Old 02-08-2011, 05:18 PM   #1
The Raven OP
The Raven's Avatar
Oddometer: 4,811
Lining up the points can right?
I was wondering how to line up my points can. I recall back when I had points on my old CB450 that you had to hook up a light with alligator clips to the points and the other end to the + on a battery. Idea was that when the points closed the light would come on. I don't see why I can't do this with the G/S bean can?
Hook it up, turn the flywheel to S, and rotate the can till the lite comes on. In theory it would be perfectly timed, no?
The Raven is offline   Reply With Quote
Old 02-08-2011, 05:23 PM   #2
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Yep!
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 02-08-2011, 05:28 PM   #3
pommie john
pommie john's Avatar
Oddometer: 1,444
I'd say it was adequately timed , ready to be strobed.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 02-08-2011, 07:53 PM   #4
The Raven OP
The Raven's Avatar
Oddometer: 4,811
I think this would give a more accurate time than a strobe?
Old 02-08-2011, 08:02 PM   #5
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,121
Not necessarily since things can be different when in motion.
Also, check the full advance since that's more important than the retarded setting, and that's difficult to set statically with the points-in-a-can system.
Old 02-08-2011, 09:57 PM   #6
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
I did that when I hooked up my can. Datchew called it 'statically timing'. We did that, then checked it with a strobe and it was right on.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-08-2011, 10:02 PM   #7
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,789
No, since the coil fires when the points open, it's correct statically when the light goes off.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-09-2011, 01:04 AM   #8
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,059
At idle or close to, yes. But worn advance mechanisms will change that fact. So when the engine spends most time at full advance, that is where you want the timing spot-on.
Edit:
Read your post incorrect Anorak.
Old 02-09-2011, 06:24 AM   #9
mykill
odd
mykill's Avatar
Oddometer: 1,166
correct!
yes
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 02-14-2011, 03:53 PM   #10
The Raven OP
The Raven's Avatar
Oddometer: 4,811
I installed the points can today and wanted to verify that the install was done correctly. As the bike is not ready to fire up yet, I used the static method.
This is what I did.
Ohm meter set to ohms. One lead on the can output, the other to ground
rotated engine until S was in the window timing mark. Then rotated the can until I lost continuity. Tightened it with no continuity and less than a millimeter to make contact again.
Is this right?
Old 02-14-2011, 04:07 PM   #11
StephenB
StephenB's Avatar
Oddometer: 2,044
Sounds right and will start the engine no matter what. But you need to check with a timing light once you have the engine running, at idle and full advance.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 02-14-2011, 04:11 PM   #12
The Raven OP
The Raven's Avatar
Oddometer: 4,811
I also ran a single wire up to where the coil will live. Probably 16ga. Is this where the wire is supposed to go?
Old 02-14-2011, 07:12 PM   #13
StephenB
StephenB's Avatar
Oddometer: 2,044
If you're talking points wire then yes. And originally it is a black wire.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Times are GMT -7.   It's 04:30 PM.
