Old 02-16-2013, 06:46 PM   #586
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,848
A little Sportster plaqying in the dirt [Verticle Dirt] action.
http://www.youtube.com/watch?v=ZHJjO...yer_detailpage
bk brkr baker is online now   Reply With Quote
Old 02-20-2013, 05:38 PM   #587
WhicheverAnyWayCan
Deaf Biker
WhicheverAnyWayCan's Avatar
Oddometer: 918
Yo! I got 40 holes hub from local H-D Dealer for free and I was wondering where did you get your rim from? Buchananspoke.net ? Did you knew what you needed and just order it or did you had to speak with someone over there to get what you needed? I am wanting a rim that is 17" with 40 holes and the hub you have look so much like the one I have..
WhicheverAnyWayCan is online now   Reply With Quote
Old 02-20-2013, 08:03 PM   #588
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
That's correct - I had the wheel built at Buchanans. I liked the Storz tracker billet alum hub (now not available - their supplier went out of biz or something like that), so I bought it from Storz and then had it shipped direct to Buchanans (theyre both in SoCal) where they laced the hub to the Sun rim with sst .156 dia spokes - 40 total. They also have Excel rims too. Check me on this, but I think they drill the spoke holes in the rims there, so # of holes can be drilled to match the hub.
I had to call Buchanans to coordinate it and get the quote. Pretty easy to work with though and they did a great job in a short time.
Hope that helps.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog screwed with this post 02-20-2013 at 08:09 PM
JimmyTheHog is offline   Reply With Quote
Old 02-21-2013, 01:47 PM   #589
Bambi
Bambi's Avatar
Oddometer: 708
Hello Jimmy,
wanted to deny your last statement. But I'm not sure any more ...
First: Might reach a twilight zone of my English now: I'm used to rims that offer a small recess (the English translation of our German word 'Punzung' says 'punch', but I'm not sure if this is correct this time) to the nipples of the spokes. The word 'punch' is that twilight point!
I'm rather sure, that I never saw anything else on a rim for a motorbike. So the number of spokes that could be used on the rim is not 'dictated' by the number of holes in the hub but limited by the number of punch(e)s on the rim. Or the other way round. Even the holes in the punch(e)s must have the correct angle to line up hub, spoke and rim.
I searched about 2 dozens of your pics to get a clear and big view to your rims. Didn't get one as good as I wanted. Tried to enlarge some of them, but with no clear result. It really looks like your rims do not have any punch(e)s and thus would enable you to marry any hub to any rim. Reminds me of the wheels of my old mountain-bike that are built that way, too. But leaves me a bit concerned about life-time-strenght of the wheel ...
Hopefully greetings, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 02-21-2013, 01:58 PM   #590
Bambi
Bambi's Avatar
Oddometer: 708
Hello,
just a few more words:
the pic of the wheel on John Wesley's build-thread (page # 22) shows the recesses/punch(e) I meant! A rim like that can't be connected to any hub of your likes, it must have the same number of holes for the spokes and it has to be drilled at the correct angle to line up rim, spokes and hub.
Kind regards, Bambi
Old 02-21-2013, 06:12 PM   #591
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 490
Originally Posted by Bambi View Post
Hello,
Kind regards, Bambi
Bambi, most rims can be ordered custom "dimpled" and drilled to your specifications, that includes the number, size and angle of the spoke holes(nipple seats). Hope this helps.
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 02-21-2013, 06:32 PM   #592
JimmyTheHog OP
Oddometer: 741
I think that's how Buchanans does it, but not certain - punch or drill as required to match hubs. Again, check me on this, but that's what I remembered from when I had my wheels built by them.
Correct on the lack of punches or dimples - the Sun rims don't have them. Just drilled holes. Ive heard that Sun's aren't as strong as dimpled Excel's but not sure if that is due to the dimples or not. When I build another set, I plan to try the Excel's.
