Old 03-20-2011, 07:30 PM   #91
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,209
IT'S ALIVE !!!!!!!.I got it all hooked together today.I still need to pull it apart and do all the gussets and final welds and paint.I ended up gusseting the crossbar and it's better,but I'm gonna go ahead and use the centerstand mounts for support.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 03-20-2011, 07:32 PM   #92
NortwestRider OP
Oddometer: 4,209
Another veiw,I had to shorten the tractor bars by 10"..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-20-2011, 07:35 PM   #93
NortwestRider OP
Oddometer: 4,209
Here it is with the tub on the frame..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-20-2011, 07:37 PM   #94
NortwestRider OP
Oddometer: 4,209
Here's a veiw of the gussets on the crossbar..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-20-2011, 07:39 PM   #95
NortwestRider OP
Oddometer: 4,209
And last but no least..AMPLE GROUND CLEARENCE !!!
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-20-2011, 08:15 PM   #96
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,239
Looking good and that's what I was getting at about gussets on the cross member.
cleatusj is offline   Reply With Quote
Old 03-20-2011, 08:50 PM   #97
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,105
Neat!
Great ground clearance!
05 R1150R....now 2 wheels...soon 3 wheels.
84 Kwaka GT750 Cafe Project & 84 Kawaka GT750 Outfit
TouringDave is offline   Reply With Quote
Old 03-21-2011, 11:32 AM   #98
toastmuncher
I be new round here! Ello
toastmuncher's Avatar
Oddometer: 677
Good job young man, were I closer id nip round for a beer and an inspection.
Guzzi 1100 callifornia stone 2003
Guzzi 1100 california hedingham hack 1994
Guzzi 1000 lemans 5
Guzzi 700 V7 details-mystery
Matchless g3ls 350 54, Ariel 650 huntmaster 56. IBA 40526
toastmuncher is offline   Reply With Quote
Old 03-21-2011, 06:12 PM   #99
NortwestRider OP
Oddometer: 4,209
Thanks for all the support & help guys your ideas are saving my A%$.So I went out to the shed tonight after work and did some messin around and found out something that could put a halt to forward progress.I can't get the sidecar suspension to move !!.It's rated at 250lb,BUT I weigh 285lb and the frame weighs about 100lb and when I stand on it ,it only moves about 1/2 inch ( the back of my bike almost bottoms out !!).My wife only weighs about 150lb so it could be a BUMPY ride for her.I'm going to contact the builder and see if there is anyway he sent me a higher rated one ( I hope he didn't cause it's welded on REALLY well ).OR maybe he has a way to soften it up??..On a positive note,as I was jumping up and down on it I watched the subframe and I COULD NOT see any flex!!,I know that road stresses are higher but I was happy that it stayed put.Also while I was just sitting there thinking about what to do with the suspension I went ahead and mounted my steering dampner.I don't know if I will really need one BUT it will be easier to remove it later than add it on,also it only cost $12.00 with shipping from ebay !!
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-21-2011, 06:22 PM   #100
NortwestRider OP
Oddometer: 4,209
Another veiw..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-22-2011, 03:40 AM   #101
TouringDave
Tri Moto Veritas
Oddometer: 7,105
Originally Posted by NortwestRider View Post
Another veiw..
Nice set up. You will notice the big difference if you take it off.
Old 03-22-2011, 08:05 AM   #102
storch
Oddometer: 108
struts
4 struts on heimjoints are not stable.Put some diagonal struts in.
Gary
storch is offline   Reply With Quote
Old 03-22-2011, 09:41 AM   #103
Steve In Ireland
Steve In Ireland's Avatar
Oddometer: 233
Gary
I was thinking that. Looks like there is going to be a lot of bending stress on the welded ends of the lower struts.
Steve In Ireland is offline   Reply With Quote
Old 03-22-2011, 09:44 AM   #104
toastmuncher
Oddometer: 677
would the damper not work better, longer travel, so it can damp more effectively if it were fitted to the front lower mount area of the subframe. I guess its not getting much travel as it is.
Guzzi 1000 lemans 5
Old 03-22-2011, 02:38 PM   #105
TouringDave
Tri Moto Veritas
Oddometer: 7,105
Time will tell I guess, it's mounted in a similar way to mine and that works brilliantly. It all gets changed when the LL's arrive.
Sorry for the hijack Alan.
Times are GMT -7.   It's 11:27 AM.
