Old 04-16-2013, 08:05 PM   #676
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 735
Originally Posted by larryboy View Post
Looking good, Jimmy!!!
Hadn't noticed before, but I think the reg/rec needs a rock guard?
I agree. I think I commented on this a while ago. Big concern where its at and if it gets covered with mud, then it will overheat too. If any good ideas out there on relocation, im may move it.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 04-16-2013, 08:15 PM   #677
JimmyTheHog OP
Oddometer: 735
The new Ohlins shocks & springs arrived. 15.28" long and 4.8" stroke equates to 8+ inches at the rear wheel. The Works shocks were 15" long, but the springs were stiffer and had less sag. So, the plan is hit the same swingarm angle but with slightly more sag.
Heres some eye candy....
Jim
Old 04-17-2013, 03:14 AM   #678
Kennon
Kennon's Avatar
Oddometer: 314
What Swedish goodness!
Kennon
2009 Yamaha Jog 50RR LC sold 2011
2011 Rieju Marathon Pro 125 SM sold 2013
1990 Honda VFR 400 NC30 purchased 2013
Kennon is offline   Reply With Quote
Old 04-17-2013, 09:44 AM   #679
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
On the reg/rec relocation, maybe move it straight up the front down tube above your upper crash bar tube. That would get it up to a more crash protected spot and up above the solid part of the fender so water, mud, and debris could not collect on it.
Worth a look anyway.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 04-17-2013, 09:59 AM   #680
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,972
Maybe mount it sideways with an air scoop like Buell did with their oil cooler?
Old 04-17-2013, 10:15 AM   #681
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,639
What version ohlins did you end up with?
johnwesley is offline   Reply With Quote
Old 04-17-2013, 07:40 PM   #682
JimmyTheHog OP
Oddometer: 735
Theyre Type S36P (S36PR1C1LB), but a variation of. I worked direct with Ohlins USA on the desired dimensions/specs and they built them up. They couldn't get the length vs stroke needed with the rebound damping wheel, so removed that and just have a screw adjustment at the bottom.
20-28N/mm springs I started with were too soft. Now trying 24-33N/mm tonight. EDIT: 24-33's too soft also. Shooting for ~1/3 travel sag. Moving on to new springs...
Jim
JimmyTheHog screwed with this post 04-18-2013 at 08:10 AM
Old 04-18-2013, 06:15 PM   #683
rodteague
Enjoying the ride
rodteague's Avatar
Oddometer: 413
I just got my swingarm extensions for the swingarm mock-up. Insert them into the swingarm ends to lengthen it, find the right geometry, then begin cad design of the new swing arm. Mock-up pictures to follow...
Love your build and website. Out of curiosity, would the swing arm extensions have worked if left bolted in place? They appeared well made and may have done the job more than adequately. I have seen aftermarket extensions for some sport bikes; was wondering that it might work well for a ADV sporty. Might also be a little more economical.
Regards
Rod
rodteague is offline   Reply With Quote
Old 04-18-2013, 06:54 PM   #684
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,127
Regards
Rod
I don't think economy was a major goal for this project
"...if you don't like the price then move on because I don't give a shit...it's my bike and I will sell it for whatever I want." Craigslist SF posting
ramon is offline   Reply With Quote
Old 04-18-2013, 09:08 PM   #685
JimmyTheHog OP
Oddometer: 735
Regards
Rod
I don't think the extensions would be a good solution - at least the way I made them. They would probably need another bolt to stabilize them instead of just the one bolt at the original axel position. Then drilling a hole in the swingarm for that bolt would add a weak spot that may crack in time. Maybe for mild riding they might last, but I wouldn't trust them for hard core dual sporting. That being said, maybe theres a different good solution out there for a bolt on extension....? Also, when you extend the swingarm, the brake caliper moves to the new axel position and you may not have enough or any of the stop bracket left to hold it in place. That would have to be addressed.
Ramon is right. This build was about building a dream from a vision and probably a bike I will have for the rest of my riding days. So, economics went out the window long ago
Jim
JimmyTheHog screwed with this post 04-18-2013 at 09:13 PM
Old 04-24-2013, 08:58 PM   #686
JimmyTheHog OP
Oddometer: 735
The rear shock springs are now dialed in. Took three sets to get it, but its done.
Heres a pic. Full bike pics this weekend...and a long awaited ride
Jim
Old 04-24-2013, 09:33 PM   #687
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,127
Can't wait for the ride report and the pics
Old 04-25-2013, 10:02 AM   #688
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,626
I'm surprised you mounted them with the reservoirs pointing forward. The "usual" orientation is with the reservoirs to the rear.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 04-25-2013, 01:11 PM   #689
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 665
That knob might have something to do with the orientation.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 04-25-2013, 03:41 PM   #690
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 488
Think about what you said........... Can't wait for the full pics!
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Times are GMT -7.   It's 06:07 AM.
