Old 02-11-2011, 08:39 PM   #1
xxxshiftxxx OP
Oddometer: 205
Eek hard wired SAE connector question
So, I put the SAE connection from my new battery tender Jr. On my 800gs. It has a 7.5amp in line fuse.
My question is:
I would like to run a few different things during different situations off that SAE plug. My cell phone (ANDROID with mini usb) and gps (zumo 550). Will that 7.5amp fuse surfice running either one of those? Or is it too much, and cause damage before it blows.
I am an electrical retard.
xxxshiftxxx is online now   Reply With Quote
Old 02-11-2011, 10:14 PM   #2
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 3,994
The Zumo 550 is rated at 2.5 watts max, or about 200 miliamps draw at 12 VDC. (Two tenths of an amp) The phone is probably similar. I doubt you'd pull more than one amp total with both devices together.
As long at you don't try to run a highly resistive load, like a heated jacket liner, a 7.5 amp fuse is more than sufficient for your needs. Remember: a fuse is only to protect the wiring in the event of a short or overload. A device won't draw any more amperage than it needs to operate.
http://www.oilandpiston.com/
Well he’s one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 02-11-2011, 10:48 PM   #3
xxxshiftxxx OP
Oddometer: 205
Cool, thanks....
Old 02-12-2011, 08:44 AM   #4
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,562
I have the SAE connector for the battery tender hooked up to another SAE connector that runs forward to power the 12 socket on the handlebars. Best of both worlds, when you need the SAE for the tire pump or charger, just unplug the splice.
I have this set up on 3 bikes and had it set up that way on two 4-wheelers.
Flashmo is offline   Reply With Quote
Old 02-12-2011, 08:57 AM   #5
xxxshiftxxx OP
Oddometer: 205
Nice, I have a little compressor that runs off a 12v cig lighter. I will look into finding a female cig lighter to SAE. To carry in bag for compressor can I buy this or do I have to make it?
Old 02-12-2011, 09:47 AM   #6
2wheelsrbest
Oddometer: 274
I bought a cig lighter socket and another SAE plug set. Wired together, covered wires with electrical tape and it works fine. I doubt you'd (easily) find one premade, but it is simple construction. Only two wires to connect and color coded!
2wheelsrbest is offline   Reply With Quote
Old 02-12-2011, 10:10 AM   #7
xxxshiftxxx OP
Oddometer: 205
Where is a good place to buy a SAE plug set and cig lighter stuff?
Old 02-12-2011, 10:25 AM   #8
perterra
perterra's Avatar
Oddometer: 7,400
Powerlet has a few different items
http://www.powerlet.com/shop-by-prod...-cables/PWRCBL
perterra is offline   Reply With Quote
Old 02-12-2011, 05:25 PM   #9
2wheelsrbest
Oddometer: 274
schucksoreilyspepboysautozonenapaetc should have them
Old 02-12-2011, 09:08 PM   #10
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,237
Is this what you want? Aerostich
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 02-13-2011, 10:56 PM   #11
tgeliot
Topher
Oddometer: 1,352
I special ordered some through my local O'Reilly. I had to hunt through the catalog they had there. It did not come with the nice little rubber cap that some have. I've been told you can get them at RV dealerships.
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 02-13-2011, 11:04 PM   #12
tgeliot
Topher
Oddometer: 1,352
My question is:
One thing to consider is that in the unlikely event you do manage to short out the relatively thin wires that feed these devices, those wires will melt down before the 7.5 amp fuse burns out.
Myself, I wouldn't worry about it, but if you care you could pull the 7.5 amp fuse and put in a much smaller one (1 amp would probably do).
Topher
Old 02-13-2011, 11:14 PM   #13
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,397
Just go to your local auto parts store for all these pieces on the cheap. I use 12 or even ten gauge wire to set things up. Let the fuse be the weak point, not the wiring.
windigo
Old 02-14-2011, 03:51 AM   #14
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,562
I get mine at a local trailer supply. SAE pigtails are about $2.
Old 02-14-2011, 07:42 AM   #15
tgeliot
Topher
Oddometer: 1,352
Lo and behold look at what I just stumbled across at Harbor Freight.
Topher
Times are GMT -7.   It's 02:41 AM.
