Old 02-12-2011, 04:41 PM   #1
welder OP
welder's Avatar
Oddometer: 1,522
1978 goldwing electrical help
after replacing the timing belts in my buddies old wing we fired the bike up and noticed the headlight was now not working. we pulled the headlight out to test the bulb directly from the battery and it works fine on both hing and low curcuits. We hooked a meter up to the headlight plug and noticed that it has power on low beam only. As soon as we insert the headlight into the plug it does not work on low or high. Any ideas? I'm completly lost when it comes to electrical work.
"If you come to a fork in the road, take it." Yogi Berra.
welder is offline   Reply With Quote
Old 02-13-2011, 01:32 AM   #2
kz1
kz1's Avatar
Oddometer: 780
The Naked Goldwing site
You can always try the Naked Goldwing site for help.
www.ngwclub.com
kz1 is offline   Reply With Quote
Old 02-13-2011, 04:29 AM   #3
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,059
Power from battery to switch? (Lights on/off switch)
Power to High/Low Beam switch?
Power at the bulb socket?
Do you have an earth connection that might have fallen off?
You should have three wires if it is a standard H4 socket, high, low and earth. Are they all connected? And is one of them earthed, either to the harness or frame.
Old 02-13-2011, 06:00 AM   #4
eepeqez
eepeqez's Avatar
Oddometer: 2,068
It is possible the Goldwing has the polarity reversed. Many Japanese cars of the same timeframe have positive supply via the on-off switch to the common pin, then earth either the high beam or low beam pin as required.
I would check the voltage relative to battery negative (0V, +12V, floating, or something weird like +5V) at each of the three terminals on the bulb socket with no globe fitted, with the headlight:
switched on, low beam
switched off, low beam
switched on, high beam
switched off, high beam
From this you can work out what switching scheme is used and what part of the wiring is faulty.
But before you get completely carried away, have you checked fuses and wiggled any relevant connectors?
eepeqez is offline   Reply With Quote
Old 02-13-2011, 08:18 AM   #5
diggersrule
diggersrule's Avatar
Oddometer: 36
go to the naked goldwing site,i had the same problem. its the lighting unit, they gave a ton of info
if the cop's ask I was here
diggersrule is offline   Reply With Quote
Old 02-13-2011, 08:34 AM   #6
sporthog93
Sporthog93
sporthog93's Avatar
Oddometer: 795
It is probably just a coincidence but review the repair that you made. What wiring did you mess with?
Are we gonna ride or just dick around all day?
sporthog93 is offline   Reply With Quote
Old 02-13-2011, 09:08 AM   #7
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,528
I love the early Goldwings but the wiring is a nightmare. Lots of hidden joints in the loom and unnecessary wirimg. I've spent hours sorting GL1000 wiring out.
Rob Farmer is offline   Reply With Quote
Times are GMT -7.   It's 04:23 AM.
