Old 03-11-2011, 09:26 PM   #61
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 636
Here it is. This tank requires a bracket to be welded to the top frame tube to hold a bolt that holds the tank. I'll post pic's when I get to that point...
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 03-12-2011, 04:27 AM   #62
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
Send a message via AIM to johnwesley
Talking
Sweet!!!!!!
johnwesley is offline   Reply With Quote
Old 03-12-2011, 04:30 AM   #63
Kleetus
Kleetus's Avatar
Oddometer: 8
JTH,
Love what you're doing with the Sporty. I've been trying to get the wife's Sporty for a year so I could do something similar but she won't give it up. I had a KLR but sold it. It wasn't a good dirt or street bike in opinion for me needs. I'm planning to keep watching you and Johnwesley's builds. I've known John a few years and he always comes away with fresh ideas and out of the box thinking. any thoughts on what that swing arm will cost?
Thaks...Kleetus
Kleetus is offline   Reply With Quote
Old 03-12-2011, 06:32 AM   #64
JimmyTheHog OP
Oddometer: 636
Originally Posted by Kleetus View Post
JTH,
Thaks...Kleetus
Thanks Kleetus. I dont know what the swingarm will cost yet. We are waiting for the billet to arrive, then we start cutting metal. Once we get into it and find out how many hours of cutting, then we'll have a better idea. I plan to put it thru some rigerous testing to confirm its structurally ok, then make it available if anyone may want one. It will be a bit pricey though. The billet alone costs ~$500.
Jim
Old 03-12-2011, 08:01 AM   #65
Kawidad
Kawidad's Avatar
Oddometer: 3,812
Don't get me wrong, I love billet, but wouldn't it be cheaper and easier and just a good to use tubular steel ala Ducati?
"Deeply flawed people make deeply flawed decisions."
Kawidad is offline   Reply With Quote
Old 03-12-2011, 07:06 PM   #66
JimmyTheHog OP
Oddometer: 636
Cheaper / easier - As a 1-off prototype, Im sure tube steel construction would be much less expensive. Half the billet gets removed which is not economical. In a production run though, it may be a different story - there would be less billet waste if you nest the rough cut arms, and once the cnc program and tooling are done, its a pretty straight forward process to machine.
Just as good - Depending on the design & material, the billet arm can be less weight. The 7075 aluminum has a very high yeild strength (higher than alot of carbon steel tube materials) and is ~1/3 the density (.1 vs .286).
For this design, I went very strong (low stresses) and kept the walls thick. Estimated weight is 13 lbs. Not the lightest but I want it to take off-road abuse without worry.
Ok - enough BS - the real story ~ I just love billet
Jim
Old 03-13-2011, 07:32 AM   #67
JohnBoy777
Pseudo-Adventurist
JohnBoy777's Avatar
Oddometer: 833
Hey JTH,
Which tank is that? Seems to work well w/ the design.
Have you entertained the thought of offering a kit?
Cheers
John
JohnBoy777 is offline   Reply With Quote
Old 03-13-2011, 08:55 AM   #68
JimmyTheHog OP
Oddometer: 636
Originally Posted by JohnBoy777 View Post
Hey JTH,
Cheers
John
The tank is from Storz Perfomance - alloy dirt track tank. Its super light, weight is kept low, and doesnt interfere with the tripple clamps when turning. Holds 2.75 gal.
http://www.storzperf.com/jpgs/page27.html
Yes - Im thinking about doing a kit. I have wanted an HD DS for years and wished someone had a nice dual sport kit that I could start from, but never found one. Just kept seeing one-off builds that kept my interest going.
My thoughts are that it would include the swingarm and the other brackets/components I made shown in this thread, and then my build notes for all the other purchased components and how they get assembled / modified. The challenge will be to see how low a cost I can offer the swingarm & components. If its too expensive, it will be a tough sell. Theres still some work to do on the exhaust, rear frame, and seat, so it may be a while - the day job gets in the way of going faster.
Jim
Old 03-13-2011, 03:09 PM   #69
JimmyTheHog OP
Oddometer: 636
Started the seat mock-up today. I want a single seat that is narrower and a bit taller than the stock sporty seat, and uses the same stock mounting. So, Im starting with the stock seat pan and foam and trimming to my likes.
Here is the seat pan trimmed...
Jim
Old 03-13-2011, 03:11 PM   #70
JimmyTheHog OP
Oddometer: 636
The other side - still has the stock mounting brackets...
Jim
Old 03-13-2011, 03:13 PM   #71
JimmyTheHog OP
Oddometer: 636
Now shaping the foam. Its not quite tall enough, but the shape is pretty close to what I want.....
Jim
Old 03-13-2011, 03:21 PM   #72
JimmyTheHog OP
Oddometer: 636
Looks pretty close. Now just need to work with a local seat builder to take it from here - They can do a much better job than I - and make it available to others....
Jim
Old 03-13-2011, 03:27 PM   #73
JimmyTheHog OP
Oddometer: 636
...And my sad attempt to cover it. I used the stock cover and stretched / stapled it on. The professsional seat will look much better, but I wanted to get an idea of how it would feel and look......
Jim
Old 03-15-2011, 06:08 PM   #74
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 629
One thing that is often totally overlooked (even in fairly highly engineered designs) is that aluminum does not have a fatigue limit, but steel does. What this means is below a certain level of cyclic stress, a steel part will last literally forever without failure due to fatigue. On the other hand, there is no minimum level of cyclic stress that an aluminum part can take without eventual failure due to fatigue.
In practical terms, it might take so many cycles to failure that the aluminum part will last virtually forever, i.e. it might never get to the number of cycles required to cause a fatigue failure. And just because steel has a fatigue limit doesn't mean that a steel part won't be designed such that it is stressed above the fatigue limit.
Does any of this really matter in here? Nah, let's just see this beast run!
Lutz is offline   Reply With Quote
Old 03-15-2011, 08:14 PM   #75
JimmyTheHog OP
Oddometer: 636
Lutz - Good point - I'll be doing the fatigue analysis soon.
Jim
Times are GMT -7.   It's 12:07 PM.
