Old 02-05-2011, 06:09 PM   #1
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 2,351
The 12X12 build...
I'm calling this the 12X12 build because it's all being built in my 12X12 shed.The bad part of this is that the door is not big enough to get the bike with the car attached thru it.Anyway,I have been planning this build for over a year,I have been asking lots of questions and sourcing parts.Today I bought all the steel for the frame ( I used 1.5"X1.5"X.120 )..$65.00,not to bad I didn't think.My goal is to complete this for under $1,000,( if I buy the subframe from DMC,that budget is shot to hell).So here is what I got done today.
2012 Honda NC700X..THE SILVER BULLIT
1982 GS850G..BLACK SUNSHINE..The tripod !!
GS500PE..THE PURPLE EXPLORER
So what your saying is that I have the worst hack AND a smelly wife??.
MY BUILD http://www.advrider.com/forums/showt...=657673&page=6
NortwestRider is offline   Reply With Quote
Old 02-05-2011, 06:12 PM   #2
boxertwin
Oddometer: 1,006
boxertwin is offline   Reply With Quote
Old 02-05-2011, 06:14 PM   #3
NortwestRider OP
Oddometer: 2,351
Here's some more pics.
Old 02-05-2011, 07:10 PM   #4
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,431
Time to fit that shed with a w-i-d-e-r door?
'77 BMW R100RS with Ural chair
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 02-05-2011, 07:52 PM   #5
NortwestRider OP
Oddometer: 2,351
I thought about that,but the way the yard is layed out it would be difficult.I will pull the bike in and fit it all up and then take it off and reassemble outside.It sounds like a pain in the ass and I'm sure it will be,BUT" ya work with ya got "!!
Old 02-05-2011, 08:56 PM   #6
NortwestRider OP
Oddometer: 2,351
I have the room for a nice garage,but I lack the $$$$.I will have one next year,but the hack can't wait.!!!
Old 02-06-2011, 12:15 AM   #7
brstar
brstar's Avatar
Oddometer: 393
Thumb Shed
I feel spoilt now I got 4metres by about 9metres. That would be 13' x 29' ish.
But no door apart from some crates. Still the show must go on. The american system for wall thickness in tubing I don't get. I remember the imperial measurement days as an apprentice. But we used fractions of an inch more if I am correct and for sheet metal it was a certain gauge thickness. I think 10 gauge is 1/8th inch thick. I suppose yours is in thousanths of an inch correct?
Cheers Bruce.
brstar is offline   Reply With Quote
Old 02-06-2011, 03:35 AM   #8
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 489
Brstar, .120 is the same as 11 ga. and some call it 1/8 inch.
cleatusj is offline   Reply With Quote
Old 02-06-2011, 04:38 PM   #9
NortwestRider OP
Oddometer: 2,351
I was going to use 1/4" thick but I thought that might be over kill.I can get good penetration with my small fluxcore wire feed welder with .120.
Old 02-06-2011, 05:12 PM   #10
NortwestRider OP
Oddometer: 2,351
A little progress today..
Old 02-06-2011, 05:13 PM   #11
NortwestRider OP
Oddometer: 2,351
Ahhhh,the wonders of modern tech,a laptop on the frame with pics of my new suspension ( thats not here yet)..
Old 02-06-2011, 06:33 PM   #12
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 489
With out them little advances you can't get to the end.
Old 02-06-2011, 06:52 PM   #13
NortwestRider OP
Oddometer: 2,351
I have till May to finish,BUT I'm hoping for the end of March.The next 2 weekends are a bust.Next weekend is a romantic get away to the ocean( the happier SHE is the more sidecar stuff I get),the next weekend is S/TEP class.
Old 02-06-2011, 07:59 PM   #14
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 489
I understand keeping her happy after 33yrs. I'll be taking her to photograph eagles.
Old 02-07-2011, 02:56 AM   #15
brstar
brstar's Avatar
Oddometer: 393
Gauge
Typical even your gauge sounds different.
1/8th inch is close as to 3mm so 1 1/2" by .120 is now let me see 25.4 to the inch plus 12.7 is 38.1 mm x 3mm wall thickness. Yup should do good.
Nor West I have a wire feed welder as well but we run 240volts so It may have a bit more bite. I max out at about 3/8th 10mm when its being joined to something a lot thinner so useful for brackets as well. I have a 15amp power point as well that helps make the most of domestic supply.
Lookin good.
Happy wife. happy life.
Cheers Bruce.
Times are GMT -7.   It's 06:57 AM.
