Old 03-22-2011, 07:00 PM   #106
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,064
I need all trhe help I can get.I have no friends,family or people around her with hacks.SOOOO everything I have done I found on here.I'm going to change the bottom mounts and get rid of the joints,and I talked to the guy who built my suspension and he insists that he sent me a 250lb setup.I asked him why with 350+ lbs on it in only moves 1/2 inch,he said it will break in and SHOULD have 3" of movement when worn in some!!.So I will redo the bottom mounts,RE setup all the adjustments ( toe in,leanout etc) and give it a go !!.Do you guys think I should mount the steering dampner to the bottom mount ( strut ) and down to the caliper area??.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 03-23-2011, 05:25 AM   #107
brstar
brstar's Avatar
Oddometer: 463
Thumb
Originally Posted by Steve In Ireland View Post
I was thinking that. Looks like there is going to be a lot of bending stress on the welded ends of the lower struts.
Diagonal braces would be a start here as well as stiffening the lower struts so they dont flex to much up and down. They still need to be adjustable for the chair wheel toe in ( tracking).
Make sense?
You have done pretty well here so far so stick with it.
Test rides are for testing! Hope to hear about yours soon.
Been nearly 5 weeks away on a 2 week job
But should be finnish here in a bit over another week.
Will put up a video of a great place to visit with a hack
brstar is offline   Reply With Quote
Old 03-23-2011, 08:32 PM   #108
BMWzenrider
The Road Scholar
BMWzenrider's Avatar
Oddometer: 1,114
Originally Posted by storch View Post
4 struts on heimjoints are not stable.Put some diagonal struts in.
Gary
What you might have missed is that the lower mounts are actually welded to the sidecar frame, making them rigid on one end. That removes the instability issue that you are talking about...
However, I do think that the lower mount rods would benefit from some angle bracing due to how lightweight they are. Mainly front-back to counter the offset drag on the lower links, and some gusseting on the upright brackets that the upper struts mount to. But that is just my opinion, the lower struts may work just fine as they are if you don't hammer on the throttle/brake.
But I would definitely add some gusseting to the upper mount risers, they will be seeing a large bending stress where they meet the sidecar frame during cornering.
And I think that having the rod ends on the lower mounts to adjust toe-in should provide plenty of adjustment.
Karl Kugler
www.theroadscholar.net
2005 BMW R1200RT w/Hannigan-LT sidecar
2002 BMW R1150RA
In Memoriam: Harley, 1993-2010 You will be missed.
BMWzenrider is offline   Reply With Quote
Old 03-24-2011, 06:30 PM   #109
NortwestRider OP
Oddometer: 4,064
THANKS guys for the advice.I redid the lower mounts tonight and got rid of the joints.I'm also adding braces from the lower struts to the front of the sidecar frame and the back ( also in the middle).After you guys brought to my attention the need to remove the bottom joints I sat down next to it and started to think about it and WHAMMMM it hit me what you were talking about.Here's the new joints..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-24-2011, 06:31 PM   #110
NortwestRider OP
Oddometer: 4,064
On the bike..Also when I pull it all off to do the final welds,I will be gusseting ALL the strut mounts...
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-24-2011, 07:48 PM   #111
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,218
That will cut down on movement.
cleatusj is offline   Reply With Quote
Old 03-24-2011, 07:57 PM   #112
NortwestRider OP
Oddometer: 4,064
I hope so,like I said this is all new to me and YOU GUYS are my only guide..Keep up the comments and help a brother out !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-25-2011, 08:49 PM   #113
NortwestRider OP
Oddometer: 4,064
My goal is to get the bike and car setup,ride it for awhile ( making sure it's right ) and then do what Dave did and mount them together without swivle joints.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-26-2011, 01:32 AM   #114
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,083
Damn! they now look solid! That sucker isn't moving anywhere.
05 R1150R....now 2 wheels...soon 3 wheels.
84 Kwaka GT750 Cafe Project & 84 Kawaka GT750 Outfit
TouringDave is offline   Reply With Quote
Old 03-26-2011, 06:40 PM   #115
NortwestRider OP
Oddometer: 4,064
Add to that pic 4 braces from the bottom struts to the sidecar frame..10 hours in the shed today,frame is DONE !!,just waitng for paint ( tomorrow).Also I added some bracing to the subframe,and got the tub primered..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-27-2011, 02:59 PM   #116
NortwestRider OP
Oddometer: 4,064
Well it's now 3pm and I'm waiting for the paint to dry on the frame,then I can hook them together and go for a test ride.Here's the frame..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-27-2011, 03:02 PM   #117
NortwestRider OP
Oddometer: 4,064
And the finished subframe..I may still need more bracing,but I won't know till I ride it.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 03-27-2011, 05:01 PM   #118
brstar
brstar's Avatar
Oddometer: 463
Thumb Busy
Well you have been busy there NWR you done good so far so stay with it till it's sorted. It is amazing how with 2 very similar machines we can have such different aproaches to the build. Though the left to right is a big change and different chair frames to. I got home on Saturday after 5 weeks away working so hope to have some progress soon. Easter is my goal for a road trip with 2 young friends and don't want to miss it.
Cheers Bruce
Old 03-27-2011, 05:20 PM   #119
TouringDave
Tri Moto Veritas
Oddometer: 7,083
Bruce and Alan, when all the outfits are finished we should all post pics of our different sub frames and chassis.
Old 03-27-2011, 06:27 PM   #120
boxertwin
Oddometer: 1,022
Tub weight?
Hey Northwest Rider,
Do you know the weight of that tub (without the frame, etc?)?
boxertwin is offline   Reply With Quote
Times are GMT -7.   It's 03:26 PM.
