Old 03-26-2011, 08:11 AM   #91
Grizzlybear
Oddometer: 511
Hi Jimmy, Have been following your project so far without comment but with great interest as an ex Sportster owner... so my question is, why did you opt for the 883 over the 1200 given that the weight is virtually identical but of course HP and torque is significantly greater with the bigger motor. Dave
Only a biker knows why a dog sticks its head out the window.
Current rides: 2009 Triumph Scrambler, 2013 KTM Adventure 1190
Grizzlybear is offline   Reply With Quote
Old 03-26-2011, 04:25 PM   #92
cardoctor1
cardoctor1's Avatar
Oddometer: 532
wow arm looks great . what was the cost to have it made
IBA#35592
RIDE EVERY RIDE LIKE ITS YOUR LAST
00 R1150GS
cardoctor1 is offline   Reply With Quote
Old 03-26-2011, 08:47 PM   #93
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 714
I felt that the stock 883 would have enough torque/power for the kind of dual sport off roading i like to do. But, being that I have never ridden a Harley off road, it will be a learning experience. If it turns out I want more, then I'll tear into the motor for more umphf.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is online now   Reply With Quote
Old 03-26-2011, 08:52 PM   #94
JimmyTheHog OP
Oddometer: 714
Thanks for the compliment. The cost is still TBD.
Jim
Old 03-26-2011, 08:58 PM   #95
JimmyTheHog OP
Oddometer: 714
Swingarm test fit
I got the call early this morning that the swingarm was ready to be picked up for a test fit before finishing, so within a few hours, it was picked up and installed....
So far, so good. No interferences. Fit is perfect.....
Jim
Old 03-26-2011, 09:00 PM   #96
JimmyTheHog OP
Oddometer: 714
Rear wheel fits fine - plenty of clearance to the arms.
Jim
Old 03-26-2011, 09:07 PM   #97
JimmyTheHog OP
Oddometer: 714
Chain installed and alignement is good. With so much travel, the chain tensioner is really required. It took all 120 links too (23/51 sprockets +4" extended swingarm). When swingarm is at full travel, the chain tension is just right.
Jim
Old 03-26-2011, 09:12 PM   #98
Grizzlybear
Oddometer: 511
A real nice piece and one that will become the major focus when the job is finished. Have you thought about junking the heavy OEM disc and caliper for something off a jap enduro bike such as the much lighter DRZ400E item. Just a thought but I guess you will have already pondered the pro and cons of this route.
With a nice long swingarm, controlled rear wheel slides on the dirt should be childs play! I can see a 1200 conversion kit coming soon! I think that you will find the 883 a bit flacid in the power dept.
Old 03-26-2011, 09:13 PM   #99
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,599
Question
That is really looking great man.
did you end up with a offset front sprocket ?
johnwesley is online now   Reply With Quote
Old 03-26-2011, 09:16 PM   #100
JimmyTheHog OP
Oddometer: 714
Now the wait for the shocks - theyre scheduled to ship week of April 11 .
Still plenty more work to do though. Rear fender, lights, rack and the exhaust are next. And yes, that seat must go - Corbin will do an nice job Im sure...
Jim
Old 03-26-2011, 09:22 PM   #101
JimmyTheHog OP
Oddometer: 714
Yes on the discs ! - They are opposite as they should be. The rear is thick, heavy, and too large a diameter, and the front is thin & smaller dia. Im going to ride it for a while to see how they work, but I do want to reduce the size of the rear and put a smaller lighter caliper on there.
Jim
JimmyTheHog screwed with this post 03-26-2011 at 09:29 PM
Old 03-26-2011, 09:25 PM   #102
JimmyTheHog OP
Oddometer: 714
Thanks John - Yes, I did go with an offset. I believe its ~0.25" offset. The chain clearance to the motor is fine. Without the offset, the 530 chain was too close and appeared that there would be interference. I ended up going with PBI sprockets in a kit from Zippers.
Jim
Old 03-26-2011, 09:28 PM   #103
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,599
thats what I found too that the zero offset rubs the cases. so mine is off-set some not sure what spacers I may need for the rear to line up properly
guess I'll figure that out in a few weeks as everything get put on and check alignment
Old 03-26-2011, 09:37 PM   #104
JimmyTheHog OP
Oddometer: 714
The rear sprocket I have from PBI has a dish offset - no spacers required. The front sprocket is offset with an increased length spacer (which was smaller dia by the way) that replaces the stock spacer. Due to the smaller dia spacer, the dynamic seal also gets replaced with a smaller diameter seal. The guys at Zippers walked me thru the changes and were very knowledgable / helpfull.
Jim
Old 03-26-2011, 09:48 PM   #105
Snr Moment
Unafarkler
Snr Moment's Avatar
Oddometer: 2,204
Beautiful work! Maybe I should have kept my 03 Hugger.
A K&N filter, rejet, and a 2:1 exhaust from RB racing and the 883 will poke along pretty well.
Love is blind, marriage is an eye-opener.
YAAK
Snr Moment is offline   Reply With Quote
Times are GMT -7.   It's 05:20 PM.
