Old 06-11-2013, 08:13 AM   #736
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Just to clarify, I purposely ran the exhaust end just below the airbox inlet that way when I hear the exhaust get muffled under water I know I am getting dangerously deep to flooding the intake.
You can not see it from the pics because I am standing taking the pic from higher angles, but the pipe outlet is the same height, maybe slightly above, the top of the tire, it is pretty high.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 06-11-2013, 09:46 AM   #737
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,183
Originally Posted by WhicheverAnyWayCan View Post
larryboy and kellymac,
Looks good and thanks for sharing the idea.. you don't worry about the river crossing? And I am curious what type of side box or side bag do you use? Any pic of them on with exhaust like that?
I've had a Buell Ulysses and never worried about the exhaust, I have my 1150GS setup the same. I really like a balanced looking bike with the hard bags tucked up tight and no muffler to burn a passenger. As long as the engine is running the exhaust pushes out the water.
larryboy is online now   Reply With Quote
Old 06-11-2013, 02:02 PM   #738
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,131
Originally Posted by larryboy View Post
That bike is bad ass! Have any more pics
"...if you don't like the price then move on because I don't give a shit...it's my bike and I will sell it for whatever I want." Craigslist SF posting
ramon is online now   Reply With Quote
Old 06-11-2013, 11:36 PM   #739
Te Hopo
AKA Deanohit
Te Hopo's Avatar
Oddometer: 1,694
http://advrider.com/forums/showthread.php?t=726304
Well worth the read, and of course check out the subsequent ride reports
Te Hopo is offline   Reply With Quote
Old 06-12-2013, 08:55 AM   #740
WhicheverAnyWayCan
Deaf Biker
WhicheverAnyWayCan's Avatar
Oddometer: 997
Ordering the chainsikle today.. wondering where did you get the peg and who is the maker? And is it a permanent fix or will it move backward and revert back to the position loosely like dual sport bike? I would hate to risk the damage if there were a spill because peg is a permanent fix. I was hoping for XR pegs at $20 a set but Shane told me that the size of peg would not fit in.
WhicheverAnyWayCan is offline   Reply With Quote
Old 06-12-2013, 07:50 PM   #741
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
The peg is from Joker Machine. They have two versions - short and long. I picked the short to keep the bike width narrow. I don't remember if I bought it direct or from a distributer (i'll check). It mounts to the Chainsickle rear sets with a pivot bolt and pivots vertically upward which is different than a typical dual sport or dirt bike peg where their pegs usually pivot at a 45deg angle up and backwards. But, they do still pivot, so if(when) the bike falls over, it should rotate up. Dog paddling in sand though, or foot down sliding in a dirt corner is where its good to have the 45deg pivot so they give when your leg calves hit the pegs.
I used the stock Sportster spring clips on mine too to prevent the pegs from rattling. When you lift the peg up, it doesn't go back down by itself. You need to push it down.
Im considering changing to a more dirt oriented 45deg peg for mine now. I just need to change my mounting brackets that bolts on. I think the Joker Machine is a nice looking peg and it works fine for most riding, but in a crash or dog paddling, Id like a 45geg type with spring return. Personal taste.
Maybe you can modify the clevis width that the XR peg would fit into to make it fit?
So far, I haven't dropped mine to crash test them, so cant help there
Forgot to add - the chainsickle rear sets are fairly high and back, so for standing, it may not be ideal. I worked with Shane on custom lower brackets and new shift linkage that helped, but ultimately I had to make my own to get the pegs where I wanted them. Anyway, Shane's a good guy and im sure he'll work with you if needed.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 06-14-2013, 08:36 AM   #742
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,183
Hey Jimmy, are you going to be able to get any pictures when they start fab on your pipes? It'd be cool to see a real pro at work. Assuming they'll use your bike for mockup?
Old 06-14-2013, 10:04 AM   #743
JimmyTheHog OP
Oddometer: 741
I should be able to post some pics of the progress. Were scheduled to start 2nd week of July and the bike will be used for the mockup.
Im working with Curt at BTR Moto. You can check out his website to see some of his work. Very talented!
http://www.btrmoto.com/index.html
Jim
Old 06-15-2013, 10:01 AM   #744
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,183
Oh that's right, I've seen their stuff before...good choice for the pipe build, they "get" it.
Old 06-25-2013, 11:50 AM   #745
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
Bikeexif
this should expand coverage just a bit, sadly no mention of ADV rider though.
http://www.bikeexif.com/dual-sport-motorcycle
Kai Ju is offline   Reply With Quote
Old 06-25-2013, 06:02 PM   #746
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 502
Good shoot! This should help get the news out.
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 06-26-2013, 11:34 AM   #747
MichiganMachete
Oddometer: 83
Check it out!
http://uncrate.com/stuff/carducci-sc...rt-motorcycle/
Pretty big deal! It's top of the front page right now.
MichiganMachete is offline   Reply With Quote
Old 06-27-2013, 07:49 AM   #748
JimmyTheHog OP
Oddometer: 741
For future press releases, I'll try to get ADVrider in there as you all helped a lot in this build.
Thanks for the Uncrate link.
Jim
Old 06-27-2013, 08:23 AM   #749
JimmyTheHog OP
Oddometer: 741
Hey Everyone,
We received an email that our website is un-viewable in a different country outside the US.
It would help if you could let us know what country youre in and if our website front page is viewable to you.
Thanks for the help.
Jim
Old 06-27-2013, 11:47 AM   #750
Bambi
Bambi's Avatar
Oddometer: 722
Hello Jimmy,
works fine in Germany!
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
