Old 12-11-2012, 10:55 AM   #526
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Glad I did not offend with my thoughts. Good idea keeping it service able at HD dealers for long distance travel purposses.
I was purely thinking of weight.
I agree on the shocks being a cool old school style and if they work good then all is good. I was purely curious as to the change reason, makes good sense especially since you thinking or even trying to market this as a kit, or at least parts of a kit. The good old KISS mentality. (Not that YOU are stupid....refereing to my self there)
Great stuff here Jimmy, thanks for the detailed thread. That is a really good weight for a big twin ADV bike. I think I want one...
At the very least, I want my buddy to build one so I can have him Beta test it.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 12-11-2012, 11:07 AM   #527
kellymac530
motorcycle addict
Oddometer: 1,052
One more quick question if I may,
It looks like you are running a stock KTM 2 piston front brake caliper on an extension bracket and a 320mm rotor, is that correct?
How do you feel it works on a close to 500# bike?
I am prepping to start a bike build and collecting parts and I have some negative input on my plans that my brake ideas are in no way enough, but I think they will be fine. I have a respectable inmate who builds alot of bikes insisting that not running a dual disc set up off of a big KTM twin will not be enough but I see alot of guys running the setup you have and see no big complaints.
Are you a heavy front brake user or a more typical HD rider and tend to use more rear?
I have raced MX for 40+ years and am a BIG front braker, My motto is "front brakes stop a motorcycle, rear wheel steers a motorcycle"....over simplified of course, but useable advice.
Thanks again JTH.
Old 12-11-2012, 07:47 PM   #528
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
KMac - Correct on the front brake. Its a KTM 2-pistion Brembo from a 525EXC, 320mm rotor, and extension bracket. Braided SST brake line and an Oberon adjustable brake lever on the stock Sportster master cylinder running DOT5.0 silicone. Im forgetting what brake pad material i have, but what ever stock KTM uses, thats it.
As far as braking power - for me, its adequate with this setup, but im a light braker. Having the adjustable lever made it better to get the max squeeze for my hand size. That being said, Ive had GS's, HP2's, 950SE, and 950/990 Adv's and all brake better than this setup. For offroad riding, i actually like it not being too grabby though. I crashed an HP2 in the dirt from a too grabby front brake once. For the on-road, i would actually like a bit more stopping power, but as i said - its adequate and have had to brake hard a few times and it gets the job done no problem. It does stop when the lever is pulled. Just takes a bit more pull force. The 320mm rotor was the big difference.
Im going to try a different pad material and that may be the ticket to a bit better on-road braking. I'll post when i do it.
If youre a hard front braker and like that - this setup will probably feel underbraked for you - unless the different pad material makes a difference.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 12-11-2012, 09:46 PM   #529
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,662
Are you planning to have the tank shaped in steel?
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 12-11-2012, 10:31 PM   #530
JimmyTheHog OP
Oddometer: 741
No on the steel. The primary plan is to make it plastic.
Jim
Old 12-12-2012, 01:52 PM   #531
Roadracer_Al
Oddometer: 1,662
Plastic like FRP, or plastic like rotomolded dirt bike tanks?
If the latter, I'd be interested to know costs and a source.
That kind of information is just good to have, you know, just in case.
Old 12-12-2012, 07:36 PM   #532
JimmyTheHog OP
Oddometer: 741
Rotomolded XLPE. Im working on selecting the right supplier now, so cant disclose anything yet.
Jim
Old 12-13-2012, 09:23 PM   #533
kellymac530
motorcycle addict
Oddometer: 1,052
Thanx a ton for your reply Jimmy.
Very cool of you to take time to answer my question while you are still working on this great machine.
I am pounding out some details for a build myself and an inmate here has given me some great advice on brakes and getting to some other ideas is very helpful.
Old 12-25-2012, 02:21 PM   #534
JimmyTheHog OP
Oddometer: 741
Happy Holidays everyone!
New projects for 2013 are already in progress:
- 6 gal gas tank - Aluminum prototype to start, then plastic to follow
- Crash bars
- Triple Clamps
CRASH BARS: To go along with the larger gas tank, I'll be adding a crash bar to protect the tank and petcocks in case of a low side fall and also to mount some new LED flood lights.
TRIPLE CLAMPS: Triple Clamps design is close to done. These are stronger than the ones im using now and will allow for more turning radius as the clamps have been moved to the front and provide more clearance to the frame.
Jim
Old 12-25-2012, 07:33 PM   #535
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 489
Keep up the good work Jim! You've got at least one victim in me...
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 12-25-2012, 08:00 PM   #536
DRjoe
DRjoe's Avatar
Oddometer: 5,204
your pretty handy cad then
DRjoe is online now   Reply With Quote
Old 12-25-2012, 08:07 PM   #537
WhicheverAnyWayCan
Deaf Biker
WhicheverAnyWayCan's Avatar
Oddometer: 915
JimmyTheHog,
You don't have to buy your Triple Tree if buying your fuel tank? I was hoping to stay with my own Triple Tree while using your fuel tank.
WhicheverAnyWayCan is offline   Reply With Quote
Old 12-25-2012, 08:22 PM   #538
JimmyTheHog OP
Oddometer: 741
Originally Posted by WhicheverAnyWayCan View Post
JimmyTheHog,
No, you dont need to. The stock KTM 525 triple clamps or the Applied Racing (for KTM) triple clamps will work with the tank as is. For others clamps, i would need to check the dimensions, but the tank has generous clearance for the forks and clamps, so unless youre using something really wide, they should fit.
These new triple clamps will be stronger & stiffer for the increased weight of the Sportster and give a bit more turning radius now that the new tank allows for that. Ive also integrated the Sportster rubber handlebar dampers into the bar risers - keeps motor vibration to the hands down to a minimun.
Jim
Old 12-26-2012, 10:38 AM   #539
boatpuller
Oddometer: 633
What forks will your triple tree accommodate?
(If that is a silly question, please excuse me. I've never changed changed or researched forks before, but plan to in this upcoming project.)
boatpuller is offline   Reply With Quote
Old 12-26-2012, 11:31 AM   #540
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
Are you (or have you considered) putting steering damper mounts on the triple clamp? It should be a pretty easy addition, just a couple of threaded holes. It would work much better than a bracket that gets added on afterwards, especially if the bracket is attached to the handlebar side of the rubber mount.
I have no idea if your bike would be helped much by a steering damper, but lots of people like them on other bikes.
Luke is online now   Reply With Quote
Times are GMT -7.   It's 05:13 PM.
