Old 02-13-2011, 03:07 PM   #1
camgregus OP
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 2,946
weird stalling, hesitation
My 1989 R100 GS is doing crazy stuff again. It runs and starts fine. After a couple of miles or so, it starts hesitating on acceleration in second and third gear. Stumbles like it is about to stall.
I just replaced the diode board. New ICU last year. All connections are clean and renewed. Floats show the same amount of gas. Petcocks flow well. I drained all the old gas out and put new in (it was only two or three months old....) I love my bike, but I'm just getting sick of it not treating me well enough to get it warm enough to tune....
got to get it on the good foot
camgregus is offline   Reply With Quote
Old 02-13-2011, 03:34 PM   #2
The Raven
The Raven's Avatar
Oddometer: 4,813
Check your tank vent
The Raven is offline   Reply With Quote
Old 02-13-2011, 04:14 PM   #3
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,603
Check the main jets for blockage.
boxerboy81 is offline   Reply With Quote
Old 02-13-2011, 04:32 PM   #4
bmwrench
Oddometer: 1,462
This sounds like classic bean-can failure to me.
bmwrench is offline   Reply With Quote
Old 02-13-2011, 05:12 PM   #5
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
Originally Posted by bmwrench View Post
this sounds like classic bean-can failure to me.
+1
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 02-13-2011, 05:40 PM   #6
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,603
Originally Posted by datchew View Post
+1
+2 ...could well be, but I'd check simple things first.
Old 02-13-2011, 05:43 PM   #7
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 945
+3, thats the first thing I thought of when I read the title...
I replaced mine with the electronic version from Rick at Motorrad Elektrik, have had no issues with the new upgrade. Yet to be seen if it will last 30 years like the last one.
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 02-13-2011, 06:10 PM   #8
hardwaregrrl
Shit for brains
hardwaregrrl's Avatar
Oddometer: 4,867
Hate to say it...
+3. Sounds like what happened to me when mine died.
Old 02-14-2011, 08:10 AM   #9
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,906
Hey if you need a known working beancan for test I do believe I have one I could ship to you.
What to do... What to do...
Stagehand is online now   Reply With Quote
Old 02-14-2011, 08:16 AM   #10
camgregus OP
riding gently now
camgregus's Avatar
Oddometer: 2,946
I could use a known working beancan. I don't think it is a fuel issue. It seems electrical.. I relubed my beancan year before last and it got better.
Old 02-14-2011, 08:28 AM   #11
DaveBall
DaveBall's Avatar
Oddometer: 923
Had similar issue a few years back. Replaced springs on mechanical advance as old ones had lost their tension. Lubed the pivot points and problem gone.
A whole lot cheaper to throw in a set of advance springs and lube the pivots than replacing the whole can. Total cost to replace, including the delivery by mail from closest dealer - less than $5.00.
DaveBall is offline   Reply With Quote
Old 02-14-2011, 09:24 AM   #12
supershaft
because I can
Oddometer: 6,070
I have had bean cans act like that. Spark plug caps. Coil wires shorting at certain vibrations. Carb enricher body gaskets. Coils. It could be about anything.
Remember that aftermarket bean cans uses the exact same hall effect sensor that fails in the bean cans. The mechanical advance in the the bean can rarely acts up. When it does, it will slow acceleration and/or deceleration. It won't cause cutting out. It can't. It's mechanical, not electronic.
If they only made an electronic advance for points! Then we could truly have the worst of two worlds! Kind of like the cable operated hydraulic brake!
Old 02-14-2011, 04:43 PM   #13
camgregus OP
riding gently now
camgregus's Avatar
Oddometer: 2,946
plug wires and caps are good. Later black coil....
Dragons.....
Old 02-14-2011, 04:52 PM   #14
The Raven
The Raven's Avatar
Oddometer: 4,813
Dragons.....
Might be time to go to points
Old 02-14-2011, 05:02 PM   #15
supershaft
because I can
Oddometer: 6,070
This bike has points? I have seen them cause about every symptom known to the ignition system.
Times are GMT -7.   It's 05:51 AM.
