03-13-2011, 06:10 PM
#76 |
TRIPOD ADVENTURER !!
Oddometer: 2,347
2012 Honda NC700X..THE SILVER BULLIT 1982 GS850G..BLACK SUNSHINE..The tripod !! GS500PE..THE PURPLE EXPLORER So what your saying is that I have the worst hack AND a smelly wife??. MY BUILD http://www.advrider.com/forums/showt...=657673&page=6 |
03-13-2011, 06:11 PM
#77 |
Oddometer: 2,347
03-13-2011, 06:13 PM
#78 |
Oddometer: 2,347
Front crossover bar ( with cutout for header ).
03-13-2011, 08:25 PM
#79 |
Dirt floor engineer
Oddometer: 487
The actual work is easy but that darn thinking how to will slow things down. It want be long and you;ll be riding.
03-14-2011, 03:55 AM
#80 |
Oddometer: 393
Yes?
03-14-2011, 07:13 PM
#81 |
Oddometer: 2,347
Got the subframes done tonight ( except for the lower mounts ).They came off ok,I just hope they go back on easy,I tried to make sure that I tack welded everything on the bike well.Now I will do all the final welds and grinding and make them look good,paint them and back on before the weekend.I'm hoping that the rig will be ridable by Sunday night !!..This is the RIGHT side..
03-14-2011, 07:15 PM
#82 |
Oddometer: 2,347
And the LEFT side..
03-16-2011, 05:01 PM
#83 |
Dirt floor engineer
Oddometer: 487
Now come on, I don't think you've aged enough to not be able to remember which side goes where.
Ok, I'll go climb back in my box, but I will pop out again.
03-16-2011, 05:53 PM
#84 |
Oddometer: 2,347
Hehehe,that was for BEFORE they got welded on..BUT now that I think about it they were both the same...DUH !!!!
03-19-2011, 07:01 PM
#85 |
Oddometer: 2,347
I got the subframe done today( welded,sanded,and painted),Mounted it on the bike,tightend all the bolts down.Here is where I ran into my first real problem of this whole build.IF I push REALLY hard ( back against a wall and feet on the subframe)I can get the subframe to move side to side about 1/8-1/4 of a inch,in the front.I know that doesn't sound like much BUT the sidecar will put alot more stress than that ( I THINK ??) and I don't want any flex if I can help it.So tomorrow morning I will go back out and sit next to the bike until I find another mounting point for the bottom of the subframe.
03-19-2011, 08:35 PM
#86 |
Dirt floor engineer
Oddometer: 487
Any room for gussets on the cross bar?
03-19-2011, 10:54 PM
#87 | |
The Road Scholar
I have had setups on my Airheads that I swore were rock solid when I "tested" them in the garage that I could see moving when cornering. And those had a full double-craddle perimeter frame that a subframe was attached to. That sucks in a bad way...
Karl Kugler www.theroadscholar.net 2005 BMW R1200RT w/Hannigan-LT sidecar 2002 BMW R1150RA In Memoriam: Harley, 1993-2010 You will be missed. |
03-20-2011, 03:09 AM
#88 |
I be new round here! Ello
Oddometer: 617
or two parralel cross bars with a triangulated section between them.
Guzzi 1100 callifornia stone 2003 Guzzi 1100 california hedingham hack 1994 Ducati GT1000 2006 Suzuki GN250 hack, 'the tiddler' Matchless g3ls 350 1954 and AJS Model 14 250 1961. IBA 40526 |
03-20-2011, 04:25 AM
#89 |
Oddometer: 393
Any pictures for us armchair engineers?
![]() This is what I am in the process of doing to mine to stiffen the connnection at the footpeg mounts. (clamps the brackets to the frame) The rod goes from one side of the bike to the other with just enough room. Hope this helps though yours has a different engine. Mind you I am a bit frustrated by being away from home for a month now apart from a few days with at least a week to go before I finnish the current project. ( its cool though with helicopters and a mountain involved) Look forward to your solution. ![]() Cheers Bruce |
03-20-2011, 10:15 AM
#90 |
Oddometer: 2,347
Well my subframe mounts to the frame below the tank ( between the GIVI crash bar mounts) and to the foot pegs.I DIDN'T go to the centerstand,I wanted to keep it for tire maint.I have a crossbar connecting the front BUT it's just bolted.I was thinkig about welding the cross bar ( if I have to remove the subframe I would just cut it ).I might have to go to the centerstand mounts!!,but that is far back from where the movement is.I wish I had that extra motormount like the 650 has !!!.
I'm heading out to the shed here soon....
