Old 02-12-2011, 02:44 PM   #1
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
The correct way of soldering two pieces of wire together.
I was wondering, as I am quite new to soldering when working on electrics instead of cramping.
I have two ends of old wire that has been split by PO for some reason, I don't want to tape it up. So I want to solder them and use some heatshrink on it afterwards.
Is it just laying the besides beside eachother? Or do they need to be fixed in some way for it to be stronger?
Old 02-12-2011, 02:55 PM   #2
sieg
sieg's Avatar
Oddometer: 2,856
Tin (melt solder onto them) the ends, lay them together heat till the solder melts. With solder less is more.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 02-12-2011, 02:55 PM   #3
eric123
Gott Mit Uns
eric123's Avatar
Oddometer: 1,495
Here is one way...
http://www.dansmc.com/soldering.htm
eric123 is offline   Reply With Quote
Old 02-12-2011, 02:56 PM   #4
DaveBall
DaveBall's Avatar
Oddometer: 1,163
Strongest method is called a "linesman's splice". Good explanaition here with pictures. http://boost-instruments.com/splicing/splicing.html It does not show the soldering, as it isn't always done, but I always solder any joint. Just remember to put the heat shrink tubing on one of the wires before attaching them together. Don't ask me how I know.
DaveBall is offline   Reply With Quote
Old 02-12-2011, 02:57 PM   #5
JUNAC
Straight Shooter
JUNAC's Avatar
Oddometer: 667
Congratulations,
Soldering is always better than using solderless crimp connectors especially when exposed to the elements. Clean the ends of the stripped wire with some sandpaper or steel wool. The heat shrink should be cut so that it is about a 1/2" longer than the area to be soldered. Place the heat shrink over the wire and keep it away from the area to be soldered. Twist the wires together. Use solder with a flux core. After making the repair let it cool slightly. Slide the heat shrink over the bare wire, heat with lighter or hair dryer. Done. Simple.
IF THERE'S A HOLE, SOMETHINGS GOING IN IT
KTM 950 ADVENTURE MUSCLE BIKE
XR650L WITH THE ARMY BOXES...R.I.P.
http://www.advrider.com/forums/showthread.php?t=640254
JUNAC is offline   Reply With Quote
Old 02-12-2011, 03:02 PM   #6
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
Daveball, that linesman splicing is exactly how I thought I'd do it! Esquependo! (Spelling)
I will have a look at it tomorrow. Now I am just unsure if I have the correct size heatshrink, but it was on offer. 4.8/2.4 mm.
Old 02-12-2011, 03:02 PM   #7
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,768
Yep ,I go with the twist and flux metod. Watch how long you keep the heat on the wires . You want a shiny connection but the longer you keep the heat on ,the farther up the wire the solder will travel making the wire stiff.
Don't forget to slide your heat-shrink on first and keep far enough away from the joint so it's not shrinking too soon.
bk brkr baker is online now   Reply With Quote
Old 02-12-2011, 03:47 PM   #8
Martian
Oddometer: 1,104
And keep the tip of your gun CLEAN! A dirty tip doesn't tranfer heat very well and you'll end up melting the insulation before you melt the solder. To clean the tip, heat it, stick into the can of flux, and then wipe it with a damp rag.
Old, corroded wire is hard to solder. Clean the strands as best you can.
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 02-12-2011, 04:19 PM   #9
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
this is the way I've been doing it for 30 years. Good solder (rosin core) is KEY and also a good iron.
step 1
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-12-2011, 04:20 PM   #10
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Step 2
www.wirewerkes.com
Old 02-12-2011, 04:22 PM   #11
Jasper ST4
Guest
Oddometer: n/a
Good tips. I was an electrician in the Coast Guard so wires often corroded on board ships. Don't just clean the outside of the copper in stranded wire, use a wire brush and clean them well. I also put some flux on the wires when they are hot, seems to help the solder to flow.
Old 02-12-2011, 04:28 PM   #12
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,130
Originally Posted by JUNAC View Post
Congratulations,
In the context of motorcycles, a good solder joint is seems to work fine. In aircraft crimped connections are the rule but done with special crimpers and connectors. Solder can fracture over time in an environment of vibration.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-12-2011, 04:47 PM   #13
Martian
Oddometer: 1,104
...........Soldering is always better than using solderless crimp connectors especially when exposed to the elements..
You can get butt splices that are encased in shrink tubing so they are watertight. As was mentioned, vibration is death to a solder joint. The biggest advantage to a solder joint is it's size. The only time we could solder wires together when I worked on aircraft avionics was if space was a consideration, and the crimp splices couldn't be staggered.
When I worked on yacht systems, we used the sealing crimp splices on systems that were likely to be submerged......bilge pumps, etc. They work really well.
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
Old 02-12-2011, 04:52 PM   #14
Ben Carufel
Boxer Addict
Ben Carufel's Avatar
Oddometer: 729
Some of you guys might be interested in a product called the "Crimp/Solder/Seal". I posted about them a few months ago in another thread:
http://www.advrider.com/forums/showp...16&postcount=3
Ben Carufel
'02 BMW R1150GSA - '72 BMW R60/5
Recovering BMW Addict...
Ben Carufel is offline   Reply With Quote
Old 02-12-2011, 05:55 PM   #15
old2wheeler
Former nÔÔb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 720
Thumb
Just a tip not mentioned yet; when soldering, you apply the heat to the wires. When they heat up you touch the solder (resin core for electronics, acid for plumbing) to the wires and they draw the solder into the spaces all around the strands.
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Times are GMT -7.   It's 06:14 AM.