Jim
Old 02-28-2013, 07:56 PM   #593
JimmyTheHog OP
Oddometer: 741
Just got the new wind screen parts today. The polycarbonate was supposed to be grey tint, but came clear. I have a tint version on the way. Also, some bubbling occurred when doing the heat re-bending. It was bent the incorrect angle, so during the re-bend it got too hot. Anyway, prototyping is a learning process.
Jim
JimmyTheHog screwed with this post 03-01-2013 at 08:23 PM
Old 03-01-2013, 08:49 PM   #594
JimmyTheHog OP
Oddometer: 741
Slowly but surely Im getting the components that I wanted to start with. Didn't have the confidence at the beginning of the conversion to commit to that kind of spending required.
Ohlins forks and Talon front hub. Braking 32mm front brake caliper is next.
Jim
Old 03-01-2013, 09:48 PM   #595
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,970
Awesome! Gorgeous! Fantastic! Beautiful!
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 03-03-2013, 06:47 PM   #596
JimmyTheHog OP
Oddometer: 741
The new Braking 2x 32mm floating caliper received and installed. Just need a new AN3 15deg side bend brake line fitting and bleed. Once this is proved out, I'll be switching over to DOT/TUV approved crimped brake lines.
BTW - I met the guy that owns Melvin's brake lines yesterday at the Adv Designs open house in Hayward - Nice guy & nice products made close to home. SST braided hoses, Teflon inner core, adjustable swivel banjo fittings to prevent kinks / twisted lines, and yes - DOT approved. I'll be calling him soon
Here's the Braking caliper - size of the pistons compared to the stock KTM 525 Brembo's is noticeable...
Jim
Old 03-04-2013, 10:48 AM   #597
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,037
You might have the first $50,000 883 in history.
Add in labor and you might be over $100,000.
Sure does look good.
larryboy is online now   Reply With Quote
Old 03-05-2013, 11:09 AM   #598
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Jimmy, can we get a couple more pics of that caliper and maybe a link to where you got it?
Does it work with a stock MC or do you need a bigger one like a Sumo bike uses?
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 03-05-2013, 12:14 PM   #599
WhicheverAnyWayCan
Deaf Biker
Oddometer: 918
JimmyTheHog,
Suspension question- What spring rate did you had on the first shocks made by YSS (I think?) and what spring rate is on your Works' Piggyback?
I got a good deal on HD 1200S piggyback shocks that is 13.5" long. It has a 51 lb/in which most likely is way too soft for me and the load but I am most likely going to look for used 1200C (Part # 54668-04) and replace the 1200S spring with 1200C spring because it has about ~130 lb/in spring rate and I will add some shim (spacer) so it won't be too short for the 1200S length. It would be a cheaper modification that may be equal or better vs the price of Works shocks. This is a trick that two guys who own Sportster came up as a solution to make sportster a comfortable riding bike after investing $4,000-6,000 into many different rear shocks from companies like Progressive, Works, Penske, etc.
So I hope you don't mind me asking you the spring rate you had on first suspension and currently suspension. I am gonna ask John on his Ohlins few days later if he doesn't reply on this thread.
WhicheverAnyWayCan screwed with this post 03-05-2013 at 03:54 PM Reason: spelling
Old 03-05-2013, 07:49 PM   #600
JimmyTheHog OP
Oddometer: 741
I'll get a few more pics soon, but you can see/buy the caliper at www.oemcycle.com
Direct link: http://www.oemcycle.com/Item/product/900091011
They sell the Braking 320mm rotors, adaptor brackets, and calipers. Its supposed to work with the stock KTM MC brake, but I have the stock HD MC brake, which also worked ok with the stock KTM caliper. So, it should work ok, but but I'll confirm after install and test. Still waiting on the brake line fitting. It needs a 15deg side bend fitting to keep the brake line tucked in nice and tight. I hope to get it tomorrow.
Jim
Times are GMT -7.   It's 07:02 AM.
