Old 02-19-2011, 04:25 PM   #31
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
Originally Posted by johnwesley View Post
did you go with PBI sprockets?
what chain length?
Sprocket Specialists 530 x 51 tooth, and the chain is 120 links shown, but final length is TBD. Probably +/- a few links. Looks pretty close as is.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 02-19-2011, 04:28 PM   #32
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
Question
i hope mine is the right length when we get through, i ordered a conversion but they didn't provide chain length.
johnwesley is offline   Reply With Quote
Old 02-19-2011, 04:38 PM   #33
JimmyTheHog OP
Oddometer: 741
Geometry...
I started the geometry layout to determine the swingarm length, shock length & spring rate, and shock position. Im considering a monoshock mounted either Left Side (thanks john - good idea) or Center.
Here are the layouts - work in progress....
Left Side Shock - Neutral (no load) & Compressed:
Jim
Old 02-19-2011, 04:45 PM   #34
JimmyTheHog OP
Oddometer: 741
Center shock - Neutral & Compressed:
Jim
Old 02-19-2011, 04:53 PM   #35
JimmyTheHog OP
Oddometer: 741
Heres a side by side of each...
Jim
Old 02-19-2011, 04:53 PM   #36
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
what length from swingarm pivot to shock mount did you use
Old 02-19-2011, 05:01 PM   #37
JimmyTheHog OP
Oddometer: 741
Here are the dim's... Swingarm is shown at ~20 degrees from flat...
Jim
Old 02-19-2011, 05:05 PM   #38
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
thanks, I like the adjustable shock mount. With the measurement does that give you room to clear the break caliper?
Old 02-20-2011, 07:04 AM   #39
JimmyTheHog OP
Oddometer: 741
Yah - that position will hit the caliper. Im trying different geometries to see what looks best - and learning in the process. As I mentioned in your thread, the ATK mounting looks best so far, but will require a frame mod to add the attachment bracket plus some stiffening. This is still close to the caliper, but I think it may be do'able. Detail design of the swingarm will
tell.
How do you plan to mount your shock ?
Here is the geometry:
Jim
Old 02-20-2011, 07:13 AM   #40
JimmyTheHog OP
Oddometer: 741
ATK style - Neutral and compressed:
Jim
Old 02-20-2011, 07:21 AM   #41
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
my plan was to use the stock mount on top. with the swing arm in full droop then the shock is 90 degrees from horizontal. With a slight angle fully compressed. If memory is right then I moved the shock mount 7.5" forward and it just cleared the caliper
Old 02-21-2011, 09:07 AM   #42
maxmfp
Dirt wannabe
Oddometer: 7
I am very interested in how your bike is going to turn out. I ride a sporty myself and have been thinking about change my forks and shocks for years. The biggest change i did to mine is to put on a 6.6 gallon tank. Now i only have to fill up once a week. I will be watching for yours to Johnwesley.
maxmfp is offline   Reply With Quote
Old 02-21-2011, 09:17 AM   #43
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
here's mine http://www.advrider.com/forums/showthread.php?t=661573
so whats the info on the big tank? gotta pic
Jim and I are sharing idea's in hope to better both builds
Old 02-21-2011, 09:22 AM   #44
maxmfp
Dirt wannabe
Oddometer: 7
The tank was made for a DR650, i had to make a few changes but i got it to fit. I will post a pic when I find one (not sure i took one after i put it on).
Old 02-21-2011, 09:53 AM   #45
maxmfp
Dirt wannabe
Oddometer: 7
Got some pics
Times are GMT -7.   It's 07:05 PM.
