Old 03-28-2011, 06:14 PM   #136
drbike
drbike's Avatar
Oddometer: 219
The chevrons on the front of the car look really good it sort of matches the lights on the bike. Great looking rig you got there!
drbike is offline   Reply With Quote
Old 03-28-2011, 06:33 PM   #137
boxertwin
Oddometer: 998
Originally Posted by NortwestRider View Post
Ya,the chair wheel came up and the whole kit and kaboddle went HARD RIGHT !!.I have all the parts for the new sidecar suspension and I'm taking Wed off from work to get it done.I will take you up on that beer in Chelan !!
What is your plan for your new suspension?
boxertwin is offline   Reply With Quote
Old 03-28-2011, 06:34 PM   #138
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 2,354
I never noticed how they match up ( I guess I was sooooo focused on getting her on the road !!).I have a 6 LED offroad light that is going just in front of the sidecar step behind a rock gaurd that matches the headlight guard..Here's another pic of the ground clearence.
2012 Honda NC700X..THE SILVER BULLIT
1982 GS850G..BLACK SUNSHINE..The tripod !!
GS500PE..THE PURPLE EXPLORER
So what your saying is that I have the worst hack AND a smelly wife??.
MY BUILD http://www.advrider.com/forums/showt...=657673&page=6
NortwestRider is offline   Reply With Quote
Old 03-29-2011, 03:23 AM   #139
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 491
Throw 2-3 bags of Quickcrete or sand in the tub and take it for a ride on a rough route to stress the suspension. It might just loosen up.
cleatusj is offline   Reply With Quote
Old 03-29-2011, 07:31 PM   #140
NortwestRider OP
Oddometer: 2,354
The guy who built NOW says it will only have 1 1/2" of travel when totaly broke in.I talked to a trailer supply shop here ,and they said that it would never be compliant enough for what I want to use it for unless I run a very low tire pressure.I have another idea for the suspension that I will install tomorrow.IF it works I will let you guys know what it is,if it doesn't I will keep my mouth shut about it..hehehe.
Here is the frame without the tub.
Old 03-29-2011, 07:54 PM   #141
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 370
Thumb
Now that's the shot I wanted to see.
How about one from the rear, center - about 2 feet off the ground.
Interesting build, looks stout. Too bad about the oversprung tub.
You'll sort it out.
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 03-29-2011, 08:19 PM   #142
NortwestRider OP
Oddometer: 2,354
Here's another veiw.
Old 03-29-2011, 08:20 PM   #143
NortwestRider OP
Oddometer: 2,354
1 more.
Old 03-29-2011, 08:42 PM   #144
TouringDave
Ok Human Let's Ride!
TouringDave's Avatar
Oddometer: 6,392
Alan, looking good
Fantastic how every outfit is different.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 03-29-2011, 09:02 PM   #145
NortwestRider OP
Oddometer: 2,354
Thats the best part of building your own,you make it like you want it.I REALLY wish we could all ( Vstrom hackers ) get together and compare them side to side.I had a VERY clear vision of what I wanted before I started and with the exception of the tub ( it kinda landed in my lap ) it turned out like I wanted.I plan to spend alot of time in the woods/mountains with this rig doing some research, (I have waited almost 30 years to do) and that was my goal when I started this project.As you can see I added extra mounting tabs on all 4 corners so I can mount a box to carry everything when I go solo and take off the tub.
Old 03-29-2011, 09:23 PM   #146
Speed Triple
Oddometer: 24
See, this is the part that took me so long to get mine out of the shed. I had at least 3 different suspension setups on mine before it ever saw daylight! Have you considered lengthening the swing arm part of your existing set up? Obviously you'd have to remount the pivot point forward, just a thought. It'd be pretty easy to calculate the desired length, as you know how much it travels now with the length it is now. Double it's length with the same weight on it and it will move twice as far. I'm interested to see your solution!
Lookin' good so far!
Speed Triple is offline   Reply With Quote
Old 03-30-2011, 08:43 AM   #147
NortwestRider OP
Oddometer: 2,354
I thought about making the swing arm longer BUT it sets INSIDE the wheel so it can only be made 2 inches longer before it hits the wheel.I would have had to make a dogleg in it to clear the wheel.I'm heading out to the shed in 5 minutes ( heavy rain and 35mph winds !!) and I will emerge victorious !!!!!!!!
Old 03-30-2011, 07:02 PM   #148
NortwestRider OP
Oddometer: 2,354
So after 8.5 hours in the shed (and 2 running for parts and lunch.)I think I won the battle.The new suspension is done and primered,I still need to remount my fender,wheel sets about 2 inches farther out.Also I need to wire up all the lights and mount the skid plate and step,then hook it up the bike and start adjusting the toe in and lean out and then RIDE !!!!!!...
Old 03-31-2011, 08:05 AM   #149
gryphon51
gryphon51's Avatar
Oddometer: 22
Nice work!
If you are ever headed up BC way I would love to have a look at the finished product, you have done some awesome work there....
Extremely anti-social while in motion...
2009 DL1000 VStrom
Founding Member
Suzuki Owners Club of North America
gryphon51 is offline   Reply With Quote
Old 03-31-2011, 11:59 AM   #150
storch
Oddometer: 101
chelan
Hopefully we can see this rig at the Chelan sidecar rally in May.I plan to be there
storch is offline   Reply With Quote
Times are GMT -7.   It's 12:55 AM.
