #26
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,607
i responded to the pm, I think we can work something out. there is two pm replays
Old 02-19-2011, 12:15 PM   #27
JimmyTheHog OP
Oddometer: 713
Installed the swingarm extensions and looks like +4" extension is about where I i'd like it, but still need to do some cad layout on the geometry and swingarm / shock to make sure all the dim's work out.
With 4" extension and the KTM front end w/ 21" wheel - new wheel base is ~64". A bit long, but should help with stability at speed. We shall see
Jim
Old 02-19-2011, 12:18 PM   #28
JimmyTheHog OP
Oddometer: 713
Swingarm geometry mockup ....
Jim
Old 02-19-2011, 12:18 PM   #29
JimmyTheHog OP
Oddometer: 713
A better view from side....
Jim
Old 02-19-2011, 12:36 PM   #30
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,607
Question
did you go with PBI sprockets?
what chain length?
Times are GMT -7.   It's 10:20 AM.
