Old 02-11-2011, 12:12 AM   #1
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,059
Considering making my own lift.
Hey guys!
As a part of a workshop course I am attending, we are required to do three projects. Usually people make lathes for turning in wood or a firewood cleaver.
I thought I'd make my own lift. It would need to be a hydraulic lift with an motor on it. But I was thinking I might add some features that are not on the usual ones.
Do you have any thoughts?
How would it be operated? A button on the lift itself or maybe a control set attached to a wire of a meters length perhaps. I also thought of adding some small containers that can hang on the side. You know for nuts and bolts etc.
Other ideas are welcome!
Regards Lasse
LasseNC screwed with this post 02-11-2011 at 09:38 AM
Old 02-11-2011, 09:35 AM   #2
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Interesting project. Consider having a section that can be removed to ease rear wheel removal. Beer holder is always an improvement.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 02-11-2011, 09:44 AM   #3
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,783
Hydraulics are nice but how about a simple electric motor with a gear worm drive from a scrap garage door opener?
Just a thought.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 02-11-2011, 09:58 AM   #4
fishkens
Further...
Oddometer: 5,147
Nice. I definitely want to see this build.
A few built-in compartments for commonly used tools, lubes, etc.
How about some sort of deadening surface treatment to keep dropped pieces from launching into the farthest corner of the shop?
And racing stripes, for sure.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 02-11-2011, 10:12 AM   #5
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,056
Electrical sockets built into the floor of the lift, maybe a bendable light pole for closer inspections?
Definitly tie down points.
Magnetic tray or strap for tools and bolts.
2012 BMW R1200GS
www.TeslaLEDS.com
www.NYMSTF.org - Support NY Riders!
GHO100 is offline   Reply With Quote
Old 02-11-2011, 10:21 AM   #6
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,783
Originally Posted by GHO100 View Post
maybe a bendable light pole for closer inspections.
Or a rigid pole that goes from floor to ceiling for the ladies?....but I digress.
-Winston Churchill
Old 02-11-2011, 11:38 AM   #7
edray
cascadian
Oddometer: 224
sweet project..
the 110 garage door opener is a great concept, specially for guys that dont have 220 or air access..
edray is offline   Reply With Quote
Old 02-11-2011, 11:53 AM   #8
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
I like screw drive, that would be simple, cheap, reliable, and run on 110v
Old 02-11-2011, 11:58 AM   #9
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,059
Those are some very good ideas.
The idea with hydraulics was to learn about hydraulic pressure, dimensioning the whole system. It is first and foremost a learning experience that I am to take with my on my engineering studies.
Old 02-11-2011, 12:49 PM   #10
norton73
drinkin'
norton73's Avatar
Oddometer: 8,306
Wooden Lift
I built this lift about 12 years ago;
It's not hydraulic, just tilts when the front wheel goes over center.
I've thought about modifying it to use a floor jack to tilt it.
Plans came from the Eurospares website
Drawings
Hopefully this will give you some ideas.
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 02-11-2011, 02:59 PM   #11
Houseoffubar
fine beer sampler
Oddometer: 1,782
Nice lift!
I got ya, Hydraulic it is then!
Ebay has some crazy cheap hydraulic rams, and pumps!
Old 02-11-2011, 03:42 PM   #12
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Yeah....
An electric screw type lift would be just the ticket.
The chassis could be similar to the HF lift but with locking caster wheels large enough to make moving the loaded lift, easier to roll around the garage or out into the driveway.
My only real complaint about my cheap-o HF lift is the crappy wheel system.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 02-11-2011, 07:17 PM   #13
fishkens
Further...
Oddometer: 5,147
Originally Posted by mymindsok View Post
Yeah....
Proper casters seem to be crazy expensive. It seems to be the place where costs are cut on all sorts of things.
Times are GMT -7.   It's 09:09 AM.
