Old 02-11-2011, 09:58 AM   #1
LBourque OP
G/S nut
Oddometer: 225
G/S intake manifold
Has anyone tried to repair just the rubber hose section of an 81' G/S intake manifold? Just trying to be frugal or cheap (depends). Part numbers #11711337165 and 166. Thanks
LBourque is offline   Reply With Quote
Old 02-11-2011, 10:32 AM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Those are the 2 air injection hoses for the bogus emissions junk that BMW added in 1981.
99 percent of the BMW airhead world removes the system, as it can be detrimental to your valves and who knows what else in side your engine.
the parts needed cost less than $10.00 from BMW.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-11-2011, 10:35 AM   #3
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,724
Most people ditch that secondary air system and plug the holes... there is some information saying that system adds the exhaust valve temp and causes wear.
Here is a link to the system plugging how-to:
http://www.ibmwr.org/r-tech/airheads...resh_air.shtml
That said, if you want a nice set, I have three complete ones that I took off of airhead and would be happy to send to you for the cost of postage! (the haed to carb tubes and valve-things)
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 02-11-2011, 11:31 AM   #4
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,298
Just plugged Beater's RT the other day and he actually got the fittings from our local Ace hardware!!! 16mm plugs or just weld a ball bearing on the end of the fitting!
Old 02-12-2011, 08:22 AM   #5
LBourque OP
G/S nut
Oddometer: 225
secondary air
I will probably take you up on the offer and TIG a ball bearing and plug it. Will be back in town next weekend and be back in touch.
Lou
Old 02-12-2011, 08:25 AM   #6
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,668
for a neater less botched approach use oil pan drain plugs from a R1150RS. If you start cobbling things together it won't be long till you have a POS looking bike w/ bailing wire and duct tape.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-12-2011, 09:48 AM   #7
hardwaregrrl
ignore list
Oddometer: 7,298
Hey!! What are you trying to say?!.
Old 02-12-2011, 10:18 AM   #8
One Less Harley
Oddometer: 4,668
OOOOPS!!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-12-2011, 10:31 AM   #9
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,724
Lou
OK, they are yours...
Times are GMT -7.   It's 06:12 PM.
