Old 02-14-2011, 04:11 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,668
is dielectric grease ok for heat sink
I removed the ICM from the heat sink and cleaned both surfaces. Is dielectric grease acceptable to transfer the heat.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-14-2011, 04:14 PM   #2
BikePilot
BikePilot's Avatar
Oddometer: 11,253
Its not great. I like tweaking computers and find that using proper thermal compound increases the effectiveness of a heat sink quite a lot. You can buy thermal paste at any decent computer store. The good stuff will have silver in it (like Arctic Silver 5), but even the cheap stuff is ok. If you need it to be non-conductive get the ceramic based paste.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 02-14-2011, 04:16 PM   #3
Weaverman
Damaged goods
Weaverman's Avatar
Oddometer: 59
Actually, no. What you want is heatsink compound. A lot of people use dielectric compound for this job, but it's not the right paste (although it does help and is better than not using anything). Check your local Radio Shack.
Weaverman is offline   Reply With Quote
Old 02-14-2011, 04:44 PM   #4
The Raven
The Raven's Avatar
Oddometer: 4,811
Not really like others have said. I would imagine the silver in the paste would help transfer the heat, Dielectric has no transfer agent.
I got mine at radio shack......but won't be using it due to going to points. It was about $10 for enough paste to do the job twice
The Raven is offline   Reply With Quote
Old 02-14-2011, 04:57 PM   #5
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,298
Hey Richard, get a tube of zinc oxide paste at any pharmacy, you know that white shit we used to put on our noses to look like a surfer. Same shit, cheaper too
Old 02-14-2011, 05:00 PM   #6
The Raven
The Raven's Avatar
Oddometer: 4,811
Hmmmm, good point, Metal in a medium. Probably a lot better than DG. Jenna, with that frugality I sense a KLR in your future
Old 02-14-2011, 05:01 PM   #7
One Less Harley OP
Oddometer: 4,668
REALLY?????? I'm sure I've got some of that stuff somewhere.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-14-2011, 05:26 PM   #8
blaine.hale
blaine.hale's Avatar
Oddometer: 3,068
I'll put in my 2 cents from my years building computers and needing very, very sensitive and good heat dissipation.
You actually need very little thermal paste because this acts as a filler for the imperfection in the metal. Since it's a metal on metal contact, you have tons of little imperfections that can trap hot air and not properly dissipate it through the cooling fins. The paste bridges this gap so should be very thinly applied, silver will be your best heat conductor in this case. Artic Silver is my go to for any cooling fin/heat sink application be it computers with highly sensitive CPU chips or motorcycles. I think you can get it at Best Buy now, I used to buy it at compUSA or newegg.com and a tube will last you years.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 02-14-2011, 08:08 PM   #9
One Less Harley OP
Oddometer: 4,668
Did a little search on the Zinc Oxide, someone did some comparison test w/ it and other goop. Looks like zinc oxide is a go for me!!! Well if it's good enough for Jenna.....
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-14-2011, 08:35 PM   #10
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
short answer: no
Longer answer: get the thermal paste from radio shack. zinc oxide is the active ingredient to facilitate the compound's heat transfer capabilities, but it is in a much lower concentration in sunscreen, baby butt paste, and other stuff of a more pharmaceutical nature.
the real stuff that is meant for this application is a much higher concentration. and that is for a reason.
datchew is offline   Reply With Quote
Old 02-14-2011, 09:01 PM   #11
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Oh go ahead and use some peanut butter.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 02-14-2011, 11:25 PM   #12
Tosh Togo
Oddometer: 1,594
CHunky, or smooth?.
Tosh Togo is offline   Reply With Quote
Old 02-15-2011, 06:29 AM   #13
espressodrinker
Cape Town Wanderer
Oddometer: 199
Polish the mating faces first
Use a piece of 1000 water paper on a sheet of glass and lap the mating surfaces first.
Thermal goop is far worse at heat transfer than good metal to metal contact.
I would guess that 2 well lapped surfaces don't need any goop anyway.
espressodrinker is offline   Reply With Quote
Old 02-15-2011, 07:10 AM   #14
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
+1 on the two flat surfaces. The ICU on mine actually had the part number embosed on the heat transfer surface so it needed to be sanded out before assembly.[IMG]Photobucket[/IMG]
Old 02-15-2011, 08:21 AM   #15
One Less Harley OP
Oddometer: 4,668
Good point
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 07:18 AM.
