Old 07-29-2011, 07:00 PM   #211
genka
SUV hater
genka's Avatar
Oddometer: 935
Originally Posted by GEIGERRIG View Post
Also...please forgive us for our logo placement on our product. We have so many people out there removing the guts of their traditional hydration pack and replacing them with a GEIGERRIG Hydration Engine. We'd like people to know that there is a patented GEIGERRIG Engine under the hood.
Purchased a RIG700 and I can see why people do it. The hydration engine is brilliant in many aspects, but disappointed by the backpack design. I expected a separate insulated compartment for the bladder, but it just sits in uninsulated pocket in the main compartment. And why the main compartment needs 2 zippers?
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is online now   Reply With Quote
Old 07-30-2011, 12:28 AM   #212
Edwood
Oddometer: 9
Since Hydrapak is the OEM manufacturer for most of Geigerrig's hydration engine. Looks like you can buy their components for drinking tubes to use with our Hydration Engines right now if you wanted.
http://www.hydrapak.com/store-2/#ecw...=0&sort=normal
The bite valve used in the Geigerrigs are the Hydropak Surge Valve. Looks like the other bite valves might work too. There is an Insulated Tube Kit with a straight bite valve and Cover. The Plug-n-Play connector looks exactly the same. For the minimalist Bite Valve Cover you could just buy the Straight Bite Valve with Cover and just use the Cover.
Hey, Geigerrig.
Can you look into getting the Hydrafusion Tube to offer for sale separately? http://www.hydrapak.com/hydrafusion-tube/
Has a nifty cap and much less bulky than neoprene cover. Would be a nice upgrade to the stock Tube with Surge Valve.
-Ed
Edwood screwed with this post 07-30-2011 at 01:02 AM
Edwood is offline   Reply With Quote
Old 07-30-2011, 09:55 AM   #213
GEIGERRIG OP
Oddometer: 96
GEIGERRIG Info
Hey There Inmates,
A couple of thoughts to the comments immediately above.... By the way, THANKS FOR ALL THE COMMENTS!
1) RIG 700: You are correct that the bladder loads into the main compartment. Please note though that there is a separate Nylon sleeve within the compartment that is to host the Hydration Engine when loaded in there. We haven't been packaging the packs with the Hydration Engine loaded into the sleeve, and we are considering doing that from now on. However, when we first started going, we wanted the hydration engine to be more visible to the consumer because of the differences in construction and fabrication. We didn't want it hidden in the separate nylon sleeve. I know that what I am describing isn't an entire different chamber in the pack for the hydration engine, but it is a separate compartment/sleeve within the main compartment.
2) OEM Hydrapak: When we began building the GEIGERRIG, we wanted to work with a company that focused solely on the construction of hydration bladders. Hydrapak does that. Many of the other companies OEM their bladders from factories and companies that build all kinds of things, and thus the bladder construction may not receive the necessary attention that it needs and deserves. With Hydrapak, we were happy to be working with a company that really takes quality construction seriously. We have a good relationship with Hydrapak to build the patented GEIGERRIG system. As to some of their other components... we are working with them to consider integration into our packs. Some we will choose to use while other we will forgo in lieu of our own designs and engineering. We are working on all kinds of systems that will be of benefit to all. Keep an eye out on our website.
Hope you all are having a great weekend....have fun riding....be safe.
GEIGERRIG
GEIGERRIG is offline   Reply With Quote
Old 08-06-2011, 03:37 AM   #214
Apachezulu
Apachezulu's Avatar
Oddometer: 30
Hey There Inmates,
GEIGERRIG
Mine arrived today and no assembly required! Filled her up and went for a ride...couldn't be happier!
Thanks for the GREAT product and fast shipping! I Likey!
Apachezulu is offline   Reply With Quote
Old 08-09-2011, 09:45 AM   #215
flyingreg
just ridin' along
flyingreg's Avatar
Oddometer: 240
1200 camo rig just ordered. I'll be watching for the mailman again.
Thanks Geigerrig and ADV inmates.
Greg
"Illegitimis Non Carborundum"
2010 KTM 990 Adventure
flyingreg is offline   Reply With Quote
Old 08-09-2011, 04:46 PM   #216
Daryl D
Oddometer: 49
1200 camo set up
Just received the 1200 camo rig. Looks great and well made. I will try it out this weekend on a duel sport camping trip to the high Sierra's.
Thanks Bob (at Geigerrig) for all your help with the questions
Daryl
Daryl D is offline   Reply With Quote
Old 08-09-2011, 05:01 PM   #217
Edwood
Oddometer: 9
Just tried my Geigerrig Hydration engine on a mountain hike this weekend. Summit was only just under 10K feet. I have the 3L Engine, and at around the last liter or so (a little less) the spraying stopped working. I had to suck the last bit of water. So the "Never Suck Again" is not true if you need to use all the water in the Hydration Engine. At least at higher elevations.
Fortunately the bladder is very easy to clean, but it sucked (no pun intended) to have to suck so much to get the last bit of water out of my Hydration Engine.
