Old 02-15-2011, 10:43 AM   #1
Beater OP
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,247
Lengthening a Swingarm ... Who?
There are a couple of people on this forum that do this sort of work ... I have tried the search but I don't think I have the right search terms ... Anyway ...
Can ya'll tell me who does it? Hopefully they can do the driveshaft too?
For those who have done it ... do you like the mod? What kinds of shocks did you get to go on it?
Thanks in advance ...
Fred
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Old 02-15-2011, 10:49 AM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
Here's one take on it.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-15-2011, 03:14 PM   #3
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 797
What happened to that one extension idea you had dreamed up on your napkin?
baldwithglasses is offline   Reply With Quote
Old 02-15-2011, 03:41 PM   #4
Beater OP
Beater's Avatar
Oddometer: 3,247
Still considering it ... HAve a guy here that could do the welding ...
Fred
Old 02-15-2011, 04:36 PM   #5
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
There's a company that sells a 100mm block that fits between the FD and the swingarm. I think they even have some bolt-on solution for the driveshaft. lemme do some searching and see if I can track it down. I'm sure it was Solo that posted it.
I think you got the name wrong in your sig line. It's not just Dobber, it's THE Dobber!
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-15-2011, 07:34 PM   #6
Beater OP
Beater's Avatar
Oddometer: 3,247
You are completely right. My bad. Fix'd.
PS - 100mm would be perfect ... Send me that ...
Fred
Old 02-15-2011, 08:20 PM   #7
FatBoyCrash
Buckle up SpankY!!
FatBoyCrash's Avatar
Oddometer: 1,129
Do it yourself!
http://www.advrider.com/forums/showthread.php?t=516530
Built In Shed
Because chrome don't get ya home.
FatBoyCrash is offline   Reply With Quote
Old 02-15-2011, 08:28 PM   #8
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
holy crap, fred. did you see these pipes?
You might want to show that to your welder friend and see what he says. I'm sure we can find a cheap GSXR muffler or something. Nothing less would be good enough for The Dobber
hope you don't mind me linking from your account, fbc. I can remove the link if you want me to.
bgoodsoil screwed with this post 02-15-2011 at 08:34 PM
Old 02-15-2011, 08:32 PM   #9
Beater OP
Beater's Avatar
Oddometer: 3,247
I just saw those in the "This is Gonna Hurt" thread ... That is exactly what I had in mind.
PS - Link Away!
Fred
Old 02-15-2011, 08:40 PM   #10
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
notice the heat shield where it goes under the seat? It should be fairly simple to get a thin wall pipe with a slightly larger diameter and cut out a quarter for a shield.
Or maybe we could put a curve in a piece of sheet metal. You'd need space between the shield and the pipe. Maybe weld in a few stainless nuts around the pipe, then weld those nuts to the shield? In the spirit of cheapness I think you should definitely make it out of a stolen road sign.
Old 02-16-2011, 05:34 AM   #11
Beater OP
Beater's Avatar
Oddometer: 3,247
I have one of those.
Fred
Old 02-16-2011, 07:15 AM   #12
norton73
drinkin'
norton73's Avatar
Oddometer: 8,306
"No Parking" signs used to mysteriusly disappear on a regular basis from in front of a house I used to live in
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 02-16-2011, 09:51 PM   #13
Quedok
Oddometer: 190
100mm longer
If you have a single sided swingarm and need it lengthened, i'm your man. I've done a bunch of them and I have a fixture so it's perfect every time.
Driveshafts are a snap too! Send it to me here in So. Cal. and I can have it back to you in a week.
Thanks,
Jim
Quedok is offline   Reply With Quote
Old 02-17-2011, 12:25 AM   #14
Country Doc
Wanderer
Oddometer: 2,718
Sweet! I'm starting an HPN build, so I'll be in touch, Quedok!
dc
Country Doc is offline   Reply With Quote
Old 02-17-2011, 07:19 AM   #15
Beater OP
Beater's Avatar
Oddometer: 3,247
Thanks,
Jim
PM Sent!
Thanks Jim!
Fred
Times are GMT -7.   It's 01:49 AM.
