Old 02-14-2011, 12:45 PM   #16
xxxshiftxxx OP
Oddometer: 240
Originally Posted by tgeliot View Post
Lo and behold look at what I just stumbled across at Harbor Freight.
SCORE!! thanks!
xxxshiftxxx is offline   Reply With Quote
Old 02-14-2011, 05:22 PM   #17
jnorton1
Oddometer: 275
I've got an sae plug also on my dakar not sure on the fuse size but what's needed to run heated gear. I have seen sae to coaxial adapters would i need something different.
2001 BMW F650GS Dakar
2009 BMW F800GS
jnorton1 is offline   Reply With Quote
Old 04-30-2012, 01:09 PM   #18
mikeb53
Oddometer: 10
I have a simple connector, SAE in USB out. Plugs right in to your battery tender connector. It's the size of a flash drive and take 2 seconds to install. No splicing, no wiring to install!
Go to: americancrossroaders@yahoo.com for more information.
mikeb53 screwed with this post 07-22-2012 at 11:52 AM
mikeb53 is offline   Reply With Quote
Old 04-30-2012, 01:30 PM   #19
freeflow
get in or go in
freeflow's Avatar
Oddometer: 16,308
Contact me at americancrossroaders@yahoo.com for more information.
vendors forum.
freeflow is offline   Reply With Quote
Old 04-30-2012, 01:33 PM   #20
freeflow
get in or go in
freeflow's Avatar
Oddometer: 16,308
I've got the soultion for getting USB connections on your bike without tapping, splicing or running new wires. Direct connection to your battery tender USB plug. Clean easy 2 second connection at a cost of $45.00 plus shipping/handling..
Old 04-30-2012, 05:04 PM   #21
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,625
Originally Posted by freeflow View Post
No doubt! 2 posts ever on a new account, and they are both Spamming the same thread...18 minutes apart.
Flashmo is online now   Reply With Quote
Old 05-01-2012, 02:55 AM   #22
John Smallberries
John Smallberries's Avatar
Oddometer: 1,322
iPhone
Originally Posted by xxxshiftxxx View Post
So, I put the SAE connection from my new battery tender Jr. On my 800gs. It has a 7.5amp in line fuse.
My question is:
I would like to run a few different things during different situations off that SAE plug. My cell phone (ANDROID with mini usb) and gps (zumo 550). Will that 7.5amp fuse surfice running either one of those? Or is it too much, and cause damage before it blows.
I am an electrical retard.
FYI - the little white cube charger for an iPhone can deliver 1 amp at 5 volts (5 watts). The iPad version is good for 2 amps at 5 volts (10 watts). When the batteries are low, they pull as much current as they can get to charge quickly. By extension, I'd guess your Android phone would pull 5 watts. If you assume a 12volt feed to the USB charger and throw in an efficiency factor, that 5 watts should draw about 0.5 amps from your bike. Your big 7.5 amp fuse should be OK.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 05-07-2012, 08:26 AM   #23
mikeb53
Oddometer: 10
Well Gents,
You may want to do the wiring, soldering and splicing on your bike but, I would rather have an adapter that takes 2 seconds to install and when not in use, takes 2 seconds to remove and all traces of wiring from the SAE connector forward are gone from the bike.
Sorry if I posted to an area that offended but, it is a legit adapter.......
Old 05-07-2012, 08:51 AM   #24
the_gr8t_waldo
Oddometer: 2,159
on the face of it, it sounds like the fuse is way too big to protect a .750 amp charger...if it were me, i'd install a 1.5amp fuse in the charger's line and then up the fuse on the bike to something like 10-15amps. i'd steer clear of cig plugs...they are designed for loads under three amps( they do have one nice attribute- threr's usually a fuse in the plug to protect the device youre useing)...most compressors draw way more. bmw type plugs and recpticals are built for large loads but tought to justify, since heavy use is so rarely needed & only needed for a relativly short period.
the_gr8t_waldo screwed with this post 05-07-2012 at 09:11 AM
the_gr8t_waldo is offline   Reply With Quote
Old 06-18-2012, 12:38 PM   #25
AngryScot
AngryScot's Avatar
Oddometer: 18,325
Well Gents,
Like said above, we have a vendor section you are most welcome to post in. We do now allow direct vendor spam outside that area of the site.
There are ways to communicate without directly linking your site etc :wink
ADV Moderator
⊕R1200GS⊕ For sale soon, snap it up and contact me.
⊕Zuma 125⊕For sale soon, snap it up and contact me.
Save $5 on Smugmug "so9RUAXlMm0bE"
AngryScot is offline   Reply With Quote
Old 06-19-2012, 05:28 AM   #26
Speedo66
Transient
Oddometer: 6,943
This link no longer works.
Anybody know what the item was?
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 06-20-2012, 12:10 PM   #27
tgeliot
Topher
Oddometer: 1,365
(That was me that posted the link)
It was a simple two-conductor SAE connector with pigtail wires at a low cost. Someone else later posted saying "are you really sure you want to go with this low-budget item on your bike, where it will be exposed to the weather, etc.? Here's a link to a better one.". Sorry, I don't have that at my fingertips, but maybe if you search the postings you could find it.
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 06-21-2012, 10:34 AM   #28
mjydrafter
evil boy for life
mjydrafter's Avatar
Oddometer: 4,252
Just go to your local auto parts store, go to the trailer area (hitch balls, connectors and such), there you will find the SAE connector that will plug right in. It usually has the added benefit of having 2 of them, just cut the wires in half and you have to of these connectors at your disposal.
Here is Oreilly's part, opps I guess it's an extension... Oh, and you will want to pay attention to the wire colors if you care, one is the opposite.
Here
1974 Suzuki TC-185 (The little 10 speed)
1986 BMW K75c
Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
mjydrafter is offline   Reply With Quote
Old 06-22-2012, 06:50 AM   #29
tgeliot
Topher
Oddometer: 1,365
At my local store they were special-order items. I've been told that trailer /Rzv stores are.a good place to find them.
Topher
Times are GMT -7.   It's 06:10 PM.