-Ed
Old 08-10-2011, 10:05 AM   #218
GEIGERRIG OP
Oddometer: 96
Edwood - Sucking Sucks
Agreed that sucking sucks! Always.
Please feel free to give our office a call at 801-823-3336 or 801-823-3335, and we'll see if we can provide a bit of helpful advise to keep the spray going.
Once you've sprayed.... It can be very frustrating to suck. We know. Let's see what can be done to help.
Please ask for Curt or Bob.
Sincerely,
Bob Geiger
GEIGERRIG Hydration Packs
Old 08-12-2011, 02:06 PM   #219
GEIGERRIG OP
Oddometer: 96
You choose: Less thorough product overview....with a blonde or More thorough product overview...no blonde....
Old 08-12-2011, 07:49 PM   #220
lostmarbles
lostmarbles's Avatar
Oddometer: 1,869
just put a order in for a GEIGERRIG Hydration Packs i'll give a update when it is in hand and can put it
through the work on the trail
My wife says that I have lost my marbles.
Don't tell me the skies the limit when there are footprints on the moon.
Have you seen my marbles?
you can't be lost if you still have half a tank
save 5$ on smugmug.com coupon #----(DE9oGz4LoiNZA )
lostmarbles is offline   Reply With Quote
Old 08-17-2011, 05:20 AM   #221
funsummer
funsummer's Avatar
Oddometer: 70
500 review
ok well i have now tested the 500 rig for about 6 months, got it with the filter and spare tube a few weeks later after rig arrived.
Firstly, it has being a great product, and i am happy i purchased this unit.
Ok, my concerns.
1-the waist strap, it fits me just, i am size 38 pants, 6'2 tall, 107kg and wear revit full sand suit, also wear kidney belt.
it could be a little bigger as i am not small but its tight, especially if i have stuff in my jacket pockets. Beer belly's will be in trouble.
2-the chest strap can be a little tricky, i wear a leatt neck brace and it is a little tricky to put the rig on and get it to sit in right place on brace. But once on it sits in the right place and fits well. To remove it is hard to try get the chest clip released.
I dont have a simple solution to this but could geigerrig look at the fitment when a leatt brace is being used?
3-the bite valve, i have lost a lot of water when offroading from not closing the valve. when the valve hits my forearm during aggressive riding it is opened causing the water loss. This is worse if the tube is left unclipped from shoulder strap.
i have being closing the valve manually and this helps combat the problem.
4-the bite valve closing mechanism, in the dark it is not possible to tell if the valve is in the open or shut position.
Can the valve have a more clearly designed marking and or shape so it can be easily identified as open or shut.
5-capacity, 2L is not enough for hot days, option of second loop to hang second bag or 3L bag that fits small packs would be good.
6-i have being looking at buying a new pack with the 3L bag, rig 1200 i think, from your website i could not ascertain what pockets the bag has/ internal/external and general arrangment and size comparision to the smaller 500 that i own. I was lucky enough that a army surplus store in my home town stocked your product so i was able to personally check the 1200 out. Your website could do with a better comparison / information page to make selection a bit easier.
Please understand that i am very happy with the product i purchased from your site 6 months or so ago.
It is tough and dependable.
the bite valve cap is a very welcome addition as once covered in mud, even with the water squirting it still has a texture like mud and water.
Thanks for a great product.
Joel
funsummer is offline   Reply With Quote
Old 08-18-2011, 11:22 AM   #222
Gargoyle
Trail Jester
Gargoyle's Avatar
Oddometer: 1,006
The 3L bag will fit in your RIG 500. It fits in mine.
'11 Husaberg FE570S
'12 KTM 990
'13 Husaberg FE350
Berkshire Trail Riders on Facebook or follow me on Twitter
Gargoyle is offline   Reply With Quote
Old 08-18-2011, 07:10 PM   #223
funsummer
funsummer's Avatar
Oddometer: 70
Thanks Gargoyle,
i think i will get the rig 1200 and take the 3l bag from that and have the versatility of a big and small bag.
i much prefer not having a tank bag when its rough.
Joe l
Old 08-19-2011, 07:40 PM   #224
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
Love my Rig 700 for its convenience & build quality, but two things continue to irritate:
First and foremost, I cannot make the water stored within taste like anything but the hot vinyl garden hose you drank from at least once as a kid. It's horrid, and I dread every swig I can so easily take from it. Yes, it's been washed. I even left water in it for a couple of weeks hoping that taste would go away, but no luck.
Second, the hose from the pump bulb to the bladder comes off far too easily, and generally I only notice after I have gotten underway. A minor gripe, really, compared to the first one.
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 08-20-2011, 06:53 AM   #225
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,511
Taste
I turned mine inside out and stuffed a water bottle in it so it would stand up in the dishwasher and ran it through the meg cycle 5 or six times until the taste went away. That was a few months ago and now I find the taste is back a little but pretty mild. I'm happy now.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Times are GMT -7.   It's 06:18 AM.
