Old 04-02-2011, 09:40 AM   #61
Spoke
Savage
Spoke's Avatar
Oddometer: 806
I know, it was a terrible joke. I deserve a I just couldn't resist.
Rich
It entered my blood in 1970 on a Honda QA50
Spoke is offline   Reply With Quote
Old 04-02-2011, 05:14 PM   #62
LemurPilot
Nugget
LemurPilot's Avatar
Oddometer: 268
Perfect April fools joke and you'll probably be able to use it next year too
I wonder how the thread count numbers peaked after the post and how many pissed off tire vendors there are now from answering dumb questions?
“What can be asserted without proof can be dismissed without proof.” Chistopher Hitchens
LemurPilot is online now   Reply With Quote
Old 04-20-2011, 12:12 PM   #63
Mika S
JC & MC: Double Freedom
Oddometer: 169
I'm a bit worried that the #3 might not be as good in mud as the #1 was.
Any news yet?
Mika S is offline   Reply With Quote
Old 05-07-2011, 09:50 PM   #64
BordenBmw
TheFrenchRider
BordenBmw's Avatar
Oddometer: 763
Couldn’t wait for the 150 anymore so, I’m going with a 110 front/140 back. So, first I replaced the front. Took about an hour to replace, including balancing. I had to hit the tire a couple of time with a rubber mallet to seat the bead, but that was OK.
Then I started on the back, took about half an hour to remove and replace the tire. I thought I was doing great . But after that……..I worked for more that an hour just to seat the bead and it’s still not even close. Tried the rubber mallet, more lube, a strap around the tire, bouncing the tire, nothing seems to work. I will try again tomorrow but I’m thinking that my small 12 volt pump isn’t big enough to seat the bead (never had a problem before). Anybody had similar experience with a 140 heide on 4 inches rim? I’m thinking I may have to go to a gas station to use a real compressor, any advice?
So many roads so little time...
http://www.saskatchewandualsport.com/forum/
BordenBmw is offline   Reply With Quote
Old 05-08-2011, 03:16 PM   #65
mlyamkaw
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 553
Gas station or compressor, I always leave the valve out to pressure it up first, only had to strap a tire once, it was the Heidenau.
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
mlyamkaw is offline   Reply With Quote
Old 05-08-2011, 04:24 PM   #66
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,205
150 easier to seat?
I'm guessing the 150 would be easier to seat the bead, because it is wider so a bit more outward force on the beads.
Holding out for Heidis at the moment, but getting keen for some knobblies...might have to relent and cough up for TKCs, or maybe Karoos.
Cheers, RVT
This week's ride: http://share.findmespot.com/shared/f...Vcz6Icqrhsbbpq
rvt is offline   Reply With Quote
Old 05-08-2011, 05:13 PM   #67
BordenBmw
TheFrenchRider
BordenBmw's Avatar
Oddometer: 763
I have the valve out and I am seeing some bubbles at the base of the beads but that is it. I have changed many tires before using a small 12 volt pump but on the Heide it just doesn't work, going to the gas station tomorrow.
Old 05-09-2011, 03:46 AM   #68
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,205
there is always time for lubricant
Be sure to press the beads into the rim and re-lube, before you try to reseat them.
Some go easy, others will just never happen dry.
Cheers, RVT
Old 05-09-2011, 01:19 PM   #69
BordenBmw
TheFrenchRider
BordenBmw's Avatar
Oddometer: 763
OK rear tire is .........ON. We had to bounce the tire a few time for the beads to start to seat and it took 60lbs for the beads to seat properly using a "real compressor". Now, I normally run my tires at 32 front/36 rear. I've noticed that the k60 scout says 36lbs max front and rear. What pressure should I run them at? I was thinking 30 front/32 rear for on road.
Here's an interesting view of 2 140/80 17 tires. The EXP is on a 3.5 inch rim and the k60 on a 4 inch rim. I don't think the k60 would look a lot different on a 3.5 inch rim!
BordenBmw screwed with this post 05-10-2011 at 04:03 AM
Old 05-23-2011, 06:31 PM   #70
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,948
Tires shipping
The 150's are shipping as we speak in case you didn't know...check parallel universe for more information. I should have two any day.
blaster11 is offline   Reply With Quote
Old 05-23-2011, 07:30 PM   #71
Englishmatt
Englishmatt's Avatar
Oddometer: 606
So where did you order them from? Happy that you got a pair, but sharing where you got them from would be cool... :-)
Thanks,
Matt.
2014 KTM 1190 R Adventure - Where to now?
2010 R1200GS Adv (gone, took me to Deadhorse)
2008 KTM 990 (gone, regretfully)
"I can't lead, I go too fast..." Scott Hinkle, 4/2010
Englishmatt is offline   Reply With Quote
Old 05-24-2011, 03:16 AM   #72
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,948
I got mine out of a place in Arkansas, just check the Moto Amore site for a list of distributors. You can try what I did which is call Moto and ask who got tires. Also check the last couple pages of this thread for vendors as well. http://www.advrider.com/forums/showt...568324&page=64
Old 05-24-2011, 03:42 AM   #73
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,840
Mine arrived last Friday (150 rear) and I spooned them on late Sunday afternoon. Sidewalls are stiffer than some others I've installed, but no real drama using my tire irons. Beads seated OK, and balance was exactly as on the Tourances I removed (first time that's ever happened that I can recall). Unfortunately, haven't been able to even scuff them in yet as I flew out early Monday on a business trip but they look great on the GSA. That is some deep tread on the rear!
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 05-24-2011, 03:50 AM   #74
channa51
Oddometer: 58
http://www.heindlengineering.com/Onl...enau_tires.htm
channa51 is offline   Reply With Quote
Old 05-24-2011, 04:27 AM   #75
ollka
Usually lost
ollka's Avatar
Oddometer: 114
I love'em. After some practise, I found they work best with some 20% lower pressure than normal dual tires. Front 1,8bar instead of 2,2 and rear 2,0 instead of 2,5bar. Great handling on gravel roads and very tolerable on black stuff.
Very good allrounder
Best thing about a GSA is getting lost
Wrrrroaaming around with GSA 2010 and Audi S5 SB
ollka is offline   Reply With Quote
Times are GMT -7.   It's 05:36 PM.
